Go to Post I heard a Lou Holtz quote as an answer to the question of "how do you motivate the unmotivated". He said " You eliminate those who are not motivated." - Scott Ritchie [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 22-12-2013, 15:31
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Re: Game Hint Solution [probably]
I've been advocating that our teams integrate the plywood bumpers into the robot chassis structure. With good quality plywood (
plywood article ) and good joinery, the plywood could contribute much more to the chassis structure than hanging on a metal frame. The arguments against have been:
  • Would require skirts for quick change of colors and skirts don't work
  • The attachment to the chassis would require much work to remove and reinstal for weigh-in
  • Would look amateur
  • "Nobody else does that" (not necessarily a bad thing IMO)
  • "Judges won't like it"
I could certainty be missing something but if passes rules, could have the following benefits:
  • Approx 5 lbs of structure is free and save weight in chassis
  • Jointed corners would provide excellent racking strength
  • Wood takes impacts well; particularly high quality grades
  • Wood is relatively easy to work
  • There are more skilled carpenters around than machinists
Think glued, dovetailed rigid perimeter that slips over and fastens to interior chassis.
