Go to Post Blasphemy! Everyone knows Mountain Dew is roboteer fuel. - Racer26 [more]
Unread 04-01-2014, 12:23
TheDrillKeeper TheDrillKeeper is offline
AKA: Josh Rodriguez
FRC #2903 (NeoBots)
TheDrillKeeper is an unknown quantity at this point
Assist System explained
Hey Chief Delphi forums! I was a little confused by all the different plays and how exactly the assists are counted, so I decided to try and figure out for myself a set of rules for the assist system.
As said in the video detailing the assist plays, the system will count assists/possessions in the way that gives the play the most points. A robot is given an assist point when it is able to be assigned its own unique zone with no other robots. In order to do this, the system will find a robot/robots that has its own unique zone and nullify the other possessions by that robot in order to give other robots their own unique zone.
In addition, balls from the autonomous period cannot gain assist points, even during teleop. This is because assists are scored during a cycle, and the balls from autonomous are not part of a cycle due to not starting on the pedestal. Try to score them during autonomous so you aren't occupied with a dead ball during teleop. (thanks MasterEric)
Originally Posted by Siri View Post
This seems to match exactly with the manual's "ASSISTS are earned when a unique ALLIANCE ROBOT POSSESSES the ALLIANCE’S BALL in a unique ZONE (i.e. red, white, or blue ZONE) during a CYCLE." My conclusion from this quote is that the Rule of Thumb is: count the number of unique robot-zone pairs. That's the number of assists.
Last edited by TheDrillKeeper : 04-01-2014 at 14:24. Reason: added extra information about assists with autonomous balls
Unread 04-01-2014, 13:46
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: Assist System explained
Unread 04-01-2014, 13:51
AKA: Josh Rodriguez
FRC #2903 (NeoBots)
Thank you! This really helps clarify the rule system. The main thing I was confused about was how a robot could get an assist point when other robots also had a possession in that zone.
Unread 04-01-2014, 14:14
MasterEric's Avatar
MasterEric MasterEric is offline
Bacon. 'nuff said.
AKA: Eric Myllyoja (E2)
FRC #2137 (Oxford Robocats)
MasterEric is an unknown quantity at this point
One thing you should make note of in your post:
As mentioned in the post Autonomous Assist, since the balls that the bots were given during auto were never on the pedestal, they never completed a full cycle. Thus:
a) You cannot score assist points with autonomous balls.
b) You should try to score those non-assistible autonomous balls during autonomous so you can spend as much time during teleop as possible getting assists.
Unread 04-01-2014, 14:25
AKA: Josh Rodriguez
FRC #2903 (NeoBots)
Done! Thank you very much.
Unread 04-01-2014, 15:58
jnelly's Avatar
jnelly jnelly is offline
FRC #2472 (Centurions)
Team Role: Parent
jnelly can only hope to improve
I'm just commenting to come back
Sleep, Lift, Muscle Milk, Repeat...
"The only bad workout is the one that didn't happen!"
-Jesse "the body" Ventura
Yeah... I lift
Unread 04-01-2014, 18:25
Bob Steele's Avatar
AKA: Bob Steele
The game should have been called Aerial "Possession"
They are using the term assist in a new way and not like it is used in sports
It is best to think of possession rather than assist.
For a team to get one assist one team has to have possession of the ball in one of the zones...
For two assists, 2 teams need to have had possession in two separate zones
For three assists 3 teams need to have had possessions in three separate zones.
It is pretty simple if you look at it this way...
One team can only get credit for a single possession and you have to have separate teams possess the ball in separate zones..
The assisting that will be done will be by robots that help other alliance robots to possess the ball in a zone that does not have an alliance robot possessing the ball already.
I think it will be played like this:
ball starts in end zone... hopefully a robot possesses it there...
it moves forward either by being carried or not... the ball is passed to another robot in either of the other two zones... and now two robots have had possession in two zones... now the only thing left to do is to recognize which robot has not possessed the ball and what zone needs that possession for the bonus... then the ball is scored...bam and you get 31 or 40 points..
I believe the alliance will rely on the monitor to see when the referees have indicated possession and then go back and fill in to get the bonuses...if necessary...the indication of possession should be real time but you must not rely on your OWN idea of what possession is but rather when the referee has seen it and recorded it.
If all three teams possess in all three zones you will get the big bonus... if a single separate team possesses in each of the zones you get the big bonus...
I think the monitor will have to be watched closely to determine when to go in for a score.
It is really nice that the GDC thought to put this monitor in a place where the alliance can really use it...
Unread 04-01-2014, 22:26
Jakenan Jakenan is offline
AKA: Jacob Rojas
FRC #0457 (Grease Monkeys)
Jakenan is an unknown quantity at this point
Ive come to the same conclusion, and agree that assist would be better explained as possession. I believe the confusion with my team was with the video explanation (I wasnt watching, rather looking at the rules i had just decrypted). I hope this can be fully explained in the Q and A.
#FRC457
Unread 05-01-2014, 10:39
cbudrecki's Avatar
cbudrecki cbudrecki is offline
AKA: Carl Budrecki (buh-dre'-key)
FRC #0222 (Tigertrons)
cbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to all
my big assist question:
Robot 1 in Red passes to Robot 2 in white. Robot 2, still in white, then passes back to Robot 1, now in blue. Robot 1 has no possession while in white. Would this count for the 3 assist rule?
Unread 05-01-2014, 10:43
cbudrecki's Avatar
as far as the confusion with the term 'assist', I just think that instead of saying 1,2,3 assists, it should be labeled as 0,1,2 assists, as one bot going for the goal does not involve any 'assistance.' Handing off to a 2nd bot is then 1 'assist,' and a 3rd bot is then a 2nd 'assist.' ... yeah, confusing term to use...
Unread 05-01-2014, 10:48
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
Ok...a question from my students yesterday still "sticks in my craw"....
"If we're playing for max points in combination and assists, how are individual teams ranked for finals at the regional?" My question is how many refs will be needed to work three different teams, three areas, marking assists, calculating points in the hot zones as they come up hot, etc.? I'm just an AP teacher but I see a lot of Swiss Cheese holes and massaging of the rules. But...that's just one prole's opinion.
Unread 05-01-2014, 10:51
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Please correct me if I am wrong as this is the core of my confusion:
This would not constitute the 3 assist, because robot 1 initiated the first assist and is thus no longer eligible for additional assist participation (no longer "unique robot/zone pair")
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 05-01-2014, 10:56
The possession information is also shown using the light strings right in front of that robots driver's https://www.youtube.com/watch?v=qc-a7-sxs4Q. But I agree that it will be important to make sure to not give the ball up until the light's you expect turn on.
Unread 05-01-2014, 11:05
cbudrecki's Avatar
Well, to answer myself... after watching the Assist Analysis video over, and over again... this would NOT be a 3 assist, only 2. "Assists will never be granted for possessions that share either a row, or a column." Since the 2 Robot 1 possessions share a column, this would not count as an assist.
Unread 05-01-2014, 11:08
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
As far as tracking assists goes, the answer is three (or even two, since there are only two balls in play at any one time which matter for assists). One ref watches each zone and taps a screen to note when a robot takes possession of a ball in that zone. The computer keeps track of the accounting.
If one ref is assigned to each ball, they have to not only note when a robot gains possession, but which color zone this happens in.
I expect there will actually be two refs that track assists on the ref touchscreens, and the user interface will look much like the 3x3 matrix in figure 3-4, except with team numbers across the top instead of 1,2 and 3. They just need to tap one of nine squares whenever a new robot gains possession of the ball. Not really that hard, when there are so few other fouls for refs to look out for.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
