Go to Post Imagination is important, but try not to use it as a substitute for actual information. - Alan Anderson [more]
  #31   Spotlight this post!
Unread 10-02-2003, 01:30
WakeZero WakeZero is offline
FIRST-a-holic Strategist
#1011 (CRUSH)
WakeZero will become famous soon enough
Send a message via AIM to WakeZero Send a message via Yahoo to WakeZero
<laughs>
I knew someone was going to be crazy enough to actually succeed in this design. A big congrats for pulling it off, you will be a force to reckon with
2004 Arizona Regional -- Semifinalist
2003 NAT Galileo Division -- Highest Seeded Rookie (20th)
2003 NAT Galileo Division -- 100% Autonomous Completion (7 for 7)
2003 Arizona Regional -- Rookie All-Star Award
2003 Arizona Regional -- Quarterfinalist
Alumni on Team 64, The Gila Monsters
College Mentor/Founder of Team 1011, CRUSH
  #32   Spotlight this post!
Unread 10-02-2003, 04:06
soezgg soezgg is offline
Senior Member
AKA: Harry Miller
#0639 (The Rude Awakening)
soezgg can only hope to improve
Send a message via AIM to soezgg Send a message via Yahoo to soezgg
hmm
people have to remember that there are many aspects to this game. dominating the ramp is but one of them.
until the first regional takes place, the happenings in the matches themselves are still verymuch up in the air.
anything is possible.
also: most robots look intimidating- until you push them across the field and reverse their motors.
  #33   Spotlight this post!
Unread 10-02-2003, 09:51
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
a few questions that i have for you...
1. what are you using for your drive motors?
2. what kind of gearing are they?
3. your light is definatly illegal the way its mounted.
3. and do you foresee any weaknesses?
...WOW...
Bad
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
  #34   Spotlight this post!
Unread 10-02-2003, 12:15
Johca_Gaorl's Avatar
Johca_Gaorl Johca_Gaorl is offline
Pwn3d
#0122 (NASA Knights)
Johca_Gaorl is an unknown quantity at this point
Send a message via AIM to Johca_Gaorl
M8
Robots must use the rotating light provided in the kit to display their alliance color (red or blue). The light must be mounted upright on the robot so that the color is always visible from a distance of at least 100 feet. The light should be mounted to allow easy changeover of the colored lens before matches. See Section 3.2.2 for Rotating Light wiring information, also see Rule C26.
There have been numerous design questions relative to the installation/placement of the rotating light. The purpose of M8 is to insure that your drivers, the referees, the scorekeeper, and the judges can identify your robot and that the audience has some idea of who’s who; and to make sure that it is installed to enable EASY CHANGEOVER OF THE LIGHT LENSE.
A momentary “loss” of visibility of this beacon is allowable; however, 99% of the time FIRST requires that the top 4” of the light be visible.
Since you can't see your light from all sides, I think you should do something, cut out some of the green material (or use clear lexan) or just mount it higher in the middle. Seems to me like it's fine to have it start sideways (ours did last year), you should have no worries in that aspect, just make it so you can see it from all sides.
BTW, if you want, I can host some videos for you, e-mail them, and I can get them up sometime tonight probably. I'm sure we all want to see this thing go up and over the side. johcagaorl@cox.net
DOX
At VT! Guess I'm unofficially part of 401 now...
  #35   Spotlight this post!
Unread 10-02-2003, 12:58
AKA: Mongo
yea bots have been allowed to have thier lights mounted in a vertical position.
but there has been a rule change and the light is illegal the way its mounted now.
Bad
  #36   Spotlight this post!
Unread 10-02-2003, 13:22
Steven Carmain Steven Carmain is offline
Bit Twiddler
FRC #2832
Steven Carmain will become famous soon enough
What motors do you use to get the robot over the wall? With the output torque needed and the speed you say you can do it, I think your lying.
2017 - Team 2832 Mentor
2016 - Team 6013 Mentor
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
  #37   Spotlight this post!
Unread 10-02-2003, 13:35
Senior Member
AKA: Harry Miller
agreed
they can definitely not do it with motors in 2.2 seconds.
the gearing would have to be insane to get 100 plus pounds over a 3 foot something wall 5 feet away from the axis of revolusion for 270 something degrees
the only forseeable way to do it is through pneumatics.
ill believe it when i see it on video.
  #38   Spotlight this post!
Unread 10-02-2003, 13:39
Andy Grady Andy Grady is offline
I'm done being quiet!
FRC #0131
Rookie Year: 1995
Andy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond repute
Send a message via AIM to Andy Grady
Wow!
Well, needless to say, I am very impressed. I am dying to see this robot in action. You may already have won my scratch-award for coolest robot of 2003! I just go back and remember my favorite pole vaulting robot in 2001, that team 25 made. This one, if its as impressive as you speak, might just put that one to shame! Good Luck!
-Andy Grady
  #39   Spotlight this post!
Unread 10-02-2003, 14:34
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Then out of those 13% they have 4 motors with a nice transmition and traction and come screaming at us. Then they still need to elevate after coming from under the bar at us cuz were about 1-2 feet off the ground at that point.
Still the thing is on a mono pod. It is very precarious in that configuration. One little hit from a robot while it is on that monopod and kaboom you will tip over.
  #40   Spotlight this post!
Unread 10-02-2003, 15:54
Joe3's Avatar
Joe3 Joe3 is offline
Joe3 has a spectacular aura aboutJoe3 has a spectacular aura aboutJoe3 has a spectacular aura about
Send a message via AIM to Joe3
Thats what I was thinking...what if an under the bar robot shoots under the bar and hits you when you'r lifting yourself up. Your center of gravity is pretty high there, and just a small bump looks like it could topple you over.
  #41   Spotlight this post!
Unread 10-02-2003, 16:58
EIROBOTICS86's Avatar
EIROBOTICS86 EIROBOTICS86 is offline
#0311 (Red Jammers)
EIROBOTICS86 can only hope to improve
Send a message via AIM to EIROBOTICS86
Thats cool but does it meet the dimension requirements
Yo
  #42   Spotlight this post!
Unread 10-02-2003, 17:20
Aaron Lussier's Avatar
Aaron Lussier Aaron Lussier is offline
Volunteer for hire
Aaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to behold
...WOW...
Bad
I realize that I'm not on 179 but perhaps I can help
1. Looking closely when It is in its Starting position, Near the top you can see The Gear Boxes That FIRST gave to all teams, so most likely Drill Motors
2. See #1, and what ever the gear ratio is for the Gears that FIRST gave all teams
3. Prove it
4. Possibly Twisting on the bridge if they get hit from both sides
But again I'm not on there team so I could be completely wrong, Dont take anything thing I say to be true or untrue.
Team 151 Student/Mentor 2001-2004
US Navy 2005 -2009
Volunteer 2010 - ???
Field Reset Extraordinaire
  #43   Spotlight this post!
Unread 10-02-2003, 19:11
#1011 (CRUSH)
Re: hmm
There are many strategies yes, but if a 'king of the hill' robot are successful at doing what they are suppose to do... all they need is an alliance partner who can drive (not necessarily go under the bar) to have a 90% chance of winning.
Of course, things rarely go the way you intend them to
  #44   Spotlight this post!
Unread 10-02-2003, 19:28
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: agreed
They never said they did it in 2 seconds. They flip over the wall in two seconds. They dont hit the boxes in two seconds. who cares if it takes two seconds, or a few more, I'd imagine itd be faster than any other method. Im worried that something goes wrong and you crash down on the polycarb sides (Or are they Lexan) If that happens, I don't ever see the officials letting you run the bot like that again.
Cory
2001-2004: Team 100
2006-Present: Team 254
  #45   Spotlight this post!
Unread 10-02-2003, 19:46
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
well, in all reality lots of good teams are gonna be goin bout 10ft per second, and i do think that they will be under 4 maybe even under 3 seconds to the top (our team can do it under 3 but i aint sayin how hehehe)
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
swamp thing team 179 Danielle 212 Chit-Chat 2 24-06-2003 22:06
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
