Go to Post We don't have to reinvent the wheel every year. (We have AndyMark to do that for us.) - GaryVoshol [more]
Unread 27-12-2013, 09:14
Mike Ounsworth's Avatar
Mike Ounsworth Mike Ounsworth is offline
Roboticist
FRC #3710 (Cyber Falcons)
Mike Ounsworth is a jewel in the roughMike Ounsworth is a jewel in the roughMike Ounsworth is a jewel in the rough
3V3 digital signal to the cRIO
I am using a Raspberry Pi to send a digital I/O to the cRIO. I know that the Pi uses 3.3V (3V3) for a True, while the cRIO expects a 5V signal.
I know that with some combinations of hardware this is fine, and others cause problems. Does anyone know about the Raspberry Pi / cRIO combination?
(Note and warning: I know that putting a 5V signal into the Pi will fry it, I'm asking about the Pi --> cRIO direction.)
I am doing graduate work on autonomous aerial and underwater vehicles with McGill University's Mobile Robotics Lab.
I have been Lead Programming Mentor with Teams 296 and 3710, as well as Head Mentor for 2 years at 3710.
Unread 27-12-2013, 11:13
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Re: 3V3 digital signal to the cRIO
Like you have said, and others have tried, running a 3V3 signal into the cRIO will not trigger a logic high for the cRIO. You must use some type of logic level converter(LLC) to perform the task you are desiring. (3V3-->5V)
Picking the proper LLC depends on the frequency of switching that your application requires as well as the type of signal you are running (i.e is it bidirectional or not). However, without knowing this, I can at least point you in the right direction to start looking...
Sparkfun Electronics sells a cheap LLC board that is run off of the BSS138 Transistor. It should work for you, and has worked for other teams
Link to Board
Link to Schematic
Link to Transistor Datasheet
Also, here is a relevant thread from last year: http://www.chiefdelphi.com/forums/sh...d.php?t=101407
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 27-12-2013, 12:21
The 14 DIO on the digital sidecar are connected to the NI 9403 digital module, which specifies 5v TTL. a 5v TTL input is compatible with 3.3v CMOS output. Vih for 5v TTL is 2v, while Voh for 3.3v CMOS is 2.4v. There is reduced margin, but it was designed to work. I have not tried it, however. Sparkfun has a nice tutorial on logic levels: https://learn.sparkfun.com/tutorials...s/introduction. However, because the digital sidecar has a 5v pullup, you should not connect them to the Raspberry Pi, but could be used with 5v tolerant 3.3v logic.
I could not quickly find a spec on the DIO for the Raspberry Pi, so you would have to make sure it conforms to 3.3v CMOS logic levels.
Other signals on the digital sidecar do not go directly to the 9403 and would have to be evaluated independently (like I2C).
Do you have another example besides that thread? It sounds like the problem was not powering the IMU from the right power source, rather then a logic conversion problem.
Unread 27-12-2013, 13:40
yash101 yash101 is offline
AKA: null
I would say, if you have a two way connection with one direction per line, the RPi tx can be directly connected to the rx on the crio. However, you would need a resistor in the rx of the pi. Are you using i2C or SPI, etc? I use a 5v UART connection with my pi to access terminal via serial.
5v requires 2v5 to register a 1.
Unread 27-12-2013, 16:13
magnets's Avatar
magnets magnets is offline
Not quite. You only need 2 volts for TTL to read high, which is a zero, not a one on the cRIO.
Unread 27-12-2013, 16:17
correct
Where did you get that information?
Unread 27-12-2013, 16:22
magnets's Avatar
Originally Posted by Joe Ross View Post
correct
I can't find it in any documentation, but I just remembered this, and thinking it was counterintuitive.
Unread 27-12-2013, 17:00
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
If all else fails you could always make up a converter with any open collector transistor. Off the top of my head a MPSA14 or MPSA13 would work very nice to change the 3.3 to 5 volt. All you need is to drive the base with the 3.3 logic and then use a 4.7K pullup to cRIO 5 volts on the collector. Be sure to use a common ground between the PI and cRIO.
Unread 27-12-2013, 17:23
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
You actually DO NOT want to directly connect a pin on the Pi to a pin on the Sidecar. The sidecar has an internal pullup to 5V in it. Putting that 5V to the Pi could destroy the Pi. Either a Pull down, voltage divider, or logic converter would be needed in order to protect the Pi. The CRIO can take up to i think 24v on an input, so no need to worry about damaging the CRIO at the levels you are using.
That 5V comes from the Sidecar even if it is set as an input, so it needs to be worked out even if the CRIO is set as input.
Team 4488 - Mentor 2013-2016
Unread 27-12-2013, 20:01
AKA: null
That could be true. I am kind of comparing to the BASIC stamp which has 5v I/O. Just stay safe and buy a cheap level shifter. $5 could save you from buying more $35 RPis, so being safe-than-sorry would also be the cheaper way in this case.
Is that true that the pin is held up? That reduces some of the nightmares I have, about limit switches having the pins floating, so thanks
Unread 27-12-2013, 20:06
Yeah they include a 10k Pullup to 5V inside the sidecar.
Here's the schematic.
http://www.usfirst.org/uploadedFiles...matic%20v7.pdf
Unread 27-12-2013, 20:24
FRC #1514
Thank you sst_thad I forgot about the 10K inside the sidecar. Using the MPSA transistor will work just fine in an open collector configuration to change the Pi 3.3 V to the cRIO 5 V level.
Just as a side note, I have a 5 volt micro computer stand alone system that is used to drive an 'H' bridge that runs at 24 volts with no problems handling the two voltages.
As long as you use the transistor between the Pi and Digital side car no problem as the transistor will act as the buffer between the two.
Unread 27-12-2013, 20:38
AKA: null
Are you talking about this excerpt (attached below)? It shows a set of pull-up resistors connected to the I/O.
Name:	Screen Shot 2013-12-27 at 6.36.23 PM.png
Unread 27-12-2013, 20:55
FRC #1514
That's the one and you are interested in the GPIO [1-14] as they are the digital inputs on J26 for the Rev 7 digital sidecar. You made me pull out my book.
Unread 27-12-2013, 21:27
FRC #1514
Here is section of my ‘H’ bridge that is driven by TTL 5 volt logic and then will either source B+ (24 volts) or sink the 24 volts.
The TTL control signals are on the right hand side and called;
COL3 when logic high will source B+ (24 volts) through Q11 (TIP127)
With the help of Q33 (MPSA14) that is used an a inverted in this case.
COL3’ when logic high will sink the B+ through Q22 (TIP122)
Just a side note here, NEVER put a logic high on both COL3 and COL3’ at the same time as it will create a short from B+ to ground and blow the fuse F11.
For your application all you need is COL3 (Output from PI) R22 (220ohm) R55 (1K) and Q33 (MPSA14). The point where Q33 connects to R33 is not needed but instead would go GPIO [1-14] on the digital side card.
So just three parts and your Pi can talk to your cRIO. I am sure there is a I/C chip that will also work but I don’t have my data books handy.
If you need more help just ask.
The other picture is the actual boards in the project.
Name:	H bridge section.JPG
ID:	15665  Click image for larger version
