Go to Post Enlighten a man who sometimes has difficulty understanding why others stray outside the box, when the box appears to be an optimized and elegant solution. - JVN [more]
Unread 23-12-2013, 19:22
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
Re: Prototype transmission for potential use this year
Originally Posted by magnets View Post
I brought up a few of the several concerns here, but I don't have experience with worm gearing for drive parts. My thought is that the teeth will just snap off before the wheel looses traction with the ground. In your gearbox, did you have your worm gear before or after any other reduction?
I know you were the first one to bring up these concerns and I agree with you completely, I was just adding another voice to the argument.
In our gearbox we had a 1:1.4 spur gear (20 to 28 tooth) reduction from each of the cim motors before the 1:10 reduction of the worm gear (4 start worm and 40 tooth gear). The worm gear was on the output shaft. It can be seen here http://www.chiefdelphi.com/forums/sh...ht=192+gearbox.
The layout is the same as the AndyMark rawbox
