Go to Post the point is that FIRST is successful, in so many different ways - Pamela [more]
Unread 31-12-2013, 18:50
magnets's Avatar
magnets magnets is offline
Victor Blinking Light Question
We've got a question about the indicator light on the victor. We've only seen this on an older 883 (rev F), and we can't find an explanation in the manual for the newer ones. If you power on the controller while pushing down the calibration button, the indicator light flashes green for about 5 seconds. Sometimes (I'd guess less than half the time) it's red instead. What is it telling us?
Also, when did they stop making the 883s?
Unread 31-12-2013, 19:53
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Victor Blinking Light Question
Indication: Flashing RED indicator after calibration.
Problem: Calibration Failed.
Possible Solutions:
1. Inadequate travel in forward or reverse. Repeat the
calibration procedure and move the joystick further
forward and/or further reverse.
2. The joystick trim tab is NOT centered. Neutral cannot
be extremely far from center.
Source: Page 4 http://content.vexrobotics.com/vexpr...l_20130118.pdf
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 01-01-2014, 08:36
magnets's Avatar
I am aware of the calibration light, but I'm not calibrating the victor. There's no PWM signal going in, and it still flashes green, and you can't calibrate without a pwm signal.
Unread 01-01-2014, 09:01
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
I would start by removing anything that is connected to the output, disconnect the PWM, double check input wiring for 12 volts and apply power.
If it looks normal then try a cal without PWM and then with PWM.
The results of the above tests will be very helpful to finding out what is wrong.
Unread 01-01-2014, 11:02
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
The 888 is the same architecture as the 883. The 888 has new firmware which provides a more linear response curve, otherwise they are essentially the same units.
Because the response curves are different, I would suggest not mixing 883s and 888s on the same multi-motor mechanism.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 01-01-2014, 11:18
Did you mean 884? The 883 is 24v.
Unread 01-01-2014, 13:23
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
Not Always
Here's all the victors
Pre2003(?) red text 883's -12V(what I have)
Post2003(?) blue text 883's - 24V
2004(?)-200?- red text 884's (incorrectly disallowed at some competitions)
200?-2011 - blue text 884's
2012 green text 884's
2013 green text 888's
Unread 01-01-2014, 14:44
Originally Posted by apples000 View Post
...Pre2003(?) red text 883's -12V(what I have)
So, is the firmware the only difference between the Pre2003(?) red text 883 and the 2013 green text 888?? I would think some non-trivial hardware changes would have been made in the intervening 10 years.
Unread 01-01-2014, 15:07
The change from red to blue label 883s was a hardware change. The old ones required external transorbs (provided). They were implemented internally on the newer 883s.
From the 2000 robot manual:
There are two models of the Victor 883 speed controller being used in the 2000 FIRST
Robotics Competition. The older models are identified by a red “Victor 883” label, while the
newer models have a blue label. There is no difference in performance between the old and
new models. However, the older models do require the installation of a transorb (included
with the speed controllers) across the power input terminals.
Tip: Teams which purchased spare Victor 883 speed controllers in 1999 should be aware
that there is a low cost firmware upgrade available from Innovation First. Teams may use
Victor 883 speed controllers purchased in 1999 with or without the firmware upgrade. For
more information, consult the Innovation First web site at www.innovationfirst.com.
I don't know what the other changes affected. I find it hard to believe that there were no other hardware changes in the last 15 years, but can't point to anything particular. I suspect better FETs were used in the 884, as the continuous current rating increased.
Unread 01-01-2014, 17:24
From a 2003 883 Manual...
Resetting Calibration to FIRST Pre-calibration:
1. Power OFF the speed controller.
2. Press and hold the Cal button.
3. While continuing to hold the Cal button, Power ON
4. A flashing GREEN indicator denotes calibration is
reset. Release the Cal button.
I will make an assumption from this part that flashing red indicates a failure to return to factory calibration. This became a non-issue when it was realized that all joysticks are not created equal. Calibration to the joysticks used was highly recommended after that. I believe the 884 became available in the 2003 season(after kickoff). By 2004, 883s were not allowed on the robot per the Inspection Checklist. The change from red to blue labels on both the 883 and the Spike gave a lot of confusion during that transition. There was a period of a couple of weeks where red 883s were not allowed even though some had been provided in the KOP that year.
There is significant hardware changes in the 888, the FETs, for one, are different.
Unread 01-01-2014, 18:32
magnets's Avatar
Thanks! That explains why we kept having to recalibrate all the time, we must have been resetting the calibration to watch the blinking lights. I've also noticed that the red flashing lights happen if you try to power on the victor with a PWM signal going in while holding the button down. It seems like it won't reset this way.
