Go to Post how can anyone Not Notice An entierly Pink Team? - Tytus Gerrish [more]
Unread 30-12-2013, 12:10
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Re: pic: SimpleChassis
Originally Posted by roystur44 View Post
Offset the transmission closer together. The main shaft needs to extend so a pulley can be attached outside the plate. This makes it easier to attach a belt without having to take the transmission apart to install/replace the belt.
Sorry I thought you guys were using a belt
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 30-12-2013, 12:14
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
After finding last years rules I think I mixed up the "you must have at least 1 inch supported on the bumper corners" with another number (very sorry about that). The bumpers should be fine.
One question, how heavy is it? (just so I can compare it to all the cots drives)
Unread 30-12-2013, 13:22
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Here is a link to a $8 mill for cutting slots in angle. The amazing thin about a mill like this is it uses no electricity and can fit in pretty much any tool box. It is significantly less danergous that a vertical mill, and can actually do more precise cuts. I took a jewelry and metal smithing calss at Purdue. One of the first assignments was to cut out the profile of Lincoln out of a penny. It was pretty cheap practice and helped showcase the tools skills.
While I couldn't find a picture of a penny, I did find this picture of something similar done to a quarter (much harder metal):
While some might think it would take a long time to do such a thing, the lincoln profile took about 35 minutes with a beginner skill level. Sawing a couple straight lines after dilling 2 holes would likely require less time than locating edges in a mill.
