Go to Post Let gravity be your friend. - MrForbes [more]
Unread 20-12-2013, 22:30
gluxon's Avatar
gluxon gluxon is offline
\n
AKA: Brandon Cheng
FRC #0178 (The 2nd Law Enforcers)
gluxon has a spectacular aura aboutgluxon has a spectacular aura aboutgluxon has a spectacular aura about
Re: Fixing opencv lag
Request a video stream from VAPIX with the "fps" HTTP parameter. Details are on page 12 of the VAPIX API doc -> http://www.axis.com/files/manuals/va...37_en_1307.pdf
And if it helps, there's an incomplete Node.js implementation of VAPIX that supports a video stream with the slowed down fps you need. https://github.com/gluxon/node-vapix
This answers your question, although I feel like the problem will still occur, just over a longer period of time with this change.
Edit: I would actually go with what virtuald said in his post for the solution. Sounds like a more complete way of handling things.
Unread 21-12-2013, 12:06
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Originally Posted by billbo911 View Post
I would definitely like to hear more about this approach.
I am no expert on the efficient use of OpenCV, and what you are proposing just might be the key to get rid of the minor delay we are seeing in our images. We can process 15-20 fps, but there is a small, but noticeable lag in our images.
We are using a USB camera and a PCDuino, but otherwise it is mostly the same.
Our implementation is available on my website if you want to look at it. Look for kwarqs2013.py.
Unread 21-12-2013, 12:11
virtuald's Avatar
RobotPy Guy
Originally Posted by sst.thad View Post
As for grabbing the image directly, openCV has no way of just opening a jpg over the network.
Not true. If you have ffmpeg support enabled (which it is by default in most opencv builds), you can retrieve the mjpeg stream directly from the camera via FFMPEG. Something similar to the following (error checking omitted):
vc = cv2.VideoCapture()
vc.open('http://%s/mjpg/video.mjpg' % camera_host)
h = vc.get(cv2.cv.CV_CAP_PROP_FRAME_WIDTH)
w = vc.get(cv2.cv.CV_CAP_PROP_FRAME_HEIGHT)
capture_buffer = np.empty(shape=(h, w, 3), dtype=np.uint8)
while True:
    retval, img = vc.read(capture_buffer)
Unread 21-12-2013, 12:43
magnets's Avatar
magnets magnets is offline
The reason we are on a beaglebone instead of the dashboard is i have heard stories of FTA's requiring dashboards to get shut off, and we don't want to be stuck if that happens. So we want it to be onboard.
This.
In 2012, I had to tell a student that the vision software they worked on was not allowed because the FTA wouldn't let us use it. Then, we were stupid enough to try vision again in 2013, thinking that the "bandwidth limit" (which doesn't work) would prevent the FTA from banning the dashboard, but no, the FTA said we weren't allowed to use our vision stuff yet again, but this time, because a robot on the field had stopped working "because we sabotaged their network connection". What really happened? The other teams battery fell out. Not our problem, but we still couldn't use vision. Vision is not a guaranteed ability for robots. Nor are dashboards, or any amount of communication.
Unread 21-12-2013, 13:42
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by magnets View Post
... Vision is not a guaranteed ability for robots. Nor are dashboards, or any amount of communication.
I think the crux of this thread points out the error in your statement.
Yes, it is really a shame when a feature that has been pushed by FIRST is taken away, for any reason, and that feature is part of the major design a team has undertaken. The point of this thread, on the other hand, is how to avoid this possibility entirely.
Here is why this thread addresses this. If the vision processing is done by a separate on-board system, Beaglebone in this case and PCDuino in ours, it removes the wireless network entirely. All acquisition of images, processing and communication of target information remains on the robot. Honestly, for much less than $200, any team can do this! It just takes time to learn how, and the information is already readily available.
Unread 21-12-2013, 14:39
Volunteer, WPILib Contributor
no team (Waiting for 2021)
while True:
Yeah I know I can recieve the MJPEG stream like this, and that is what I am doing. The camera still pushes frames into the stream at 30 FPS. If the vc.read does not occur faster then 30 times a second, The buffer will start to backlog and lag. In fact your code was what I started from, and I was doing exactly that. If you put at 50ms delay at the end of your processing function you will see that it starts to lag.
When people were talking about requesting images, they are talking about not opening the stream, but just directly requesting a single image, and working with that, so the camera does not push a buffer. Thats the part that does not work natively in openCV.
Team 4488 - Mentor 2013-2016
