Go to Post 3 weeks vacation here...every single day devoted to volunteering for FIRST. Am I crazy? Yes...I am most definately crazy...but crazy has never been this much fun. - Andy Grady [more]
Unread 28-12-2013, 08:39
magnets's Avatar
magnets magnets is offline
Re: Gearbox friction model
Originally Posted by DampRobot View Post
I usually use these (highly inaccurate) estimates, based a little on research, and a little on experience:
Belt reductions: about .98 efficient
Gear reductions: about .95 efficient
Chain reductions: about .90 efficient
Planetary reductions: about .8 efficient
Single lead worm reductions about .6 efficient
These are great numbers for design, and I use about the same numbers when I do design estimates. However, if you'd like to get more accurate, you'll need to actually build the thing and do some testing. You'll notice some strange stuff. We saw that we were most inefficient with low loads, and most efficient with medium loads. Lubrication and accurate machining and placement of gears, belts, and pulleys really makes a difference. Another thing that we found interesting was that the efficiency changes a lot with time. When we started our shooter (it used a "hack" 1:1 banebots p60), it was around 2800 rpm. After 1 minute, it was up to 3400 rpm, and after three more minutes it went to 3100 rpm.
Unread 28-12-2013, 09:34
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Yeah those numbers look accurate enough for my estimates (either .81 for everything or the separate ones), I'm not doing any rocket science.
