Go to Post The obvious solution is to only allow the real world to have negative jade induction coefficients. - EricVanWyk [more]
Unread 31-12-2013, 20:17
Mr_smith's Avatar
Mr_smith Mr_smith is offline
FRC #3979
Mr_smith is an unknown quantity at this point
Drawing templates for kick-off concepts
Hi,
In order to ease our concept phase this year, I made some drawing templates of very simple bases. The students will be able to sketch their ideas directly on them. I am sharing them in case it can help other teams (see attachments).
Any comment for improvements is very welcome.
Thank you.
Unread 31-12-2013, 20:20
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Re: Drawing templates for kick-off concepts
Why no square frame? Square gives you the maximum area (for a rectangle).
Unread 31-12-2013, 20:33
Mr_smith's Avatar
FRC #3979
I made a 28" x 36" base, which is, I believe, the max dimensions from last year (I haven't checked the old rules). This would allow the max area.
But the dimensions don't matter too much for the concepts. It is more important to find out what the students need on the robot.
Unread 31-12-2013, 20:40
FF TSL: Frog Farce
I'm in agreement about size not really mattering early on in design, but the rules changed last year to allow a maximum 112 inch perimeter, instead of just 28x38. This is around 28x28 as a square, I don't remember what it is in the old ratio.
Unread 31-12-2013, 20:42
Mr_smith's Avatar
FRC #3979
I forgot about the total perimeter rule. You are right on this one.
Unread 31-12-2013, 20:43
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
max of 28x38 was the old size I believe
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 31-12-2013, 20:48
FF TSL: Frog Farce
No, I mean same ratio as 28x38, but following the new perimeter rules, it's almost 24x32.
Unread 01-01-2014, 18:45
Big Ideas Big Ideas is offline
AKA: Stephen des Jardins
FRC #2102 (Team Paradox)
Big Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant future
Interesting idea for a discussion aide. I do it all of the time at work, but, it had not occurred to me to give the team a similar sketch aide. At first I was thinking that the students would be to heavily loaded with the assumptions in the example. Not thinking that things like "size, rail design, wheel count COULD be different.
But, since my team will be kick starting design by using a prototype working chassis for early tests and development--we are making similar assumptions and potentially GUIDING (or over constraining) early concepts.
I think I'll make a similar sketch template using our "starting point" chassis.
