Go to Post This 6 weeks of work, sweat, thinking, designing, building, talking, discussing, turning wrenches, wiring, programming, drawing on chalk boards, eating pizza, drinking mountain dew, with the students - is what the FIRST experience is really about. - meaubry [more]
Unread 23-12-2013, 00:40
ftcTeam6389 ftcTeam6389 is offline
FTC #6389
ftcTeam6389 is on a distinguished road
[FTC]: Help With AutoDesk Inventor 2012 ?
Hi,
I am trying to "trim" a standard Tetrix ipt part file, a "long axle", in AutoDesk Inventor. Does anyone know how to do it? Do I have to modify the .ipt file directly? Or can I just chop off the piece I want to remove from within my .iam file?
Here is a pic of my assembly. I want to "trim off" the part of the long axle that's sticking out on the left top...
thanks
- FTC Team #6389
Unread 23-12-2013, 21:50
mozrila mozrila is offline
AKA: Ben
FTC #3415 (Lancer Robotics)
Team Role: CAD
mozrila is an unknown quantity at this point
Re: [FTC]: Help With AutoDesk Inventor 2012 ?
Under the assemble menu, click "save and replace component". It will then save it as a child of the original .ipt Then you can make whatever edits you want and just save it in a "modified parts" folder in your CAD directory.
Unread 24-12-2013, 10:48
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Yes, you will need to modify the .ipt file directly. Creating your own Tetrix axle file wouldn't be a bad idea so you can more quickly and elegantly modify it the next time a similar situation comes up in future designs.
This appears in the "productivity" menu of the Assembly tab in my installation. Thanks for pointing that out - that's a new one for me.
Unread 26-12-2013, 17:40
FTC #6389
Ok, thanks @nemo and @mozrila.
Now our CAD of our bot is complete. We'd like to create a 360deg "flyover" view of the CAD bot. Is this possible to do in Inventor 2012? We have found tutorials on how to "explode" all the parts out and have them go back together, but none that show how to do a "flyover". Any ideas? Or not possible in Inventor 2012?
thanks again for the help!
- FTC 6389
Unread 26-12-2013, 18:42
echin's Avatar
echin echin is offline
AKA: Eric Chin
FRC #3467 (Windham Windup)
echin is a jewel in the roughechin is a jewel in the roughechin is a jewel in the roughechin is a jewel in the rough
I have never used 2012, but in 2014 you would do it by using Inventor Studio and rendering an animation. Inventor Studio is in the environments tab.
Unread 26-12-2013, 21:30
AKA: Ben
Team Role: CAD
Look into using any of the following:
autodesk 3DS max
autodesk Maya
Autodesk Showcase
Autodesk Inventor Publisher
We use Showcase and Publisher. I am also the designer and animator of these
http://www.youtube.com/watch?v=plFgXn_BuCA
http://www.youtube.com/watch?v=aPQINTKGGAY
http://www.youtube.com/watch?v=T-J3G4m17kE
