Go to Post Once you try hex you'll never go back. - IndySam [more]
Unread 26-12-2013, 17:04
Maximillian's Avatar
Maximillian Maximillian is offline
AKA: Max Westwater
FRC #5254 (HYPE)
Maximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant future
Victor 888 vs Jaguar for rookie drive train
I am the member of a small rookie team. We have about 10 kids on the team. We have decided to go with the Simbotics Kitbot on Steroids for our drive base.
My question is should we use the Victor 888 or Jaguars for our motor controllers?
We get 2 Victors and one Jaguar in our kit of parts. Then we get two more of each with the IFI PDV. If we use Victors we dont have to buy any for our drive train. But if we use Jaguars we have to buy one more controller for the robot.
Sorry if this has already been answered. From what I have read there is no use to the Jaguars unless you use CAN. Due to use being a rookie team I doubt we will end up using CAN anyways so there will be no use for that.
Thanks for the help.
Unread 26-12-2013, 17:06
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Victor 888 vs Jaguar for rookie drive train
Your better off going with Victor 888s. They are very reliable and easy to use.
R.C.
MadTown Robotics Team 1323
Unread 26-12-2013, 17:19
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
Good choice.
I'd hesitate to say one is "best," because they are different products with different feature sets. Which one is better for you depends on what you're looking for in your motor controllers. (Though I agree with R.C.; Victors would probably be a better choice for your rookie team, and most rookies in general.) Some questions to consider for your team:
  • Are you planning on using CANBus or PWM control? (Jaguars can do CANBus or PWM, Victor can only do PWM. Sounds like you're not planning on CAN, and I'd say that's another good choice.)
  • How much is reliability a concern for you? (Victors are considered to be more reliable than the Jaguars, generally speaking.)
  • Is physical size of the controller a concern for you? (Victors are smaller than Jaguars.)
  • How much of a concern is cost for your team? (Victors are $10 cheaper than Jaguars, should you need spares/extra.)
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
Unread 26-12-2013, 17:33
AKA: Max Westwater
FRC #5254 (HYPE)
PWM control. We are trying to keep things simple
It is a very big concern. We are operating on a fairly low budget and also dont want to have to deal with things breaking alot.
not really.
The difference in price of $10 is less of a concern than the fact that we have to buy one Jaguar when we dont have to buy any Victors. I would be more concerned with the reliability of each.
Unread 26-12-2013, 17:35
Free Agent
not really.
Based on your responses, it seems like the Victor is a better option for you and your team.
Unread 26-12-2013, 17:38
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
It seems like there might be a couple misperceptions here. The Kitbot on Steroids was developed with the 2011 kitbot in mind. Since then, the rules restricting robot size have changed (robots are smaller now). Also, the kitbot will be quite different this year from previous years (as per the FRC blog). Most of these changes are for the better, but it does mean that the Kitbot on Steroids isn't necessarily legal for this season and it's features may not directly apply to this years kitbot. However, many of the concepts in KBoS, like the electronics board and changes with the wheels can still likely be adapted to this year's kitbot to help you improve your drive base. It's awesome that you are looking to Kitbot on Steroids for inspiration, just want to make sure you're aware that the exact design isn't necessarily legal for this season.
As for jaguars vs. victors, I agree with RC and Brennon that victor 888's will be the more reliable option for you. However, it's not that there is 'no use' in using jaguars if you don't use CAN. Jaguars will also work on PWM, but they are heavier, have a larger footprint, and are less robust than victors. So the jaguar you get in the kit isn't 'no use' because you choose not to use CAN (I support this choice by the way), but I would suggest that any additional motor controllers you get be victor 888's or talons.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 26-12-2013, 17:52
AKA: Max Westwater
FRC #5254 (HYPE)
Originally Posted by brennonbrimhall View Post
Good choice.
We are aware that the rules according to size will change. We are just using the basic principals of the kitbot on steroids, the wheels, chain drive and 4 motors, in our build. We will adapt those ideas into whatever size there will be for the 2014 season.
As of the motor controllers I am aware that Jaguars can use PWM. We have a loaner bot that we are messing around with and that has 4 Jaguars on it. I was trying to say that one of the main advantages of Jaguars was that you could use CAN, and because we arent doing that it would be logical to use the lighter and smaller Victors.
Unread 26-12-2013, 19:11
nicholsjj's Avatar
nicholsjj nicholsjj is offline
AKA: John Nichols
no team (Devil Bots)
nicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant future
Keep in mind that any assuming of what the rules will be will only make an..well you know. As a rookie team make sure that the first thing you all do after the kickoff and extra videos are over is to . Yes three times is the charm as far as day one is concerned then many more rereads need to be in order.
As far as the motor controllers go I would recommend the 888s. They are very reliable and from our team's past experience they have been more robust than the jags. Some examples of this would be PWM's falling out on jags and not 888's as well as exposure to metal shavings and overheating have occurred more often to our jags. The only problem our team ever had with the 888's was when we didn't set the PWM cable into the port correctly.
2011-FRC Team 3862, Team Captain
2012-FRC Team 3862, Strategy Mentor
2013-FRC Team 3885, Programming Mentor, Razorback Regional, Curie Inspector
2014- FRC Team 3885, Programming Mentor, Arkansas Regional, Newton inspector
2015-??? Teacher Murphysboro High School
“They call it coaching but it is teaching. You do not just tell them…you show them the reasons.”- V. Lombardi
Unread 26-12-2013, 19:19
Kernaghan's Avatar
Kernaghan Kernaghan is offline
Technical and Driver
FRC #4814 (United Robotics team of London)
Kernaghan is on a distinguished road
Victor 888: the rookies best friend! We used them this year on our drive and loved them, the Victor is also smaller from a mounting point of view than the Jaguar, making it easier to fit everything as rookies. Apparently the Victor is also used in some cases for battle robots, if they can count on them for that then they must be doing somthing right.
______Team 4814______
"Linking London Together"
_________URL_________
Unread 26-12-2013, 19:32
yash101 yash101 is offline
AKA: null
As Brennon pointed out, you may like the victors. They are a great choice. However, if you get good funding (because you are a rookie team), you may want to give talons a try. It works exactly the same as victors (even the wiring) but is sealed, so you won't have to worry as much as debris getting inside the holes, damaging the controller
I think that victors are the best for rookies because PWM is a very easy-to-use motor communications protocol. You probably will have access to only one cRIO, so the team will be cramped trying to use it for educational purposes. With PWM, you could easily use an Arduino or Propeller, etc. That way, you could prototype an application by yourself while another person can be using the cRIO or another controller.
I really like how easy it is to use PWM. However, this would be one-sided because I haven't played much with CAN!
However, if I am not wrong (and please correct me if I am), you can have more motor controllers on the CAN but than you can have PWM connections. That will allow you to have more complex mechanisms! There is the problem that it is hard to get enough Digital I/O pins.
"Pins, pins and pins...what microcontrollers need more of"
Check out this thread
Unread 26-12-2013, 19:38
Originally Posted by nicholsjj View Post
Some examples of this would be PWM's falling out on jags...
Even with the PWM cable properly secured in the cable retainer??
My understanding is that the VEX Jag PCBs are are conformally coated.
Name:	Jag cable retainer.png
Unread 26-12-2013, 19:57
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
I've always been a fan of Jaguars due to easy for rookies to use (not calibration, easy to stick the pwm cables in). Just my $.02
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 26-12-2013, 20:49
ronbaer ronbaer is offline
FRC #0612 (Chantilly Robotics)
ronbaer is an unknown quantity at this point
Concur with the choice of Victor 888s vice Jags for simple motor controller. Jags are best used for CAN control and sensor integration (ie plugging sensors directly into the Jag).
Limit switches is a great use for Jags. Limit switches can be connected directly into a Jag. When the switch is pressed while the motor is moving in its direction, the Jag stops the motor, independent of the cRio software control. This is a good safety control when going beyond the limit switch can damage the robot wiring, etc. This limit switch mode works in both CAN and PWM control setups.
Jags can also accept encoder and pot inputs and can provide that data to the cRio via CAN control. There is also the automated feedback loop control.
Ron Baer
Team 612 - Chantilly Robotics
Unread 26-12-2013, 21:01
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Besides reliability and price, another great thing about Victors is that they have a much smaller footprint than Jags. Especially since the robot size has been reduced in FRC last year, teams are struggling to find room for electronics (especially young teams like yours and mine). The victors are a huge help for this.
Robo Hamsters Robo Hamsters is offline
AKA: Matthew Vesperman
FRC #4466 (Robo Hamsters)
Robo Hamsters is on a distinguished road
We found the Victors to be more reliable than the Jags, but as was mentioned, the Jags are great when you need to use limit switches.
Also, you may want to look at the IFI PDV more closely. You will get to choose one of the following options:
  • Two Jags
  • Two Victors
  • One Jag & One Victor
The IFI PDV doesn't allow you to get two more of each.
As far as drive train goes we used the Victors on our bot last year and they worked great. Controlled the motors well and we had no issues with failure of drop outs of any kind.
Good luck this year. If you need any help don't hesitate to ask. The folks here are a great resource for a rookie team.
FRC 4466
FTC 7042
2013 Washington DC Regional Finalist
