Go to Post My advice is anytime your intuition tells you something, double check it with physics. - tennispro9911 [more]
Unread 29-12-2013, 22:39
Yannick B Yannick B is offline
FRC #2994 (ASTECHZ)
Team Role: CAD
Yannick B is an unknown quantity at this point
8 wheel Drive Train
As a pre-season project, a friend and I took on the challenge to design a versatile drive train our team could use and modify for future years.
It was decided the drive train would have to meet certain requirements, including 8 wheels, a direct drive custom two speed gearbox, belts and versatile.
The outcome of these decisions produced a drive train that looked like this:
The specification of the drive train is as follows:
• 8 wheel drive
• Pneumatic wheels
• Two speed Custom shifting Gearbox
• Belt drive
• 0.064 in thick aluminium frame
• Mountings for other components
• Interchangeable wheels and shafts
• Width: 26.25 in, Length: 28.13
• Weight: 54 lbs
• Perimeter: 108.76 in
• Speeds: low gear: 7.3 ft/s, high gear: 16.7 ft/s
The frame was designed using Solidworks, and a Mastersketch was used as a base to allow us to modify the frame with ease.
The custom gearbox was designed so the two centre wheels would be directly driven, meaning if the belts or the chains on the frame broke, it would always have 4 wheel drive.
Name:	Gearbox Render.JPG
The gearbox was made from a VexPro ball shifter modified to fit our needs.
If you have any questions, please feel free to ask and I will try my best to answer all of them!
Yannick,
Co-Captain, Team 2994
Unread 29-12-2013, 22:46
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Re: 8 wheel Drive Train
Very nice, looks (and is) heavy though.
Unread 29-12-2013, 23:12
julianpowell julianpowell is offline
FRC #2928 (Viking Robotics)
julianpowell will become famous soon enoughjulianpowell will become famous soon enough
Why pneumatic wheels?
Unread 29-12-2013, 23:28
OWilliamson's Avatar
OWilliamson OWilliamson is offline
FRC #2594 (NASKCO)
OWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of light
Just out of curiosity, how much does that gearbox weigh?
2015: Utah Regional - Quarter-Finalists (3374 & 4158)
2014: Utah Regional - Semi-Finalists (1619 & 399)
2013: Utah Regional - Quarter-Finalists (1332 & 3562)
2012: Utah Regional
Unread 29-12-2013, 23:37
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
It looks like a very nice design!
Two comments on the gearbox plates:
-If machining, you will need some internal fillets on the corners for the mill. Even if you are using a water jet, fillets will reduce the Kt of the stress concentrations in the plates.
-The thickness around the bearings may need to be increased for press fit, otherwise the press load could tear the metal/material.
I really like the gearbox incorporation into center 4 wheels. The Enginerds (2337) did a similar approach last year and had a very robust drivetrain.
Unread 30-12-2013, 11:34
FRC #2994 (ASTECHZ)
Team Role: CAD
Bryce Paputa, yes it is a heavy frame at the moment, but 54 pounds does include motor controllers, PD board, CRIO, router and a basic pneumatic system (not shown in the picture). We will be looking for ways to reduce the weight in the future.
julianpowell, we decided to use pneumatic wheels for two reasons, tractions and bounce. We are experimenting with the pressure in each wheel to give the robot the best traction (so far, the best result is centre wheels at 40 psi, outer wheels at 25 psi). Pneumatic wheels also give a pseudo suspension to the frame.
OWilliamson, a single gearbox that includes both cim motors weighs 8.15 pounds. It is heavier than a ball shifter by 1.29 pounds. However, it is much lighter than a AndyMark super shifter.
Infinity2718, you are probably right about the fillets, we had the plates manufactured for us, so I am not sure what procedure they used.
The drivetrain is extremely robust with its inter-lapping plates and the gearbox, it also has a very low centre of gravity and is quite manoeuvrable. We are extremely pleased with it.
Unread 30-12-2013, 13:26
FF TSL: Frog Farce
Oh, I didn't know that the 54 number included electronics, it's fine with that in mind. How will/did bumpers attach?
Unread 02-01-2014, 13:55
FRC #2994 (ASTECHZ)
Team Role: CAD
The bumper mounting mechanism we designed is quite simple. Outer plates you see on the frame will be part of the bumper (staying under the 20 pound bumper weight limit). Rivet nuts will be placed on the frame at set locations and we will mount the bumpers using fasteners (also included as part of the bumper). If needed we will have an l-bracket attached on the top of the frame.
Unread 04-01-2014, 18:05
lewislongbottom's Avatar
lewislongbottom lewislongbottom is offline
Klein Bots 3735 Mentor
FRC #3735
lewislongbottom is on a distinguished road
So what are the benefits and fallbacks on an 8WD Drive Train? I just wanted a quick generalization of bullets for our team to go off of.
Unread 04-01-2014, 18:12
If I might make a suggestion...
There may be one already on the site. The search feature is near the middle of the orange bar at the top of the page.
There are a number of benefits and drawbacks to ANY drivetrain design. Weight, cost, chances of a failure and chances that any given failure will cripple half the drivetrain can be some drawbacks or some benefits.
