Go to Post I'll toss this out to stir up the pot: if you need double precision floats for your FRC software, you should re-think what you're doing. - Ether [more]
Thread Tools Rating: Thread Rating: 12 votes, 4.67 average. Display Modes
  #76   Spotlight this post!
Unread 04-01-2014, 13:40
Kabir Manghnani's Avatar
Kabir Manghnani Kabir Manghnani is offline
FRC #0649 (MSET Fish)
Kabir Manghnani is an unknown quantity at this point
Re: Aerial Assist Discussion Thread
Originally Posted by shades23 View Post
Wait so what is the max amount of points you can score in a single run?
60pts
Max cycle: 3 assist, truss-catch, high goal (60 points).
Different strategies: 2 assist, truss-catch, low (51 points);
2 assist, high (40 points);
2 assist, low (31 points)
FRC Team 649
Vice- President
Programmer
Chairman's Lead
Scouting
The voices in my head may not be real, but they have some good ideas!
  #77   Spotlight this post!
Unread 04-01-2014, 13:52
andrewia andrewia is offline
AKA: Andrew LD
FRC #3859 (Wolfpack Robotics)
andrewia is an unknown quantity at this point
It seems to me that "assisting" is the act of another robot possessing the ball in another zone; assistance is not defined by passing. That would mean one alliance robot could get the ball from outside (+10 pts.), pass it to a human player, and then the human passes the ball to another robot in another zone (+10 pts.). This means that robots with poor passing ability can use the human players. Human players can pass much quicker than robots (unless you have really good drivers and programs) so this might be a more efficient method of passing.
  #78   Spotlight this post!
Unread 04-01-2014, 13:53
bs7280 bs7280 is offline
FRC #3734
bs7280 has a spectacular aura aboutbs7280 has a spectacular aura aboutbs7280 has a spectacular aura about
I have a question about getting 30 assist points AND the over the truss + catching bonus:
After watching some of the field tour videos about assists, I learned that, in order to get all the assist points, you have to pass between color zones, and to the opposite sides of those color zones (different row and column if you will). And for the Over the truss + catch maneuver my first thought was to have a robot with an arm/elevator that lifts the ball over, and only a few feet away is a catching robot with a large bucket.
So, in order to get 30 assist points AND the over the truss with a catch, do you have to make some huge 20 foot pass across the field from one zone to the next in order to get all the points? or can you do a short pass like I said, then have the other robot drive into the different zone to get the same number of points?
  #79   Spotlight this post!
Unread 04-01-2014, 13:56
mechanical_robot's Avatar
mechanical_robot mechanical_robot is offline
Team Role: Driver
mechanical_robot will become famous soon enough
Originally Posted by npalm2849 View Post
What happens if a ball is stuck inside a robot during autonomous. Then you cannot score until you get that stuck ball out it seems. Hope FIRST fixes this issue.
That's a you & your team's problem not a FIRST problem. Find a way to combat this. Be innovative.
  #80   Spotlight this post!
FRC #3734
Do the supershifter gearboxes work with the new 2014 frame?
  #81   Spotlight this post!
Unread 04-01-2014, 14:05
Coin3's Avatar
Coin3 Coin3 is offline
AKA: Griffin Cerva
FRC #4110 (Deep Space Niners)
Coin3 is an unknown quantity at this point
I believe doing so would only net you 2 assists. Assists are defined as "when a unique ALLIANCE ROBOT POSSESSES the ALLIANCE’S BALL in a unique ZONE (i.e. red, white, or blue ZONE) during a CYCLE." So passing the ball across the field from one robot to the other and then scoring would only count as 2 unique alliance robots possessing the ball in 2 unique zones, and therefore 2 assists. The "correct" way to get 3 assists with an over the truss catch would be for the furthest back robot (opposite alliance zone) to launch the ball over the truss, the second robot (white zone) catches it and passes it over to the third robot (alliance zone) who then scores it.
Don't forget to be awesome!
  #82   Spotlight this post!
Unread 04-01-2014, 14:07
4AngryNutjobs's Avatar
4AngryNutjobs 4AngryNutjobs is offline
FRC #3859
4AngryNutjobs is an unknown quantity at this point
By removing the end game they've reduced the number of different things a robot can do and given us more opportunity to increase the complexity of a single mechanism.
  #83   Spotlight this post!
Unread 04-01-2014, 14:10
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Jibri Wright will become famous soon enough
Anybody know how much the balls weigh?
You know someone likes something when after doing it a million times, they still marvel at it as if it was the FIRST.
Greatness asks how can I make it better. Genius asks how can I make it different.
  #84   Spotlight this post!
Unread 04-01-2014, 14:14
MOOcow's Avatar
MOOcow MOOcow is offline
AKA: Cliff
FRC #1986 (Team Titanium)
Team Role: Electrical
MOOcow is an unknown quantity at this point
Someone mentioned earlier that the balls were 5 lbs exactly without air.
  #85   Spotlight this post!
Unread 04-01-2014, 14:19
prachinawathe15 prachinawathe15 is offline
FRC #1351 (TKO)
prachinawathe15 is an unknown quantity at this point
I can't seem to find where to buy just the bladder, but that may not be the best idea because rubber and cloth will act differently when you try to pick them up. For example, a suction method may work for just the inflated rubber bladder, but it will not work if the cloth cover is on.
  #86   Spotlight this post!
Unread 04-01-2014, 14:25
Team Role: CAD
ok thanks. Any guess as to how much with air?
  #87   Spotlight this post!
Unread 04-01-2014, 14:35
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
Originally Posted by Kabir Manghnani View Post
Exactly 5lbs without air (air wont add much weight though).
AndyMark says 2.75 pounds.
http://www.andymark.com/FRC-2014-p/am-2720.htm
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
  #88   Spotlight this post!
Unread 04-01-2014, 14:37
MOOcow's Avatar
AKA: Cliff
Originally Posted by Ankit S. View Post
Ah. I just saw someone said 5 lbs earlier, I should have done some research.
Air shouldn't add much.
The volume of the ball is about 4.19 ft^3
According to Wolfram Alpha, 4.19 ft^3 of air weighs .334 lbs.
2.75+.334 = 3.084
The ball with air will weigh approximately 3.084 lbs
  #89   Spotlight this post!
Unread 04-01-2014, 14:38
Team Role: CAD
Oh wow! Any verification on this?
  #90   Spotlight this post!
Unread 04-01-2014, 14:47
FRC #3859
Couple questions. Do assists other than the truss pass/catch count if the goal is not scored? Also if you missed and made a couple more assists and managed to score this time, could you get over 3 assists for a cycle?
