Go to Post How many of the team's current students were even alive when those awards were earned? :) - Alan Anderson [more]
Unread 03-01-2014, 21:24
Bryce Paputa's Avatar
Happy Birthday! Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
pic: 2014 Offseason CAD
Unread 03-01-2014, 21:27
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Re: pic: 2014 Offseason CAD
Looks pretty good! Only have two questions/concerns. First - it looks like the belly pan only extends to the inner side panels; did you consider having it go to the outer rail and if so what made you chose not to? Second - you probably won't need that many wing nuts to hold the bumpers on . Overall though, I like the design. Good luck in 2014!
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 03-01-2014, 21:34
OWilliamson's Avatar
OWilliamson OWilliamson is offline
FRC #2594 (NASKCO)
OWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of light
First off, I'm really digging this chassis
One thing that I will mention though, is that you might want to consider having a cutout in your belly pan beneath the gearboxes. If you do this you can disconnect the gearbox and then slide it out the bottom. Last year in competition we had a problem with one of our gearboxes, and it was a nightmare to pull it out to perform the repairs that we needed to. It took way too long, and almost cost us a match. It shouldn't compromise the strength of the belly pan too much, and it could possibly be the difference between missing a match or not in competition.
2015: Utah Regional - Quarter-Finalists (3374 & 4158)
2014: Utah Regional - Semi-Finalists (1619 & 399)
2013: Utah Regional - Quarter-Finalists (1332 & 3562)
2012: Utah Regional
Unread 03-01-2014, 21:50
Johnny_5's Avatar
Johnny_5 Johnny_5 is offline
Whose cooking motor?
AKA: Isaac
FRC #3484 (Short Circuit)
Johnny_5 has a spectacular aura aboutJohnny_5 has a spectacular aura about
Careful with waterjetting that thin of material, depending on what kind of machine you are using, you can end up with some pretty bad cuts.
When the machine begins the cut, it uses a much high pressure to first pierce the material and then it lowers it to actually run the cut. Sometimes the back of the sheet metal can blow out with that initial jump.
However, this can be pretty easily solved with the Omax jets (I'm sure Flow does this stuff too) they have a drill attachment that goes on the head to first drill through the sheet. Or you could opt to drill it yourself and then use the camera locating tool to tell it where to begin the cut.
This is an issue we are going to be facing this year. Luckily enough we have 5 pretty large laser fabrication shops that even have CNC press brakes that we are going to ask for sponsorship from.
Unread 03-01-2014, 22:02
FF TSL: Frog Farce
We can't go all the way to the outside because we have to put the axles, wheels, etc. up through the bottom. The amount of wingbolts is a bit ridiculous, in the actual robot we would probably take a few of them out. The holes in the bumpers will also probably be oversized and slotted, which isn't represented in these files.
First off, what gearbox were you using and what was the issue (just for my curiosity)?
We originally had the bellypan cut out under the gearbox (If you suppress Extrusion2 in "Electrical/board/FF14-EP-2-AA Base Electrical Board.ipt" it will go back to this), however since we have never had an issue with the supershifters, we decided that we would take the repairabiity hit and go with taking them out of the top (having a easily removable gamespec element will be a design requirement) in order to get more rigidity. The electrical board is actually 3 pieces of 1/16th aluminum folded and riveted together, making 2 mini-crossbeams for torsional stiffness, having the control board go down to a thin section in-between the motors would greatly reduce the effect of these. A secondary design priority was to have as much rigidity as possible to help with handling, last year we did not have a structural bellypan, nor did we have rigid bumpers; we ended up with great front-back and side-side rigidity, but it was not up to snuff torsionally, which makes it scrub more, and scrub more inconsistently. We're trying to fix the rigidity this year with the belly pan, very heavy bumpers, and a more structural gamespec element. I'll talk to our other guys about it though.
One of our sponsors has waterjetted two robots of this same style and thickness without issue, thanks for the warning though.
Unread 03-01-2014, 22:13
AKA: Jesse Gibson
Team Role: CAD
If you wanted to get a little extra strength out of the belly pan, you could try something like in this picture
Not sure how much space you have between wheels but doing something like that will let you extend the belly pan farther out but still allow you to put the wheels in through the bottom
2011 - Logomotion
Unread 03-01-2014, 22:23
FF TSL: Frog Farce
We use chain (#25), so we have to be able to access it between the wheels to do stuff with masterlinks and maintenance. There isn't any room for tools to come down through the top. It would be another good reason to switch to belts though (looking a year or two out), we've been considering it for quite a while now but don't have any real experience with them.
Unread 04-01-2014, 00:45
FRC #2594 (NASKCO)
We were using the Kitbot, so we were just running the Toughbox Minis.
The issue that we had was actually a drive motor coming loose. I'm still not certain how this happened, and was probably an error on our part. We ended up having to pull the gearbox out in order to reassemble everything, and it was just a general pain in the butt to do.
I still recommend that teams at least consider it because I heard of the theory (pretty sure I first heard it from the Killer Bees) that you should be able to work on your drivetrain from beneath your robot. Once you start adding game piece manipulators and the superstructure on top, you can't guarantee that you will have room to work on the drivetrain anymore. If something does end up happening, it will be much harder to fix things from the top.
But, I do realize that torsional rigidity is a big issue with a lot of teams. That's awesome that you guys had already brought it up in your design, and if you think you will be better off without them them go for it
2012: Utah Regional
Unread 04-01-2014, 06:09
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
I would not be concerned about cutting material this thin. I've cut plenty of thin aluminum to high precision, even 1/32" thick carbon fiber comes out nice.
It all depends on your fixturing methods. It's imperative to properly clamp and weight your material in place. Even plastics and low-density materials are not a problem.
As an OMAX employee and FIRST participant, I've never had to use a drill attachment before. If piercing is an issue, you can easily adjust the pressure ramping in software to achieve smoother piercing. Optical locating is also overkill...
If material blow-out or frosting is an issue, don't be afraid to throw a piece of wood or other sacrificial material underneath. It's a quick way to ensure a nice surface finish.
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
