Go to Post Taking some parts from an old robot isn't cheap, it's like adding a piece with more experience to the new robot. - Marcel [more]
Unread 27-12-2013, 23:55
nuttle nuttle is offline
AKA: Allen Nuttle
FRC #4080
nuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud of
Re: 3V3 digital signal to the cRIO
A couple of other possibilities:
-- Use an analog input, instead of a digital one (via the analog breakout board, I mention this mainly in case someone comes along, reads this, and wants something easy and quick)
-- Use an opto-isolator (this not only level shifts, but avoids potential problems with ground loops -- you probably don't need to worry about this, but it is very good to be aware of and on the lookout for this type of problem)
Unread 28-12-2013, 00:05
foote stepped in
AKA: E. Foote
FRC #0868
Quoting this because I'd recommend it in most generic situations.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 28-12-2013, 02:10
yash101 yash101 is offline
AKA: null
An opto-isolator is a splendid idea that will almost always work. Why did someone not already bring it up?!?! Kudos to you .
Using an analog signal would be getting a little off from what we want here. For something like the raspberry pi or propeller would be hard to interface with a DAC/ADC couple. On the RPi, I don't know if you'd even have enough GPIO!
Unread 28-12-2013, 08:34
magnets's Avatar
magnets magnets is offline
I think the idea behind the analog inputs is to use the analog module on the cRIO because it doesn't have a pull up resistor like the digital ones do. You can make the analog input behave like a digital input and return true if the voltage is above 2v, and false if it is below, without having to worry about the pullup resistor to 5v.
Unread 28-12-2013, 12:23
AKA: null
Ah. I get it. However, that seems a little complicated because you will need to craft the code to emulate DI/O. I'm just wondering but has anyone succeeded in using the analog communications with the Jags?
Unread 28-12-2013, 12:55
magnets's Avatar
The code? Easy- Replace the 2 with any voltage you need.
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.AnalogChannel;
public class AnalogAsDigital {
    AnalogChannel analogInput;
    public AnalogAsDigital(int channel){
        analogInput = new AnalogChannel(channel);
    public double getAnalog(){
        return analogInput.getVoltage();
    public boolean getDigital(){
        return analogInput.getVoltage() < 2;
As for the analog on the jaguar, you can use a gyro/other analog sensor if the output is 0 to 3 V, or any type of potentiometer or variable resistor.
From the datasheet
Analog Input
The analog input accepts a 0-3 V sensor signal for implementing position control mode. Position control can
also be implemented with a single- or multi-turn potentiometer. Potentiometers with continuous rotation are not
supported. The Jaguar contains a built-in bias pin for use with 10kΩ potentiometers. If another potentiometer
value or analog source is used, it must have a 0-3 V range.
If the P, I, and D parameters are positive (or zero), the Jaguar expects that a forward condition (+ voltage on
White terminal, - voltage on Green) will generate an increasing voltage on the analog input.
White terminal, - voltage on Green) will generate a decreasing voltage on the analog input.
The analog input is not electrically isolated.
Table 5 on page 6 lists the electrical requirements of an external control signal.
Unread 29-12-2013, 18:01
steinra's Avatar
steinra steinra is offline
(KG7KEO)
AKA: Randy Steiner
FRC #5461 (V.E.R.N.)
steinra is on a distinguished road
I guess I want to take a step back and ask the intent.
Are you simulating digital input to test programing on the cRio, or are you using it to pass information the Pi has already determined to the cRio to take action?
I ask because if you are looking to pass information it may be much easier to use i2c if you don't want to use hub points on the radio, or just pass the data between the two on an ethernet connection (UDP or TCP).
But if you are looking to simulate other sensor data then the other discussions here definitely apply. I would look at the logic level shifters from spark fun. That would be the safe way to do it.
Randy Steiner
2014-2015 FIRST Team 5461 - Coach
2011-2014 FIRST Team 4106 - Head Mentor
2007-2011 FIRST Team 1891 - Mentor
Unread 30-12-2013, 14:34
AKA: null
Network isn't the best approach when you want to get the newest data with the least delay. Also, if you are processing a sensor a thousand times a second, offboard, you want a very fast and reliable connection. While ethernet can get close, it isn't exactly the "best" way to go!
It is also relatively easy to code i2C on the Pi compared to another technology because of the libraries out there and the documentation that they have!
