Go to Post We must remember: if you're reading this comment right now you already "get it." - akeisic [more]
Unread 03-01-2014, 19:07
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
CNC router: suitable for FRC?
Hello!
We would like to improve our in-house fabrication capabilities, and have been torn between a DRO mill, and a CNC router.
obviously a mill would handle aluminum better, but we would like to be able to work on chassis profiles without clamping them twice (thus reducing accuracy).
A mill large enough to have that much X travel would not fit in
our workshop most likely (height limit).
This made us think about CNC routers, but none of us have any experience with them, so we thought we'd consult CD.
what do you think about using CNC routers on aluminum profiles?
What say you about this CNC router?
We appreciate your input!
- Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 03-01-2014, 19:22
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Re: CNC router: suitable for FRC?
We have a ShopBot in our shop. I have cut a few profiles in .125 6061-T6 plate when the CNC Mill was in use, but haven't ever drilled using it. It is a
http://www.shopbottools.com/mproducts/prSstandard.htm
You have to clamp the parts down very well and take very shallow cuts on aluminum (.030 or less) or else the router will move in Z (the clamp holding the router in is not meant to take a lot of axial force). I believe it will drill holes in thin wall tubing but I haven't tested it. Just remember it is not a mill, go slow (especially in Z) and you can make some parts.
If what you really want is a mill (and for FRC I think you want a mill) - you can find an old Bridgeport CNCs for $4000 if you look hard enough. Certainly an old manual mill and eventually convert to CNC.
-matto-
Unread 03-01-2014, 19:49
AdamHeard's Avatar
Lead Mentor
We have a manual knee mill that's 3000 lbs w/ 30" of X travel (pretty standard), we have a CNC metal router that's much heavier duty than the one you linked, and it's 20x60". We have a metal router (in terms of construction) heavier duty that the one you linked, largely for wood (24"x24"). We also have a clone of hte above mill converted to CNC.
Having used all these, even our heavy duty router does not hit the precision of the manual or CNC mill WITH jumping in the vices. Rezeroing is easy.
A quality router has a great place in FRC for platework, but you'd want something much beefier than what you linked, and that's where a CNC knee mill can be a steal (found from $3k-10k used) if your goal is to also run tubing, etc... We have a fixture on our larger router for running tubes, but it doesn't compare in power or speed to the knee mill.
For reference, our metal router can sustain 40 ipm w/ a 3/16" cutter at .07" depth. If we're watching the machine closely and keeping the mister and airblast going, we can do 80 ipm. It can do faster for shorter times (and if you are fine with a lot of cutter deflection), but not all day.
Be weary of numbers posted for cheap routers, and youtube videos. They are often showing hte cutting speed for brief periods of time, and in a situation where they are getting a lot of deflection int eh cutter and machine (wrecking accuracy).
Unread 03-01-2014, 20:10
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
FRC #2468 (Team Appreciate)
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
Originally Posted by Leav View Post
Hello
- Leav
We purchased this CNC this Fall. We got it up and running just a while back. We went with thehttp://www.homedepot.com/p/Bosch-2-2...SPK/100341666# for our machine based on the recommendation of Probotix.
We are very excited to get our machine up and running. We could have done all of sheetmetal for robot last year with this machine.
We have used a CNC similar to this for the past few years that was manufactured by one of our mentors and a student over one summer. We have used it on:
aluminum tube (4x4, 1x1, 2x2), angle and plate
HDPE: 1/2" to 1.25"
Lexan: a variety of thicknesses
wood: plywood, MDF
Carbon Fiber
BTW, we use double sided tape for holder material in place when machining most of the time.
If you go with this machine, drop me a line and I will share more information if you are interested.
Another piece you might want to look into is the Precise Bits Collets.
FRC 2468 Team Lead 2008 - Present
Win The Day!
Unread 03-01-2014, 20:13
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
We have a Haas TM-1P with 10 position tool changer and a Haas TL-1 on the way (it might be there already or not with the snow). On the manual side we have an old Bridgeport knee mill.
We've not done too much with the Haas yet at FRC but from experience it'll handle the jobs just fine. Just realize it's expensive, depending on the software that could be expensive, and then there's the tools. This is not really a hobby machine it's a professional tool.
Unread 03-01-2014, 22:09
DonRotolo's Avatar
Back to humble
FRC #0832
Some CNC routers can cut aluminum quite well. I recently built this one (27" x 50" version), and using a Hitachi router and special Onsrud router bits, it cuts aluminum quite well. NOT like a mill, somewhat slower and lighter cuts, but no problems cutting.
The whole machine cost me about $3300 to build, using the generous FIRST discount with the local 80/20 distributor and some careful work on my part. The "official" cost is closer to $4000, and sources and prices are given for everything needed. You can surely buy everything you need, either from the USA for the smaller stuff, or locally for things like steel and aluminum parts. I did have to add a coolant system for cutting the aluminum. Cost under $25. A single person can assemble the machine in 10 working days, but I did it over about 3 months.
The Probotix Comet is a much lighter machine. It will cut aluminum, but even slower than the KRMx02. You also need to buy a spindle for it, which can be a non-trivial expense.
But to answer your basic question: Yes, a CNC router can be very useful for FRC. If you have time, it can rival the work on a CNC Mill, but only for softer metals like aluminum, brass, etc. Oh, and it cuts Polycarbonate really well, too!
Unread 03-01-2014, 22:51
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Personally I know I'd love to get my hands on a CNC router for our FRC and FTC teams. Being able to easily do sheet metal parts would be really nice.
Although, I want to throw this idea out there; build your own.
I've been following this fella on youtube for a couple years, and he's build a fantastic, high-accuracy (for a router), powerful, machine for about $2500, and with the kind of expertise that you have with FIRST teams, it could totally be pulled off. And he even has some good how-to videos if there are things you get stuck on.
And http://www.cnczone.com/ is a great resource.
You still might find that buying one is better for you, I just wanted to throw it out there.
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 03-01-2014, 23:41
Mulcahy's Avatar
Mulcahy Mulcahy is offline
FRC #0987 (High Rollers)
Mulcahy is on a distinguished road
We have a shopbot. It gets used as much as any machine in our shop - including the drill press and cnc mill. You can cut aluminium with a single flute cutter. The end product is not as finished as it is on the mill, but the ability to rapid prototype is priceless. We also make a lot of mock-ups using MDF and Lexan to check the fit of parts before they are sent out for final machining by our awesome sponsors. I would highly recommend getting one.
Unread 04-01-2014, 00:36
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Hey everyone!
thanks for the replies!
just to clarify: when I said "aluminum profiles" I actually menu "aluminum tubing, mainly rectangular".
from your answers I gather that it's possible but maybe not the best idea.
does no one make CNC routers intended to cut aluminum?
-Paraphrasing JFK
Unread 04-01-2014, 00:47
techhelpbb's Avatar
Hey everyone!
If you take a look at my post you'll see that the Haas TM-1P can machine just about anything an average Bridgeport can which includes aluminum. It's more than fast, powerful and rigid enough, it's got coolant and with the proper tools it'll do a great professional job.
Gantry routers will do aluminum but there are limits in speed, power and rigidity. I've cut plenty of aluminum on gantry routers just know: your machine, keep the number of flutes down as low as possible, use smaller diameter end mills, and mind the suitable feed rates (you'll mind the feed rates anyway on most CNC machines). If you must use a general purpose shop router as the spindle consider getting a SuperPID for it.
Will these cheaper machines be a 100% replacement for something like the Haas TM-1P: absolutely not. Will they do some work: sure just don't get too crazy. Keep in mind the forces involved and respect them.
Unread 04-01-2014, 06:14
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Sorry I didn't get a chance to click the link when I wrote my post, I was on my phone.
Now that I've clicked, I must say I was taken aback by the price!
We were looking to get something for under $5000.
I think that's an important thing to take from this: If we're willing to keep feed rates down, It would probably be ok to use a gantry router.
This is good news as far as I'm concerned, since the gantry router form factor is better suited to our shop (the ceiling is pretty low, about 3m/9feet at most).
Thanks everyone! i'll be back when we compile a list of optional machines and i'll ask for your opinion again.
-Paraphrasing JFK
Unread 04-01-2014, 08:57
RandomStyuff RandomStyuff is offline
FRC #2212 (Spikes)
RandomStyuff is a jewel in the roughRandomStyuff is a jewel in the roughRandomStyuff is a jewel in the roughRandomStyuff is a jewel in the rough
Don't know if this question fits here or in another thread but it felt very related. A few weeks ago I saw the Shapeoko 2 CNC router (http://www.shapeoko.com/) which felt to me really inexpensive relative to the option of a CNC mill. I assume nobody would have experience with the new version but does anyone know based on the old version if it would be something that fits for FRC uses?
Would it be possible to use such equipment for things like making gearbox plates or a drive system frame (in terms of accuracy). I understand that routers take longer than mills, but I expect being able to do slow is better than not being able to do at all .
I've found it including some more details and price here: https://www.inventables.com/technolo...kit-shapeoko-2
Because using your robot's cannon to shoot at your nation's Minister of Education is worth all the 6 weeks of no sleep!
Unread 04-01-2014, 09:40
DonRotolo's Avatar
Back to humble
FRC #0832
I think that's an important thing to take from this: If we're willing to keep feed rates down, It would probably be ok to use a gantry router..
Emphasis mine. No, you need to calculate the correct feed rate based on the tool (router bit) manufacturer's specification, and take a smaller depth cut. Taking too small of a 'bite' (from a low feed rate) is just as bad as taking too big of a bite (from a high feed rate). Look up the term "chip load".
But yes, if you are willing to keep the pass depth down to maybe 0.125 or less, cutting aluminum (including profile) is not a problem.
Except, longer tools will be needed to cut the entire thickness, and these are less rigid than short tools. For example, I use a 3/16" diameter cutter with a cutting length of only 3/8". I cannot cut anything deeper than 3/8". But this tool is very rigid and doesn't deflect much at the proper feed speed (60 IPM, 12000 RPM, 3/32" pass depth (=1/2D)). A tool with a cutting length of, say, 1.25" will be less rigid, but it will cut 1" box stock without trouble - but maybe only at 40 IPM, 8000 RPM, and perhaps only 0.06" depth. (The tool bit can cut at 1D pass depth, but the machine cannot supply that kind of force)
Unread 04-01-2014, 19:38
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Thanks for the detailed info DonRotolo. Really helpful! Am working on lightening cutouts. What about a miniature chop saw between 1/2 diam drill holes?
Unread 04-01-2014, 21:04
DonRotolo's Avatar
Back to humble
FRC #0832
I don't understand the question.
