Go to Post Maybe someone should start a FIRST Anonymous meeting to try to help the tragicly addicted... - BiTurboS4 [more]
Unread 24-12-2013, 01:02
Andrew Lawrence
Posts: n/a
pic: Practice DT
Unread 24-12-2013, 01:06
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Re: pic: Practice DT
After a brief once-over, I notice the cylinders in the back, that hold the battery.
a) What are the made out of?
b) How do they mount?
c) They seem to mount with the edges right on top of the gusset plate that holds the upper 1x1 tubing, which, in my experience, is a problem.
Looking good!
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 24-12-2013, 01:11
BurkeHalderman's Avatar
BurkeHalderman BurkeHalderman is offline
Casual Robot Observer
BurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant future
How did you space out the pulleys in the gearbox? When I opened the CAD it looked like two 9mm VexPro HTD timing pulleys couldn't fit without rubbing against the bearing and shifter plate. It looks great, really like the paint scheme.
[2010-2014]: FRC 3266 Robots-R-Us: Founder and Alumni
2010 (5-5-1): Buckeye Regional; Driver
2011 (4-5-0): Buckeye Regional; CORI; CAGE Match; Drivetrain/Manipulator Operator
2012 (7-13-0): Buckeye Regional; Queen City Regional; CAGE Match; BPRC; Drivetrain Operator
2013 (25-15-1): Queen City Regional; Buckeye Regional; Crossroads Regional; CORI; Ohio State Champs; CAGE Match; BPRC; Drivetrain Operator
2014 (21-10-0): Crossroads Regional; Queen City Regional; Designer; Mechanical/Design Mentor
Founding an FRC team as an 8th grader sure wasn't easy, but it was totally worth it.
Get in touch with me:
Personal Facebook
I believe every human has a finite number of heartbeats. I don’t intend to waste any of mine. – Neil Armstrong
Unread 24-12-2013, 01:32
Andrew Lawrence
Posts: n/a
Looking good!
The golden spacers are 3D printed. It's a resource my team has readily available to us, so we like to use it every once in a while. They're a bit large in this photo. In the latest iteration they've been slimmed down to 1/2" OD (I think they're like 3/4" OD here). There are bolts (not put into the model until a later iteration done this morning) that go through the spacers and hold the plate steady to the frame. The new smaller iteration doesn't interfere with the gusset plates.
Two 9mm VEXpro HTD timing belt pulleys fit perfectly into the WCP WCD single and dual speed transmissions - they were designed to fit them perfectly, and my earlier design used two next to each other no problem with 0 interference. However what I like to do is put a single 15mm pulley in place of the two 9mm pulleys. The actual 15mm pulley is toleranced a bit larger than 15mm to be able to hold two 9mm belts if needed.
Unread 24-12-2013, 11:38
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
To expand on this, the 15mm pulley has 17mm of space for a belt. This may not seem like enough, but RC from WCP has told me that the VexPro belts are actually 8.5mm instead of 9mm, allowing a perfect fit for two of the "9mm" belts. Useful information for anyone trying to save space and use belts in series with each other.
Unread 24-12-2013, 15:37
Excellence is Bliss
Additionally, I'd like to say that this model looks really nice!
And to think, just a year ago, you were here:
http://imgur.com/S5rHfOV
They grow up so fast!
Unread 24-12-2013, 15:56
Andrew Lawrence
Posts: n/a
So over the span of a year, I replaced the cross braces with a bellypan and added superstructure mounting. Such learn. Many improvement. So CAD.
Unread 24-12-2013, 18:02
UAH Class of 2019
Now that it is not midnight, and I have had a bit more time to look at it:
a) That battery holder look really snug, which is a good thing, BUT, I would give it at least a little wiggle room, then strap it down or something. Last season, our manufacturer made our battery container too small, and, as a result, we had to cut of one side, and strap the whole thing down really tightly.
b) What is the ground clearance on this? It seems to be 1/8" or less?
c) The spikes next to the CRio. Have you considered how difficult it would actually be to put the electronics on those? Unless you put the wiring on first, then put them in place.
Unread 24-12-2013, 18:09
Andrew Lawrence
Posts: n/a
There is 1/16" of clearance on all sides of the battery. It's snug, but the battery can slide in easily enough and it's strapped down with velcro. We ran this setup in the offseason and loved it.
A little more than 5/8" ground clearance.
Since our electronics are to be velcroed down, we can wire first then place. Though there is is plenty of room to wire up regardless of spike position (the angle of the picture makes it look strange).
Unread 25-12-2013, 15:46
Chris is me's Avatar
AKA: Pinecone
Have you put any thought into sizing the drive belts and pulleys for this application?
It seems like you're using 9mm HTD belts with pulleys that can't be more than 24T. We have definitely had ratcheting and strength problems using 9mm wide belt with pulleys about that small. I would check the Gates spec sheet or run a test chassis before you bet your season on what fits most conveniently. I really think for a west coast setup you're going to want 15mm wide belt.
Also, relying on a 17mm wide pulley to fit two belts that are "about 8.5mm wide" seems like it's asking for trouble. Absolutely zero extra space for belts on a pulley isn't a great idea.
Unread 25-12-2013, 16:22
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
I'd second this. On the prototype of last years gearbox we had two belts on the same pulley with no flange between them. Even with space between the belts, they would drift together and started to eat each other. Not enough for he belts to be anywhere near failing but there was plenty of rubber dust. I don't think it's a good idea to force the belts together.
Unread 25-12-2013, 17:25
AKA: Pinecone
Were you running exact center-to-center distance on your belts? While we don't cram belts onto tiny pulleys we do run two belts without a flange in the middle and it's worked fine for us. I suspect running exact centers helps prevent the belts from walking.
Unread 25-12-2013, 17:30
Andrew Lawrence
Posts: n/a
We ran this exact same setup in the offseason and it worked like a charm. 9mm HTD belts on 24T pulleys 9 1/2" C-C spacing with tensioners in a WCD setup.
Unread 29-12-2013, 23:29
Cash4587's Avatar
Cash4587 Cash4587 is online now
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
How do you plan to mount encoders on this drive?
Unread 30-12-2013, 03:59
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
What are the wingnuts for?
