Re: Gearbox friction model
This is where you use efficiency:
OutputTorque = Efficiency*InputTorque*GR Speed is indirectly affected by efficiency since the % of max torque will be higher in an inefficient system, which slows the motor speed. This is how you calculate it: InputTorque = OutputTorque/(Efficiency*GR) %Torque = InputTorque/StallTorque OutputSpeed = (1-%Torque)*FreeSpeed Using a blanket fudge factor isn't going to behave properly, particularly if your % of max torque is high. |
Doesn't your OutputSpeed equation not factor in efficiency at all?
OutputSpeed = (1 - %Torque) * FreeSpeed OutputSpeed = (1 - InputTorque/StallTorque) * FreeSpeed InputTorque is the variable you multiply by efficiency to get OutputTorque - i.e. torque before efficiency is factored in. At a system's free speed, the InputTorque would only be enough torque to overcome kinetic friction in the system (no external load). It's very possible I'm misunderstanding. |
If you think about what is going on in a gearbox, it can help you with the model immensely.
With planetary and spur gears, the teeth of the gear are ment to roll relative to one another. The better the tooth, the lower the friction. This rolling will have some friction which will be proportional to load, and thus a simple efficiency factor works well espeically for moderate torques. Speeds are merely a function of the ratio. Thus output torque=eff*input torque*gear_ratio Outputspeed=inputspeed/gear_ratio While this model works pretty well, as other have pointed out, it falls apart towards "top speed". IE, if my motor has a free speed of 15,000 rpm and my planetary gearbox has a ratio on 3:1, why doesn't my gearbox freespeed = 5,000 rpm? Instead I get about 4,000 rpm! So the other element tends to be drag. For example when riding a bicycle, you have to overcome the grade, rolling resistance, and wind resistance. On a still day, on flat ground, the initial torque is dependent on acceleration and rolling resistance, but as you speed up, wind resistance becomes a bigger factor. For gearboxes, the "wind resistance" is often the oil or grease in the gearbox. These drag forces tend to have a torque to speed relationship of: drag torque = C*speed^2 with C being a constant. C is a combination of the thickness of the grease and bearings and....It is often temperature sensitive for many gearboxes. A good way to get a value for this is to measure motor free speed, then motor gearbox free speed. Use the gear ratio and motor curve to find the torque for that speed, and then... Set dragT=c*speed^2 For your model, you will then have: Torque out=eff*ratio*input_torqu-c*speed^2 If you use this method, and have the ability to measure stall torque, I think you can make a very accurate model, and you will likely see a much better efficiency number than using the other methods. For instance in high power oiled gearboxes, we might use as little a 1%-1.5% efficiency loss per gear mesh and 0.1% to 0.15% for bearings. Of course, this is with gearboxes with really good gear geometry, properly weighted oils, and high quality bearings. Overloaded gears, bushings, bearings, and really thick greases tend to perform at lower efficiencies with higher "windage", but they tend to work pretty good for FRC. |
I will need to think about that one a bit more, and how it would effect an acceleration model. |
I will have to look into other acceleration models to see what all they have, and how to do some simple test in order to get an accurate model of what is going on.
It would be really neat to come up with a VI or something similar that could be run with an FRC robot and output some parameters. |
#8
Scenario1: 1) put the robot up on blocks, so there is no external torque load on the drivetrain. 2) apply enough voltage to the motors to get them moving 3) slowly reduce the voltage to the lowest value that still sustains a constant (very slow) speed. Since the wheels are not accelerating, there is no net torque on the wheels. For Scenario1 I assert the following: A) at that same voltage, a free motor (i.e. motor not connected to gearbox and drivetrain) would be spinning faster and drawing less current. In other words, the motors in the drivetrain are producing torque... but that torque gets lost through the friction of the gearbox and drivetrain. B) using the model: wheel_torque=eff*ratio*motor_torque- (Kro+Krv*speed) ... with wheel_torque = 0 and wheel_speed ~ 0, you get: motor_torque = Kro/(eff*ratio) ... which allows you to choose a value for Kro which reflects the real-world situation that the motor_torque is not zero under these conditions. C) This effect can be non-negligible for a poorly-built drivetrain (chains/belts too tight; misalignment; inadequate lubrication, etc). D) since the net wheel_torque is zero and the wheel_speed ~0, the model: wheel_torque=eff*ratio*motor_torque-c*speed^2 ... says the motor_torque is ~zero, which does not allow the model to take into account the losses mentioned above. Scenario2: Same as Scenario1, except place the robot on a straight, flat, level, carpeted surface For Scenario2 I assert the following: A) The motor current (and thus torque) will be even higher than in Scenario1. B) The reason is the extra losses due to rolling resistance (carpet compression) plus additional work done on the carpet due to misalignment of the wheels (or in the case of mec or omni, the stretching of the carpet due to the sideways component of the reaction force of the roller on the carpet. C) These extra losses will include a constant term (which can be added to Kro) and a speed dependent term. Whether the speed dependent term is better approximated as linear or quadratic I do not know at this point. Last edited by Ether : 30-12-2013 at 19:49. |
#9
