Go to Post The FIRST family is incredible. - Libby Ritchie [more]
Unread 16-12-2013, 17:57
michaelwm's Avatar
michaelwm michaelwm is offline
Integrated Systems Lead
AKA: Michael Midura
FRC #4976 (Rebel Robotics)
michaelwm is a jewel in the roughmichaelwm is a jewel in the roughmichaelwm is a jewel in the roughmichaelwm is a jewel in the rough
Smartdashboard is Troublesome
When the code for our robot is first compiled, the SmartDashboard works and displays all the information as needed, most importantly our variable "throttle". However, as soon as we activate the robot, the entire SmartDashboard becomes blank, showing no variables and disallowing me from creating widgets.
code:
SmartDashboard.putNumber("throttle", throttle);
Unread 17-12-2013, 08:57
MichelB's Avatar
MichelB MichelB is offline
Jack Of All Trades
FRC #3941 (Absolute Zero Electricity)
Team Role: Electrical
MichelB is an unknown quantity at this point
Re: Smartdashboard is Troublesome
When we compile and run our code, SmartDashboard won't even open...would you be willing to post your code for others to see?
EDIT: Wow, just noticed you did post part of your code at the bottom. Sorry! Still, would you be willing to post the entire thing? Alos, what version of SmartDashboard are you using and where did you download it from? Any and all info is helpfull. Thanks!!
Unread 19-12-2013, 12:34
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
On the driver station so you have java selected?
Unread 21-12-2013, 18:18
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
A new SmartDashboard is being developed for next season I believe. We should see a lot of improvement
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 23-12-2013, 23:44
MichelB's Avatar
Jack Of All Trades
We've been selecting C++ since thats what our robot code was written in, but now that you mention it, selecting the language SmartDashboard is written in (Java) makes much more sense. Thanks!
Unread 24-12-2013, 10:50
The SmartDashboard is included with the language update for C++ and Java. If you do not have the Workbench update installed on the computer you are using as a DS the SmartDashboard will not launch. You can either install the Workbench update or follow the instructions for using the standalone SmartDashboard installer: http://wpilib.screenstepslive.com/s/...sion-installer
Unread 24-12-2013, 14:55
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
code:
Are you sure you're enabling it in teleop mode? What you're describing sounds like the dashboard going into test mode. Check your teleopPeriodic and autonomousPeriodic, and make sure they don't include this line:
LiveWindow.run();
I code stuff.
Unread 05-01-2014, 13:26
AKA: Brad
#0190 ( Gompei and the Herd)
The driver station buttons just select what directory/program is the dashboard program that the driver station starts. So if you have the java plugins installed on the computer then select "Java" and it will start the dashboard as <userdir>/sunspotfrcsdk/tools/smartdashboard.jar.
Where in your program are you writing the throttle value? Make sure it's somewhere where it's continuously being executed so it will always be sending the current value.
I'm not exactly sure why it's disappearing from the screen unless, as was suggested, you're running in "Test" mode which puts up a different screen on the dashboard. Teleop and Autonomous modes will display on the same screen, so be sure you're updating the value from both of those paths.
Brad
Brad Miller
Robotics Resource Center
