| Thread Tools |
Rating:
Display Modes |
Game Hint Solution [probably]
Hi CD,
I searched the numbers in google earth: The second numer refers to a sign "Security FIRST" and there is a US post office in front of it. The third number refers to the "FIRST Baptist church" The first number is very interesting, there is a sign: "WEIGHT LIMITS REDUCED 25% EFFECTIVE 1 JAN TO 1 MAY" which is the FIRST season The photo of the sign can be found in the link below. To find it on google earth: 1. Type 8234/57 in the search bar 2. pick the first option (ohio) 3. go to the main street 4. you will see the sign https://maps.google.com/maps?ll=40.94281%2C-81.311998&cbp=%2C32.62%2C%2C3%2C15.080002&layer=c& panoid=VNSRfLx4QNO3teEqfg3kxg&spn=0.18000000000000 152%2C0.30000000000000676&output=classic&cbll=40.9 4281%2C-81.311998 Have a great season! Thanks to my friends from the FIRST Israel community for helping |
Re: Game Hint Solution [probably]
Let's keep all the hint discussion in the original thread, it makes for a far cleaner forum. Thanks.
Could someone with magical forum powers merge these threads? That being said, I sure hope the weigh limits aren't lessened. That would be very annoying. |
That's pretty good work. The reduced weight limits could be the real deal, especially with the rise of and emphasis on 3D printing, and last year's reduced size. I believe a 120lb robot with 14 lb battery and ~16lb bumpers is over the recommended weight that two high school students should be lifting, so this makes sense.
Can you explain how you found the 3rd number to relate to the church? |
I kind of prefer this thread to be separate...saved me a lot of time not having to read the whole other thread....
Keep this thread separate, because this is the most legitimate analysis I've seen.
#7
But, oh well...Last edited by dellagd : 21-12-2013 at 14:46. |
#8
Anyone got any ideas? The control system is a relatively large chunk of that weight. Colsons are a no-go since they weigh much more than other off the shelf wheels. Steel gears? No way. If the weight limit really is 90 pounds, the game could be as simple as Lunacy and this would still be a very significant challenge for every team. |
#9
I'm intrigued. I think this is for real, or else a very well camouflaged red herring.
Like Chris said, getting under 90 would be really hard... We could have done it with our offseason bot, but it still would have been very difficult. Perhaps the weight limit refers to the game piece or something else? |
#10
Kinda depends on the game, eh? I know of at least one robot in 2008 that was very light, yet very successful.
#11
Im just throwing this out there, but its just saying a 25% reduce. Who says that the reduce is off of last years weight? it could be off of the older weights making not such a huge decrease.
#13
This is (effectively) the highest weight limit we've ever had. It used to be 130, but with battery, which was 14 lbs, for a max usable weight of 116 lbs.
#14
This was my immediate thought upon reading speculation about the reduced weight. Maybe Andymark has all those options for modifications on the kit because maybe the weight tiers won't just be based off height, but overall frame perimeter instead.
#15
Very interesting! I like the tiered idea... Makes for a more interesting design challenge.
