Go to Post I will gladly be pied if that's something you guys want. I know I have people from the Clarkson FIRST dorm floor who will shell out PLENTY of cash for the chance to pie me in the face! - Libby K [more]
Unread 23-12-2013, 11:18
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Re: Modular Drive System
Originally Posted by MrBasse View Post
...as these modules as pictured wouldn't be up to the task of FRC in my opinion.
MrBasse,
Could you say what about the design you think is weak?
Thanks
Unread 23-12-2013, 13:51
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Originally Posted by DavisDad View Post
MrBasse,
Thanks
I don't think the design itself is weak, simply that the current version posted would be up for quite a task. I have no clue as to speed, but I would be concerned with the gearboxes (we have found planetariums to be a tad fragile) in a pushing match. An open frame with little structure to tie the front end together would have me concerned as well for impact, but I think with the scale of your frame rigidity shouldn't be much of an issue. Again, these are simply in the prototype you have proposed. I haven't a clue what this could delvelop into when built for FRC. I am excited to see what it could become, as a modular approach is something we have been contemplating for our entire history in FRC.
Beyond that, it's a tiny little thing! Sure does make the battery look massive! (I know it is a prototype!)
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 23-12-2013, 14:09
DavisDad's Avatar
MechE
I guess my post is unclear. The prototype is the FTC team. We're scaling up for FRC. The FRC battery was used to add weight to simulate future game components. The open frame was min structure for testing drive performance
Unread 23-12-2013, 14:33
No you are good with your clarity. But only having smaller scale design to base my opinion on, I simply pointed out my concerns. I think this has great promise and am excited to see what the FRC scale version is capable of.
Andrew Basse
Unread 25-12-2013, 15:57
DavisDad's Avatar
MechE
Unread 25-12-2013, 16:00
magnets's Avatar
magnets magnets is offline
This is cool, but I'm worried about the thrust loads the shaft on the CIM will receive. It's been a while since I've taken a CIM motor apart, but I'm pretty sure you don't want to be loading the shaft like that. If you placed some spacers on the CIM shaft so that any downward load on the shaft would be transferred to the plate the CIM is mounted on, you'd probably be better off.
Unread 25-12-2013, 16:06
DavisDad's Avatar
MechE
Hey Magnets,
Yea, there are still some loose ends on the design. I need to check the thrust load specs for "deep groove" ball bearings. If they can handle the loads, the gear will butt against the inner race; otherwise we'll have to use thrust bearings. I didn't fix the gap between pinion and bearing yet.
Unread 26-12-2013, 22:53
DavisDad's Avatar
MechE
Had to move planetary gear set outside wheel...
Unread 26-12-2013, 23:04
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
This might be useful for you guys...
http://www.andymark.com/product-p/am-2622.htm
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 27-12-2013, 09:58
DavisDad's Avatar
MechE
Hey geomapguy,
Thanks for the AM suggestion. I looked at that, but want to optimize for FRC space and function. And, I'm learing about gearing; this is my first time building a gearbox. We may end up using a COT as the designs so far are more complex than I'd hoped. I haven't received the Matex planetary gear set (pic & link below) and need to determine the shafting requirements for alignment and loading.
Also, to use the CIM with the AM planetary set, you have to trim the motor shaft 1/4". Is modifying the shaft FRC legal?
PN: 75-5MLD
The 5:1 ratio units I ordered cost $73 ea
Unread 28-12-2013, 06:19
DavisDad's Avatar
MechE
Progress update:
I've got 3 designs roughed out:
  1. Planetary 5:1 reducer located in the Mecanum hub. I was excited about this when I found this video: e-Bike Hub Motor I immediately thought of the Sturmey-Archer 3-speed bikes of my youth. I got an old unit from my local bike shop's junk bin and thought I had a cheap source for the planetary set. The design I've sketched requires pretty complicated shafting and I'm doubtful about putting the planetary at the end of the gear train (shock stresses). the current design requires disassembly of the Mecanum to access the planetary set Also, I envision an oil dip system for lubrication and expect this to be a problem in the hub.
  2. Move the planetary set outside hub but on wheel axis. This has the same issues with gear tooth stresses.
  3. Move the planetary set to motor shaft and integrate into one gearbox with the 3:1 bevel gear set. AM has a COT setup for this, as geomapguy pointed out: AM COT
I haven't totally given up on the gear-hub idea. I'm waiting for the Matex set to arrive. When I get it in my hands and get a better feel of mounting/shafting requirements, I'll know better how to proceed...
Unread 28-12-2013, 14:54
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Yeah it's legal.
Modifying the shaft and removing the window motor locking pins are the only legal modifications you can make to a motor.
Unread 29-12-2013, 12:03
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Yeah it's legal.
Obligatory disclaimer that the relevant rules can change for the upcoming season.
Unread 29-12-2013, 13:51
DavisDad's Avatar
MechE
Thanks geomapguy and cgmv123 for your replies.
I think we'll go this route; planetary in-line w/ motor and 90 deg bevel set to wheel. This is much simpler than the previous designs.
Unread 29-12-2013, 15:53
DavisDad's Avatar
MechE
My son and I made these movies (links below) to show Mecanum with speed control. This is the FTC teams prototype; not FRC. This is the design from which we're scaling up.
