Go to Post Our robot throws custom $5.50 FIRST Frisbees at a rate of 75 discs per minute and a speed of ~32 feet per second. It costs over $80 to feed our robot for 12 seconds. - Woolly [more]
Thread Tools Rating: Thread Rating: 12 votes, 4.67 average. Display Modes
  #106   Spotlight this post!
Unread 04-01-2014, 15:20
cbudrecki's Avatar
cbudrecki cbudrecki is offline
AKA: Carl Budrecki (buh-dre'-key)
FRC #0222 (Tigertrons)
cbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to all
Re: Aerial Assist Discussion Thread
Originally Posted by jp1247 View Post
Neat game, interesting there's no endgame...
Though, it may just be me, it seems that there is no point to the lower goals. Every team (assumption, though a fairly good one I'd say) is going to at least AIM for getting the high goals.
With assists, the low goals can still be valuable. The 10 & 30 point bonuses also apply to the low goals.
  #107   Spotlight this post!
Unread 04-01-2014, 15:21
taschneide taschneide is offline
FRC #1719
taschneide is an unknown quantity at this point
If you get a ball from your team stuck inside your robot, then tough luck, I guess. You can't use the ball, and you can't get another ball into play until your ball has been scored, which isn't going to happen, 'cause you can't use the ball.
If you get your opponents' ball stuck inside your robot, though... that's a technical foul, right? But is it just one technical foul, or do they add more on over time? The rules say "technical foul per instance"... I assume this is one thing they're going to change over the coming weeks, otherwise it might be worth it to steal your opponents' ball and sit on it for the whole match.
  #108   Spotlight this post!
Unread 04-01-2014, 15:28
Snapshot Snapshot is offline
Director of Media / Electrical Lead
AKA: Trevor Naze
FRC #2910 (Jack in the Bot)
Team Role: Electrical
Snapshot will become famous soon enough
Has anyone seen anything that says it's okay to block passes by intentionally driving between two opponent robots or even pushing a ball out from in front of a robot that's pushing the ball along the field?
  #109   Spotlight this post!
Unread 04-01-2014, 15:32
Steve Horn's Avatar
Steve Horn Steve Horn is offline
#OMGSuffShakedown Scorekeeper
FRC #0176 (Aces High)
Steve Horn is on a distinguished road
Originally Posted by Jhultink View Post
So if you can's score autonomous you get to become a goalie...
If you can't score in one of the goals in autonomous mode, you can also drive into your zone and get five points. If you can cross into your zone and score in the "hot" goal, you can get 25 points in autonomous mode.
Steve Horn
Social media mentor for team 176 Aces High
Team website | Twitter | Facebook | Pinterest | Instagram
  #110   Spotlight this post!
Unread 04-01-2014, 15:33
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by Chi Meson View Post
Follow up to that,
Can the balls that begin in auto be used to score truss points before they score a goal?
I'm guessing not, based on 3.1.4:
Points are awarded once per CYCLE for BALLS SCORED by ROBOTS in the GOALS, BALLS SCORED by ROBOTS over the TRUSS, and for each ROBOT CATCH. Additional points are credited to an ALLIANCE upon each GOAL based on the number of ASSISTS earned by the ALLIANCE for that CYCLE.
The CYCLE doesn't start until after all the BALLS from AUTO have been SCORED. (3.1.2)
(since 2004)
  #111   Spotlight this post!
Unread 04-01-2014, 15:37
Chi Meson's Avatar
Chi Meson Chi Meson is offline
"Strange and Anti-charmed"
AKA: Brian Chidley
FRC #2168 (Aluminum Falcons)
Chi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud of
But that logic would make the autonomous goals not count as well. I read that rule to limit the number of truss/catch points per cycle.
In 3.1.4 it says specifically for assist points:
"ASSISTS are earned when a unique ALLIANCE ROBOT POSSESSES the ALLIANCE’S BALL in a unique ZONE (i.e. red, white, or blue ZONE) during a CYCLE."
It does not say specifically that truss points "only count within a cycle."
  #112   Spotlight this post!
Unread 04-01-2014, 15:42
Yalib Yalib is offline
FRC #2630 (Thunderbolts)
Yalib is on a distinguished road
What do you guys say about G4, G5?
Auto setup - does setting up a robot in "thier goalie zone" mean he is placed on the opposite alliance's side and can block in auto? or does it mean he starts in the goalie zone of his color?
Thunderbolts 2630, Emek Hefer, Israel
2013 Israeli Regional Winner & Quality Award, Dean's List Finalist
2013 DC Regional Semi-Finalist & Industrial Design Award
Ranked 5th in 2013 Galileo
  #113   Spotlight this post!
Unread 04-01-2014, 15:43
GaryVoshol's Avatar
Cogito ergo arbitro
It does create a Catch-22 situation if BALLS are SCORED only during AUTO or in a CYCLE. A CYCLE doesn't start until all the BALLS from AUTO have been SCORED. But they can't actually SCORE after AUTO ends.
And the following text in 3.1.4 that tells when BALLS are SCORED says nothing about being inside a CYCLE.
Something for the GDC to clarify.
(since 2004)
  #114   Spotlight this post!
Unread 04-01-2014, 15:46
The_ShamWOW88's Avatar
The_ShamWOW88 The_ShamWOW88 is offline
Senior Mentor/Coach
FRC #0157 (Aztechs)
The_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to behold
Question regarding auto if anybody has any ideas. The robot is allowed to drive up to the 10pt goal and shoot/roll/layup the ball or does it have to be done from the white zone before the robot enters the red/blue zone?
"The best way to predict the future is design it"
"Striving for excellence through inspiration"
  #115   Spotlight this post!
Unread 04-01-2014, 15:54
heisenburger heisenburger is offline
FRC #4716
heisenburger is an unknown quantity at this point
I'm new to first and by looking quickly through the manual i didn't find any programming rules. so are there any programing rules?
  #116   Spotlight this post!
Unread 04-01-2014, 15:55
Chi Meson's Avatar
AKA: Brian Chidley
That line you quote where the cycle doesn't begin until all auto balls are "scored"...
They obviously do not mean "truss" scored, but "goal" scored. A clarification is needed, although I do take it to mean that all balls must be scored in goals before a cycle begins. I still see it so far that truss/catch scores are valid using balls that begin in autonomous.
I would very much like to get that clarified.
  #117   Spotlight this post!
Unread 04-01-2014, 16:01
DaveFrederick's Avatar
DaveFrederick DaveFrederick is offline
FRC #1895
DaveFrederick is a jewel in the roughDaveFrederick is a jewel in the roughDaveFrederick is a jewel in the rough
What is the password for the encrypted data?
  #118   Spotlight this post!
Unread 04-01-2014, 16:03
AKA: Trevor Naze
FIRST is pretty lenient with the programming rules. You can choose between Labview, C++ (Winriver), or Java (Netbeans). When programming, you must make sure to implement watchdog, which is a function that automatically shuts down the robot to prevent safety hazards if it isn't "fed" within a certain amount of time. Of course, you also must be sure your code doesn't allow control while disabled or autonomous, of course.
I'm sure there's other rules, but those are the big ones.
  #119   Spotlight this post!
Unread 04-01-2014, 16:04
AKA: Trevor Naze
3Zones2Goals1Alliance!
  #120   Spotlight this post!
Unread 04-01-2014, 16:52
ohrly?'s Avatar
ohrly? ohrly? is offline
Griffin Alum
AKA: Colin Poler
FRC #1884 (The Griffins)
ohrly? is an unknown quantity at this point
I'm really confused about the role of the human players, specifically these ones: http://min.us/i/bpK5KsFVN1YvK
G38 prevents player C from passing the ball to player A, and G39 prevents player A from getting the ball himself. Furthermore, player A is forbidden from inbounding a ball by G36. So what exactly do player A and B do?
