Go to Post It's just another design constraint that needs to be dealt with. - Dave Scheck [more]
Unread 29-12-2013, 18:21
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
pic: SimpleChassis
Unread 29-12-2013, 18:22
Andrew Lawrence
Posts: n/a
Re: pic: SimpleChassis
If this is for low resource teams, what advantage does this have over the kitbot, or any of the other COTS drivebases out there?
Unread 29-12-2013, 18:53
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
I don't wanna speak for the designer, but one of the immediate 'advantages' I see of this, not necessarily as opposed to the kitbot, but other COTS drivebases, is that I'm sure, aside from transmissions/motors/wheels, this could be built for <$75 with stuff that can be bought on a single trip to Home Depot
Unread 29-12-2013, 18:58
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
The brackets used for the eyebolt tensioning system are a little funky. Where would you source those?
--Madison--
...down at the Ozdust!
Unread 29-12-2013, 19:02
markmcgary's Avatar
markmcgary markmcgary is offline
Software Mentor
FRC #4322 (Clockwork Oranges)
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
I think the CAD rendering is a little funky. Double images on the outside wheels and the eyebolts.
Unread 29-12-2013, 19:05
Andrew Lawrence
Posts: n/a
I'm looking more at the slots that need to be machined and precise manual hole drilling that most low resource teams won't be able to do.
Unread 29-12-2013, 19:22
Pault's Avatar
Yep, and gearboxes etc can be recycled. You could even say it has this advantage over the kitbot, because you could just get the $450 Andymark voucher instead.
Also, some teams may have opted out of the kitbot, and since then realized that they really needed it. I know that my team thought we were going to be a lot better off this than we actually are, especially in terms of CAD resources.
And, some people may just not like the kitbot. Especially this year when we don't know what to expect. So this would be a good alternative for those people, just like the COTs drivebases.
Last year we machined a very similar chassis with mainly a band saw and a drill press. The slots were made with a dremel and worked fine (although this year we are probably going to make them with our manual mill that we finally learned how to use).
Those are just 2 1in piece of angle aluminum.
The wheels aren't a problem with the render. We had double wheels, 1 on either extreme of the chain tensioning, and I forgot to hide one.
Unread 29-12-2013, 19:23
Chris is me's Avatar
AKA: Pinecone
What precise drilling? There's slots in the L-bracket for the wheels which can easily be done on any mill, and everything else seems quite doable by hand. No exact centers or anything here. Looks super cheap to make and uses the bumpers for strength. I don't see this drivetrain as something you can easily dismiss as inferior to COTS options.
Unread 29-12-2013, 19:43
Madison's Avatar
FRC #0488 (Xbot)
Ah. This is a time when including hardware in your model would be helpful.
--Madison--
Unread 29-12-2013, 19:47
markmcgary's Avatar
Software Mentor
Yeah. After my post I realized that you probably were showing both the 'tensioned' and the 'un-tensioned' positions. Thanks for sharing this design.
Unread 29-12-2013, 20:29
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
Very nice design. Looks like an afternoon project for 1 or 2 people. The chain tensioning set up I have used for many projects and while it does looks crude it works great. GRT has used eye bolts many times. I would add a cross brace at the top but that is my preference. This design would give a team a cheap practice chassis and one to test mechanisms on and save the kit chassis for later if they wanted to. Good work.
KF6UZX
Unread 29-12-2013, 21:02
Kernaghan's Avatar
Kernaghan Kernaghan is offline
Technical and Driver
FRC #4814 (United Robotics team of London)
Kernaghan is on a distinguished road
Quick Question - Where is the cross strength going to come from? If all of the force is going to that wooden board, where the electronics are ideally mounted, that might not make a pretty sight.
Looks nice though, great way to practice CAD!
______Team 4814______
"Linking London Together"
_________URL_________
Unread 29-12-2013, 21:45
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Their team name fits this very well .
Also, when the new rules come out, check if those corners are compliant with the bumper rules. Other than that it looks great.
Unread 30-12-2013, 11:12
Pault's Avatar
The bumpers! While the plywood board gives the chassis strength again parallelograming and other stresses parallel to the ground, the bumbers provide great resistance to any forces perpendicular to the ground.
When we first built our chassis last year, we tried driving it around without bumpers. Like you said, it was not a pretty sight.
What exactly might be wrong with the bumper corners? I don't see anything wrong.
Unread 30-12-2013, 12:09
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Offset the transmission closer together. The main shaft needs to extend so a pulley can be attached outside the plate. This makes it easier to attach a belt without having to take the transmission apart to install/replace the belt.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
