Go to Post While money can create fancy-looking robots, it does not always create game-winning ideas. - Karibou [more]
Unread 24-12-2013, 01:18
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Re: GCC 4.8 Toolchain
Originally Posted by virtuald View Post
True, I'll change the docs. Vagrant 1.2+ should work. There are various bugs in vagrant that I've ran into over time, so I'd recommend 1.3.5 if you're not going to use 1.4.
I think there are some other additional requirements to make this work. Here's what I got:
Bringing machine 'default' up with 'virtualbox' provider...
[default] Clearing any previously set forwarded ports...
[Berkshelf] This version of the Berkshelf plugin has not been fully tested on this version of Vagrant.
[Berkshelf] You should check for a newer version of vagrant-berkshelf.
[Berkshelf] If you encounter any errors with this version, please report them at https://github.com/RiotGames/vagrant-berkshelf/issues
[Berkshelf] You can also join the discussion in #berkshelf on Freenode.
[Berkshelf] Updating Vagrant's berkshelf: '/home/eric/.berkshelf/default/vagrant/berkshelf-20131223-3824-141h9iv-default'
[Berkshelf] Using frc-gcc-vm (0.1.0)
[Berkshelf] Using apt (1.7.0)
[default] Clearing any previously set network interfaces...
[default] Preparing network interfaces based on configuration...
[default] Forwarding ports...
[default] -- 22 => 2222 (adapter 1)
[default] Booting VM...
[default] Waiting for machine to boot. This may take a few minutes...
The guest machine entered an invalid state while waiting for it
to boot. Valid states are 'starting, running'. The machine is in the
'poweroff' state. Please verify everything is configured
properly and try again.
If the provider you're using has a GUI that comes with it,
it is often helpful to open that and watch the machine, since the
GUI often has more helpful error messages than Vagrant can retrieve.
For example, if you're using VirtualBox, run `vagrant up` while the
VirtualBox GUI is open.
This is with virtualbox 4.3.6 and vagrant 1.4.1 on 32-bit Ubuntu 12.04. The Virtualbox GUI suggested a problem with VMX instructions but I checked and those are enabled on my system. It appears that the guest system is 64-bit. Perhaps the host is required to be as well.
Also, it might be helpful to note that the "vagrant up" should be done in the directory of the checkout. This is probably obvious to someone who has used vagrant before but I suspect most people haven't.
