Go to Post The battery will be mounted at the top, correct? There can be no other way. - Travis Hoffman [more]
Unread 04-01-2014, 12:30
mkaa00x's Avatar
mkaa00x mkaa00x is offline
Momo
AKA: Mohammad Al-Ahdal
FRC #4627 (Iron Manning)
Team Role: RoboCoach
mkaa00x is an unknown quantity at this point
Is it possible to block a pass?
Since 2014's game is NOT a water game, (sadly) for this year's game, is it possible to block a pass, haven't found anything in the Manual so far.
Unread 04-01-2014, 12:49
MasterEric's Avatar
MasterEric MasterEric is offline
Bacon. 'nuff said.
AKA: Eric Myllyoja (E2)
FRC #2137 (Oxford Robocats)
MasterEric is an unknown quantity at this point
Re: Is it possible to block a pass?
I see nothing in the rules against it.
One interesting bit though is:
An opponent ROBOT that contacts, but fails to stop a BALL from going over the TRUSS or in a GOAL has not caused either of these actions and does not invalidate the SCORE.
This means that if a blue robot throws its blue ball, and it hits a red bot, but still goes over the truss, its still a blue score, not a red score because the red bot touched it last.
In a similar situation, if that blue robot throws its ball, and it hits a red robot and bounces away, and doesn't go over the truss, it's not counted because it didn't go over.
So yes, you can block a pass.
Unread 04-01-2014, 12:50
jtaffy's Avatar
jtaffy jtaffy is offline
Business and Scouting Lead
FRC #4911 (CyberKnights)
jtaffy is an unknown quantity at this point
G25: ROBOTS on the same ALLIANCE may not blockade the FIELD in an attempt to stop the flow of the MATCH. This rule has no effect on individual ROBOT-ROBOT interaction.
Violation: TECHNICAL FOUL
I think this means that we are allowed to block and push other robots like in the past (just not pinning), but we can't block the entire field.
Unread 04-01-2014, 12:52
kuraikou's Avatar
kuraikou kuraikou is offline
AKA: Alex
FRC #4183 (Bit Buckets)
kuraikou is an unknown quantity at this point
The manual says that "An ALLIANCE may not POSSESS their opponent’s BALLS. The following criteria define POSSESSION :
A) “carrying” (moving while supporting BALLS in or on the ROBOT),
B) “herding” (repeated pushing or bumping),
C) “launching” (impelling BALLS to a desired location or direction), and
D) “trapping” (overt isolation or holding one or more BALLS against a FIELD element or ROBOT in an attempt to shield them).
Violation: TECHNICAL FOUL per instance."
So I think that blocking is not allowed, but it is iffy.
2012 Utah regional Rookie All Star
2013 Phoenix regional Judges Award
2014 Hub City Quality Award
2014 Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award
2015 Arizona East Regional winning alliance captain
jdh042397's Avatar
jdh042397 jdh042397 is offline
Being a nerd really pays off!!
FRC #4063 (TRikzR4kiDz)
Team Role: Electrical
jdh042397 is an unknown quantity at this point
G12 An ALLIANCE may not POSSESS their opponent’s BALLS. The following criteria define POSSESSION :
Violation: TECHNICAL FOUL per instance. Examples of BALL interaction that are not POSSESSION are A. “bulldozing” (inadvertently coming in contact with BALLS that happen to be in the path of the ROBOT as it moves about the FIELD) and B. “deflecting” (being hit by a propelled BALL that bounces or rolls off the ROBOT). A BALL that becomes unintentionally lodged on a ROBOT will be considered POSSESSED by the ROBOT. It is important to design your ROBOT so that it is impossible to inadvertently or intentionally POSSESS an opponent’s BALL.
So I think you can. Just be cautious to follow the g12 CRITERIA.
2014 Hub City Regional Engineering Inspiration
2012,2013,2014 Alamo Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
2013, 2014 Hub City Regional Finalist
"Robotics are beginning to cross that line from absolutely primitive motion to motion that resembles animal or human behavior."
J. J. Abrams
Unread 04-01-2014, 12:53
TheCrayButton's Avatar
TheCrayButton TheCrayButton is offline
FRC #3528
TheCrayButton has a spectacular aura aboutTheCrayButton has a spectacular aura about
Yes you can.
Unread 04-01-2014, 13:03
MasterEric's Avatar
Bacon. 'nuff said.
If it bounces off the opponent's robot, but the opponent's robot doesn't carry, herd, launch, or trap the robot, then it would be valid.
Take for example if the opponent robot gets in the way of a ball, the ball is thrown, and it bounces off the robot and away. It does not count as herding since it is not repeated bumping.
