Go to Post Call it confidence, call it ego, call it what you want, but the fact of the matter is you need to be humble or someone will humble you. - Dan Richardson [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
  #76   Spotlight this post!
Unread 31-12-2013, 00:48
atucker4072's Avatar
atucker4072 atucker4072 is offline
Andrew Tucker
AKA: Andrew Tucker
FTC #4968 (Rapid Robotics)
atucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura about
Re: Game Hint Solution [probably]
The hint has had a good break through. If you look at the new thread you'll see.
  #77   Spotlight this post!
Unread 31-12-2013, 11:29
ThereYouAre ThereYouAre is offline
FRC #3405 (Eaglebots)
Team Role: Animator
ThereYouAre is an unknown quantity at this point
Even if they do reduce the pounds, I think there is a bigger purpose. It could be that the game can't take heavier robots, and it will be easier for us to do a light weight robot either way. I have never seen a hint that was completely about the robot, they are called game hints for a reason. So it must refer back to the game.
  #78   Spotlight this post!
Unread 31-12-2013, 11:36
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Sometimes they only even hint about the name of the game...which gives away nothing. Looking at you Logomotion.
  #79   Spotlight this post!
Unread 31-12-2013, 16:53
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Just as a wild guess only because of the {{{text}}} in the redo clue reminds me of the song,
1,2,3 oclock rock.
So the time might be a longer game of 3 minutes and then collecting rocks.
Just simple out look following Frank's suggestion.
Of course if all easy fails the game hint is a red herring which means a fishing game on the water of course. Sorry just had too.
  #80   Spotlight this post!
Unread 31-12-2013, 18:29
mechanica's Avatar
mechanica mechanica is offline
Mechanica
FRC #4468 (Fernbank LINKS)
Team Role: CAD
mechanica is an unknown quantity at this point
just did some research....
61474:135 - serial number for a triple tachymetric indicator (device which generates target position, speed, direction, and rate of target range change)
12661:1963 - (not sure about this one) nominal pipe size in 200 mm and 250 mm respectively with the capacity in kg/hour fir 4 bars of pressure
32662:15806 - (couldn't find anything with the numbers together, so I divided them by 2 and got 16331:7903; any higher divider would yield a decimal)
7903 - it is an helicopter serial number (most relevant result) and also the name of the 7903 Albioni asteroid belt
16331 - nada
I then divided 16331:7903 by 7 and got 2333:1129
2333 - serial number for greatwall motor (most relevant result)
1129 - nada
however, both numbers' results' had pictures of buses?????
hope this helped!
  #81   Spotlight this post!
Unread 31-12-2013, 20:49
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Hey Mechanica! I see that you're pretty new to the forum, so just as a rule of thumb you probably shouldn't post the same thing on multiple threads. I couldn't find a verbatim rule, so someone correct me if that's acceptable.
On top of that, this thread was about a specific solution too, so that's not relevant here.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
