Re: Self pass over the truss
good point - not sure
No matter whether the opponent can catch the ball, you can always catch the ball, since you can always possess it. This debate is about whether the catch gains points, and the rules made it clear that a catch only gains points if its by the partner.
So yes, you can catch your own pass but you wouldn't get catch points. |
You wouldn't even have time to throw it up and make it to the other side to catch it.
There are going to be some pretty fast robots out there. I'm pretty certain some of them could do it pretty handily, particularly if they shoot on the move.
The truss is only 1 foot wide, so if you stood almost below it and threw it in a shape like a steep parabola, you would only have to move a foot or two to catch it. |
if you take the size of the robots into consideration you may not even have to move at all because the bot could be long enough to just sit under the truss.
#7
Well you'd probably have to move closer to 5. 2 feet for ball, 1 for truss, then another 2 for the ball as it falls on the other side.
#8
If you're holding a ball, it has the same velocity as your robot. Drive forward at a steady speed, shoot it straight up, and it'll land right back on your robot. Granted that's a different launching system than you'd need for Top Goal, but it's perfectly doable.
#9
Then you compensate by throwing it forward slightly.
#11
the ball is heavy enough and the flight duration short enough that Kevin's approximation is a valid one (as in less significant than other mechanical errors throwing and catching) |
#12
To people talking about catching the other alliance's truss-throw:
