Go to Post It's just a game. - artdutra04 [more]
Unread 04-01-2014, 14:35
mechanical_robot's Avatar
mechanical_robot mechanical_robot is offline
Team Role: Driver
mechanical_robot will become famous soon enough
Vision Targeting for Aerial Assist 2014
Alright what are some ideas for vision targeting this year for the 2014 game? My ideas were to for autonomous use the hot zones to target.
Any ideas what are your ideas. I'm currently looking at the game/arena setup PDF.
Unread 04-01-2014, 14:49
Hypnotoad's Avatar
Hypnotoad Hypnotoad is offline
Junior Assistant Secretary of Moon
Hypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these parts
Re: Vision Targeting for Aerial Assist 2014
It seemed pretty clear that that was the intention of the hot zone from the very beginning.
The following sentence is true.
The preceding sentence is false.
This sentence is false.
This signature is false.
My teeth are false.
Unread 04-01-2014, 19:28
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Track the hot zone, the balls (calculate its speed and go to where it will be autonomously), track other robot and pass the ball so it will meet them in their path. Track opposing robot so you can autonomous move around them. Track the vision tape on the wall and index from that.
Not going to lie, this this very elementary stuff.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 04-01-2014, 20:50
N00bfirst N00bfirst is offline
FRC #4992
N00bfirst is an unknown quantity at this point
Not for us new to this.
Unread 04-01-2014, 21:23
http://wpilib.screenstepslive.com/s/3120/m/8731
Unread 04-01-2014, 22:00
FRC #4992
Originally Posted by RufflesRidge View Post
wow...
thanks a lot!
Unread 04-01-2014, 22:31
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
I agree that determining from the vision target if one of the autonomous goals is hot from a relatively defined stationary position is an easy task with already published examples.
But I don't see how you can possibly argue that tracking other robots and/or flying ball(s) is elementary. That betrays either a misunderstanding of how difficult it really is, or such a deep mastery of computer vision that you've forgotten how difficult it is to the inexperienced. I'll assume the latter.
Unread 05-01-2014, 11:18
faust1706's Avatar
I"m going to finish it as soon as I can so I can then outsource the code. If you do a cascade on the object, then you can calculate distance via sterio or depth. You can "measure" the distance traveled between 2 frames for this ball or robot, along with the distance on screen. Size you can assume that the robot's frame dimensions will be almost identical for every robot (or you could save that robot's dimensions when doing a cascade of them), you can measure the velocities in the other two, then use simply add all 3 and now you know it's velocity. Then you know how fast you are going to roll the ball at them, so you do a vector problem. This does assume that they will continue their speed.
The ball is a fairly easy. You already know how big the ball is (therefore its diameter). You could simply use the area of the ball to calculate how far away it is. It would take some testing, but it is very doable. Then the same math applies to the previous example.
Unread 05-01-2014, 11:38
Team Role: Driver
Never asked or said anything about how easy or hard this all was.
Unread 05-01-2014, 12:22
yash101 yash101 is offline
AKA: null
Take a look at 341's vision paper. It's well written and has what you need to learn! While the programming isn't necessarily the easiest part of vision, the algorithm still seems quite simple to work with!
Unread 05-01-2014, 12:37
AKA: null
The math involved is quite simple. You know the diameter of the ball in real life. You can get the diameter of the ball from theNumber of pixels out is wide. Use convexhull to find the balls and process them. So you will need a reference image showing how large 25 inches is. You can use this info to extrapolate the size and distance to three ball. This will allow you to find the distance to the ball and find the speed and acceleration.
This is simpler than what it seems. Have you gotten pence installed with python bindings or Windows c++?
Read 341's vision whitepaper!!!
Unread 05-01-2014, 12:41
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
If you didn't outsource the code before Kickoff you are to late and you can't use it on your 2014 robot:
R13 ROBOT elements created before Kickoff are not permitted. ROBOT elements, including software, that are designed before Kickoff are not permitted, unless they or their source files are publicly available prior to Kickoff.
I hope that you did outsource it before Kickoff as I am interested in seeing your techniques as a learning tool for my team's programmers. Please include a publicly available link to your source code.
-T
Unread 05-01-2014, 13:23
Hypnotoad's Avatar
I doubt there will be much practical use in tracking anything but the hot zone. Anything else and you're adding unreliable gimmicks to your code. Letting the drivers practice for a few extra days at picking up and shooting is most likely much more beneficial than a ball tracking algorithm.
What I'm worried about is the brightness of the led strips around the hot zone. It seems like they will be a bit dim to track. If anyone has seen stills of teams using the reflective tape, you will see that the leds have to be blindingly bright for them to be as easy to destinguish.
My teeth are false.
Unread 05-01-2014, 13:24
Then why not track the reflective targets?
http://www.youtube.com/watch?v=8-vZm...ru_5& index=3
Unread 05-01-2014, 13:33
Hypnotoad's Avatar
Huh. I totally missed that part while looking through the rulebook. I guess ill read through it one more time. That's one less problem I have to deal with then. Thanks!
My teeth are false.
