Go to Post If your robot doesn't work, it doesn't matter, because the robot is really meaningless, in the long run. What is the important thing, the reason we're all in FIRST then? To better our understanding of Science and Technology, and hopefully make the world a better place. - Ian W. [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Thread Tools Rating: Thread Rating: 128 votes, 4.89 average. Display Modes
  #631   Spotlight this post!
Unread 25-12-2013, 08:44
RonnyV's Avatar
RonnyV RonnyV is offline
All of the above
AKA: Ron Visser
FRC #4481 (Team Rembrandts)
RonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud of
Re: [FRC Blog] 2014 Game Hint
Originally Posted by Calvin Hartley View Post
I believe somebody earlier in the thread used Wolfram Alpha to do this and got a sphere... I could be wrong though, it may have been something else. Someone please correct me if I'm wrong.
That's correct! Somebody plotted it in Wolfram Alpha and got a sphere.
Somebody else plotted it different. I only saved the link of the attachment not the whole post. But you can see what he did. It forms a rectangle. So the conclusion of the guy was: Triangle, Sphere, Rectangle = 3 game pieces.
Triangle = Coordiantes google maps
Sphere = Wolfram Alpha
Rectangle = His plot
Here is his plot: http://www.chiefdelphi.com/forums/at...5&d=1387644692
  #632   Spotlight this post!
Unread 25-12-2013, 09:27
magnets's Avatar
magnets magnets is offline
Triangle- Any three points will make a triangle, unless it's a line, can be done with random numbers.
Sphere- A single point was plotted on a sphere. The same could be done with any number.
Rectangle- The rectangle was plotted by making a rectangle with dimensions that were the given numbers. Again, any set of three numbers could do this.
What I'm trying to say is that if your game hint solution works with almost every set of three numbers, it might not be the solution.
  #633   Spotlight this post!
Unread 25-12-2013, 09:29
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
If only it was a triangle, circle, rectangle... It would be just like the FIRST logo
The views expressed are mine and should not be construed to represent the views of anyone else.
  #634   Spotlight this post!
Unread 25-12-2013, 09:44
Johnny_5's Avatar
Johnny_5 Johnny_5 is offline
Whose cooking motor?
AKA: Isaac
FRC #3484 (Short Circuit)
Johnny_5 has a spectacular aura aboutJohnny_5 has a spectacular aura about
Originally Posted by zacube View Post
When you Goodle 8234, the first result is a NI part ID. 5761126 comes up with a Digikey part number... Not getting anything on the other two, though, so can't be sure....
Here is something to think about. So I know we can't get very far with that part number. But what if it's similar to the hint from 2 years ago. The hint was a list of donated and purchased components from Rockwell/Allen Bradley. What if the part is in the KoP or on the field?
  #635   Spotlight this post!
Unread 25-12-2013, 10:24
Sorry2 Sorry2 is offline
FRC #0180
Sorry2 is an unknown quantity at this point
Hello all.
Someone earlier said something about "Who's on FIRST?" Being a good game title. And that got me thinking about when it was created. Well, it was in 1938. (Source: http://thenostalgialeague.com/kwtnl/whos-on-first.html and Wikipedia, but I got lazy and didn't look it up again. ) That means that this year is the 75th anniversary. Someone might have hit a home run with that idea! (pun absolutely intended) Sorry if there are any mistakes, I'm on a cell phone.
  #636   Spotlight this post!
Unread 25-12-2013, 10:26
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
First I would like to say that I do not believe there is a weight reduction for this game. In the north, they have weight reductions every spring when the ground thaws so that large trucks do not destroy the roads. We have enough torn up roads just from the freezing and thawing without large semis crushing them. So there are thousands of instances of weight reduction on roads, it is likely a coincident that picture was found.
I was thinking about game piece volume for the 3 numbers. What if there are 3 different sized game pieces and they gave us the volume for them? Those numbers seem pretty specific. Here was a calculation on volume with in^3 converting to the diameter of a sphere in inches:
144.4561403508771929 in^3 = 6.50997 inches (diameter)
31.13907284769211920 in^3 = 3.90333 inches (diameter)
3.943186131848665063 in^3 = 1.96012 inches (diameter)
Now the numbers don't work out to a nice whole number, but maybe the game pieces have dimples or are in a 3D polygon shape. If so, these could be some of the smallest game pieces yet. The ~1.96 in (dia.) is slightly larger than a golf ball.
With the objects being on the smaller side of things, I lean away from a stacking game. Certainly lean away from a shooting game (unless the numbers are the area of the targets). It seems to lean towards a placement game with smaller containers than are customary to past FRC games.
Have a Merry Christmas!
  #637   Spotlight this post!
Unread 25-12-2013, 16:00
Anthony4004's Avatar
Anthony4004 Anthony4004 is offline
Anthony4004
FRC #4004 (MARS Rovers)
Anthony4004 is an unknown quantity at this point
Originally Posted by Sorry2 View Post
Hello all.
I would love this! Mainly because it would give me the right to make everyone watch Abbott and Costello!
  #638   Spotlight this post!
Unread 25-12-2013, 16:25
Jill_ls101's Avatar
Jill_ls101 Jill_ls101 is offline
Band Geek
FRC #1646 (Precision Guessworks)
Jill_ls101 is a splendid one to beholdJill_ls101 is a splendid one to beholdJill_ls101 is a splendid one to beholdJill_ls101 is a splendid one to beholdJill_ls101 is a splendid one to beholdJill_ls101 is a splendid one to behold
Using my Little Orphan Annie Secret Decoder Ring, I have determined that the game hint reads:
"Be sure to drink your Ovaltine"
2009 - 2012 FRC 1747 Harrison Boiler Robotics Student
2012 - 2016 FRC 1646 Precision Guessworks Mentor
2016 - ???? ???????? (Hoping to continue mentoring)
Bringing lasers to IRI Friday Night Entertainment since 2013. www.lasershows101.com
  #639   Spotlight this post!
Unread 25-12-2013, 17:13
Willem Bohrer Willem Bohrer is offline
FRC #4656 (Rock Solid Robotics)
Team Role: Driver
Willem Bohrer is an unknown quantity at this point
8234/57
61126/1963
62326/15806
Fibonacci sequence: 1,2,3,5,8,13,21,34,55,89,134, etc.
Feel free to do what you want with this information. This may be connected to fluid dynamics?
  #640   Spotlight this post!
Unread 25-12-2013, 17:56
Rynocorn's Avatar
Rynocorn Rynocorn is offline
Strategist and Designer
AKA: Ryan Jacobs
FRC #1466 (Webb Robotics)
Rynocorn is on a distinguished road
Someone has been watching TBS today....
My favorite parts: Surgical tubing, Grab catches, churro tubing, and waffle tread.
  #641   Spotlight this post!
Unread 25-12-2013, 21:00
Laser_Shows Laser_Shows is offline
Laser_Shows is an unknown quantity at this point
/begin sarcasm
This means one of two games.
1. Something involving a red ryder bb gun. Oops; this violates the spirit of FIRST so it cannot happen.
2. A football.
My money is on #2.
/end sarcasm
  #642   Spotlight this post!
Unread 25-12-2013, 23:00
Sarakiro's Avatar
Sarakiro Sarakiro is offline
AKA: Rob
FRC #1676 (Pascack ∏-oneers)
Sarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud of
Hi FIRST community,
I will admit that I am usually one to stray away from threads full of mere speculation- Nonetheless, I present some thoughts...
The Game Hint:
The game hint seems to be a series of 3 numbers-
My initial thoughts were coordinates (perhaps defining maximum X, Y and Z field dimension restrictions relative to the point 0,0,0 but the scale seems rather uncommon lest each value is in it's own specific unit [leave it to the GDC to be vague and "justified" in their hints])
My next thought was perhaps a scoring threshold, either pertaining to value or placement of game pieces; that too in my opinion can be denounced for proportions.
Throwing those aside, I look to game trends
Trends:
So here is some speculation of my own-
I don't think a stacking game is so far fetched. One such game I envision has the field strewn with crates (similar in design to milk crates) and numerous (90-200) balls of about 3 inches in diameter.
The objective of the game would be to stack these crates with variable numbers of balls in them, thus scoring points determined by stack size, and ball content.
The complications include dealing with upside down, sideways and irregular crates amongst "herds" of loose balls, the combination of which are difficult to navigate, and difficult to handle provided a versatile range of game pieces.
Alliances would also need to be concerned with defending built stacks.
(FIRST is decently rooted in providing irregular driving conditions; off the top of my head I list Maze Craze, and He-Who-Must-Not-Be-Named (rhymes with "*unacy")
Sorry for ranting,
I guess we know why I try to stay away from these threads,
Robert Sarakin,
Mechanical Division leader 2013-2014,
Disc Acquisition Device (DAD) Leader 2012-2013,
Participant: 2011-2014
  #643   Spotlight this post!
Unread 25-12-2013, 23:08
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
I think you just described the foundation of the 2011? FTC game, Bowled Over Thus the FRC GDC emulates the FTC GDC...
"A genius is just a talented person who does his homework" T. Edison
  #644   Spotlight this post!
Unread 26-12-2013, 14:10
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Originally Posted by tondogone View Post
i dont believe that anyone has plotted them yet like that.
Please read the thread before commenting. Check back several pages, I plotted them in 3D several days ago.
  #645   Spotlight this post!
Unread 26-12-2013, 14:34
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
At risk of sounding like a jerk, but... Did you read the posts following the one you quoted? This was already addressed. Let's try not to be hypocritical. Thanks! (Although we're all guilty of this, I am sure.)
Now let's get back onto the original topic!
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
