Go to Post What isn't fun about watching a robot hang tubes? I love watching my team do it! - Michael Corsetto [more]
Go Back   Chief Delphi > Technical > CAD
Unread 08-05-2013, 19:38
sconybeare sconybeare is offline
FRC #0694
sconybeare is an unknown quantity at this point
G-code
For those teams that use CNC stuff to make parts: how do you generate the g code? What software do you use?
Unread 08-05-2013, 19:49
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: G-code
We have been quite happy with OneCNC. HSMWorks looks good too.
Unread 28-12-2013, 18:36
theCADguy's Avatar
theCADguy theCADguy is offline
Design Team Student Leader
AKA: Sean Gibbons
FRC #0020 (The Rocketeers)
Team Role: CAD
theCADguy has a spectacular aura abouttheCADguy has a spectacular aura about
Re: G-code
MasterCam works fairly well.
http://www.mastercam.com/
Unread 29-12-2013, 00:57
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: G-code
What CAD program are you using?
If Solidworks or Inventor you should probably be using HSMWorks (free!) unless you have mentors that are experienced with an alternate CAM package.
I personally like MasterCAM as I've taken multiple classes using it. It has a bit of a learning curve though. You really can't just jump into it and be productive like you can with some of the integrated into your CAD package programs.
2001-2004: Team 100
2006-Present: Team 254
Unread 29-12-2013, 12:29
DonRotolo's Avatar
Back to humble
FRC #0832
Re: G-code
It also depends on your CNC machine: A CNC router (generally) needs only 2.5D, while a Mill with a 4th axis would want more dimensions. The programs that generate G-Code differ wildly in price, and often have different capabilities.
HSMWorks is free, and works with both SolidWorks and Inventor.
A program called Cut2D is a good choice for 2.5D, but costs $150. The same company (Vectrics) makes other programs that are all good.
MasterCam is the gold standard IMHO, but its price is high.
Note: You can also write G-Code by hand! Like knowing how to deal with a dot prompt (Linux) or > prompt (DOS), it can be helpful to know this. For complex shapes you probably would go with automatic code generation, but you can make simple stuff by hand, as well as understand the generated code.
