Go to Post Being a mentor doesn't have an age requirement. As long as you are positively influencing someone you could be called a mentor and a role model. - EricLeifermann [more]
Unread 23-12-2013, 14:11
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Importing SDK .jar
You're just telling it not to stop when it hits an error The error will still exist and the code likely not work.
Unread 23-12-2013, 14:30
dc74089's Avatar
dc74089 dc74089 is offline
Control Systems Lead
AKA: Dominic
FRC #1902 (Exploding Bacon)
dc74089 will become famous soon enough
Oh... From what I've seen on preverification, it looks to me like I need to preverify the SDK .jar? I'm poking around with that now.
-Dominic
Think big. Think smart. Think different.
FLL - Nerdvana (2011-12)
FTC - Nerdvana/Clockwork Mania 6379 (2012-13), Team HazMat 9277 (2014-?)
FRC - Clockwork Mania 4013 (2014), Exploding Bacon 1902 (2015-?)
Unread 23-12-2013, 15:39
It's unclear what you are trying to accomplish by loading the library into the cRIO code. The device will be connected to the computer and the code will be on the cRIO so how will the two communicate?
It sounds like you want to create a Java dashboard or other program to run on the DS and pass messages over something like UDP or Network Tables to the cRIO to use as control signals.
