Go to Post You don't have to beat stronger teams to get better... to get better is to be forced to push the envelope against stronger teams. - Shankar M [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 20-12-2013, 23:22
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
2014 Game Theories
Ok, this isn't for talking about the hints. The idea here is to post your theory of what the game will be. Curious who if any will be closest come January 4th.
My theory:
A hockey game played on the same surface as Lunacy to give it an ice hockey feel. I also think there will be a mini-bot throwback. The mini-bot will be a quadcopter type thing that will be used to score bigger points. There will be 3 alliance: blue, red and green. 2 teams per alliance.
All the Doctor Who references give to the fact that they are traveling back in time to past competitions to pull out all the stops this year.
Unread 20-12-2013, 23:23
Andrew Lawrence
Posts: n/a
Re: 2014 Game Theories
Are you purposely putting together two of the most hated game components from the past 5 years?
Unread 20-12-2013, 23:24
Connerd's Avatar
Connerd Connerd is offline
09R - JBD Detachment, USU ROTC
AKA: Conner Doggett
FRC #3166 (First Year Ravens)
Connerd will become famous soon enough
Smile Re: 2014 Game Theories
Originally Posted by Connerd View Post
While I love most (if not all) the ideas stated above, I know what the game will be: CTF! The field will be of similar shape and size to those from Rebound Rumble and Ultimate Ascent, with two team stations on either side. The floor will be some texturally interesting material, or possible combination of materials. There will be an assortment of weights in the middle of the field, with varying weights. The goal will be to, with some automatous mode, get the most weights on your side of the field. The interesting part is, "Do we push it in front of us, hoping another team doesn't take it, or do we pick it up, and carry it?" A balancing end-game finishes the round. What do you guys think?
This still might work... I'm still interested in how people think about this.
2012-2014 - Team 3245 Ravens, Student/Mascot
2014-20?? - Team 3245 Ravens, Alumni
2015-20?? - Team 3166 Ravens, Mentor
Unread 20-12-2013, 23:28
AKA: Rich Lester
Nope, but would you put it past First to try and get it right this time.
The mini bot comes from a link that I caught posted somewhere on FRC to http://www.youtube.com/user/dblavery/videos
His videos are game videos and award videos. All except the latest one that was a quad copter test at NASA.
Unread 20-12-2013, 23:37
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
the game piece will be hula hoops
My Instructables
Unread 20-12-2013, 23:38
Oblarg Oblarg is offline
AKA: Eli Barnett
I think it fairly likely the game piece will be a ball.
Past that, I haven't a clue.
"The breakfast of champions!"
Unread 21-12-2013, 00:31
Mitchell1714's Avatar
Mitchell1714 Mitchell1714 is offline
What's better than robotics?
AKA: Mitchell Schlidt
FRC #1714 (MORE Robotics)
Mitchell1714 will become famous soon enough
Street Hockey
2 alliances of 3 teams compete to score the most goals with tennis balls.There is a hockey goal in the middle of each alliance(similar to breakaway goals). There are many balls on the field of play (50+). Normal robots cannot go into a "goalie box" without penalties. Some robots may choose to be goalies, but they cannot score balls for their alliance. Scoring robots may not pick up balls. Once a tennis ball touches the ground it must continue to touch the ground (,like the soccer balls in breakaway had to touch the ground).Endgame is a shootout.
2016-present: 1714(Alumni)
2011-2015: 1714(Student, FRC)
2013-2015: 1714(Student, VEX)
2006-2011: 1714(FLL)
Unread 21-12-2013, 00:37
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Hey guys, can we try to condense these discussions threads together? There are tons of game hint threads and several discussing the potential 2014 game.
We are all excited for the new game but lets try not to go crazy on the thread making.
1058 PVC Pirates 2016 - xxxx
Unread 21-12-2013, 00:38
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Agreed. This thread has absolutely no purpose.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 21-12-2013, 08:01
Michael Hill's Avatar
It will either be a football or something that must be manipulated with an arm. Definitely not a round ball.
GDC has had too many "shooting" games recently.
Unread 21-12-2013, 08:15
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Yep, there was a pretty popular thread on this topic made back in April, and it is still often used as the go to thread for any guesses. Please just use that.
http://www.chiefdelphi.com/forums/sh...hreadid=116291
Unread 21-12-2013, 08:46
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
My theory:
No offense, but in spite of your caveat, this will become a parallel thread.
Quadracopters and TARDIS's, TARDIi, TARDAe?
A mashup of previous games. That is usually the paradigm.
I will respect your intentions and go with a Hockey Game.
The endgame may ask us to "pull the goalie" and go on a scoring frenzy.
Not a quadracopter, but one of those simple helicopters ($20) to be launched in the endgame to rescue the Princess from Donkey Kong.
Unread 21-12-2013, 13:28
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Please can we stick to the hint thread and the already well used 2014 game thread? Maybe someone could close the thread?
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 21-12-2013, 14:37
AKA: Rich Lester
Why so rude? This thread was dying anyway. All this was supposed to be was peoples theories. Not discussing hints in a 10+ page post. I figured it would be fun to see if anyone was correct. Why keep every aspect of talking about the 2014 game in one over blown thread.
This thread isn't about the hints really, it was about guessing the game. If the admins want to delete it, they are well within their rights, but commenting on a post that you don't like is just a way to keep it alive.
