| Thread Tools |
Rating:
Display Modes |
#301
Re: [FRC Blog] 2014 Game Hint
Or
http://www.morethantoys.com.au/shop/...25-degree.html [It's model number appears to be 57-C8234] Could bring us back to racing. |
#302
Anyway, I'm really not getting much out of those Morse Code "translations." |
#303
Our friends in Israel, the most important FIRST outpost on the planet, are cogitating the clue. Emily has provided one of the more interesting interpretations, though I don't think that game would be "fan-friendly". I think the KOP change to easily accommodate different attachments means that a modular robot that can perform unique functions, depending on the abilities of the alliance partners, may be in order this year. This, along with the three people (okay, Dean is somewhat robotic at times ) in the picture, suggests a triad that can work together points to 3v3v3. It's hard enough to explain the game to the casual observer with 6 robots. 9 robots?! Well at least we may get the increased number of matches in a Regional or District that we have asked for, but the coordination of the matches will be tough. If this is the case, I predict 3:00 matches, with more time between matches. Ohhh, the batteries! Ohhh, the scouting. A scoring robot, a defense robot, and a third for a unique endgame. Hockeyball? Basekey? Umpires, referees, replay booths? I hope not. I need to wrap presents. Happy Solstice. The only holiday created by "God". http://www.washingtonpost.com/blogs/...er/?tid=pm_pop 12:11 on 12/21 (almost a palindrome) Waning gibbous. Lunacy I need to wrap presents. |
#304
I think one thing that we're forgetting is the fact that FIRST is changing the KOP drive base. This may play a factor in what the game is.
#305
Baptist -> Baptism -> Water
Sorry Gotta go wrap presents. |
#307
Looking at the previous posts, baseball does seem very possible. Just a question though, did any FRC game have an element that involved two robots from opposite teams doing something correctly (i.e. FRC tennis)?
#308
Not to offend anyone, but for all the people who are suggesting 3v3v3 or something of the sort: Have you ever been to a DISTRICT event? Space is already extremely limited as it is. It would be impossible to have 3v3v3, unless they drastically reduce the size of the playing field. Even queing areas would be a nightmare. I don't foresee 3v3v3 or anything similar coming for a very very long time. And if that change ever does come, half (probably more) of the high school gyms that are currently utilized for districts wouldn't be big enough to use anymore (Let alone offseason events...)
#309
Has anyone considered that the numbers could be a reference to a topic/post number on a forum? I looked on the first forum and found some things, as well as some dead ends.
#311
Do you think that maybe it will take a string of plugging the numbers into the calculator? Or would that work? Take your answer and go through the process again. Maybe it will make sense after that.
#312
As for alliance stations - would one alliance have their teams on what side of the field, the second alliance have their teams on the other side of the field, and the third alliance have their teams split between the two sides of the field? |
#314
If there's actually a 90lb weight limit, I'm going to be very frustrated. The weight limit is tough as it is; I can only recall one robot I've worked on in the entirety of my time in FIRST that weighed under 90lbs.
#315
It was really really easy to find it on google earth, I just entered the pairs of numbers (i.e 8234/57) and took the first option |
