Go to Post Just wait till Heidi learns video-editing skills. - tkwetzel [more]
Unread 04-01-2014, 18:00
godkane godkane is offline
FRC #3875
godkane is an unknown quantity at this point
Auto Mode - HOT GOAL
How is a hot goal scored?
0:00 - Left is hot
0:04 - Ball in air on left
0:05 - Right is hot.
0:06 - Enters left goal.
When is a goal scored,
1) when the ball touches line the,
2) all the way thru the line,
3) or touches the bottom?
Are they going to use an instant replay camera?
Unread 04-01-2014, 18:01
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Re: Auto Mode - HOT GOAL
0:00 - Left is hot
As i understand, only one goal is HOT during a match??
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 04-01-2014, 18:03
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
I thought this as well but actually, no. Here's the relevant quote from the manual
Additionally, each high/low pair of goals will be designated “hot” for five seconds, but the order of which side is first is randomized. For each ball scored in a “hot” goal, the Alliance earns additional bonus points.
EDIT - that is from the very beginning of the manual in the section entitled "Summary"
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
FRC #3875
Here is the rule I'm reading.
Section 1 - The match begins with one 10-second Autonomous Period in which robots operate independently of driver. Each robot may begin with a ball and attempt to score it in a goal. Alliances earn bonus points for scoring balls in this mode and for any of their robots that move in to their zones. Additionally, each high/low pair of goals will be designated “hot” for five seconds, but the order of which side is first is randomized. For each ball scored in a “hot” goal, the Alliance earns additional bonus points.
Unread 04-01-2014, 18:05
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Oh wow....
*facepalm*
Unread 04-01-2014, 18:11
AKA: Jesse Gibson
Team Role: CAD
Oh wow....
*facepalm*
It's OK, I missed it at first too and was about to post exactly what you did before I reread the manual
2011 - Logomotion
Unread 04-01-2014, 18:19
Flimsor's Avatar
Flimsor Flimsor is offline
The Mad Cadder
FRC #1983 (Skunkworks Robotics)
Flimsor will become famous soon enough
So just to clarify, this means that either the top pair of goals, or the bottom pair of goals will be hot for 5 seconds, then the other pair will be hot for 5 seconds, right?
- 2013
Thinking outside the box implies you have limited yourself in the first place.
Robots
Unread 04-01-2014, 18:21
AKA: Jesse Gibson
Team Role: CAD
What the rule appears to say is that for the first 5 seconds either the right or left low AND high goals will be hot, then for the remainder of autonomous the other side's low and high goals will be hot
2011 - Logomotion
Unread 04-01-2014, 18:23
Flimsor's Avatar
The Mad Cadder
Okay, so my original train of thought was correct. I thought I had misunderstood it. Thanks!
- 2013
Robots
Unread 04-01-2014, 18:27
FRC #3875
Here is how I read it:
Assume left is first:
left top and left bottom will be hot for first 5 seconds.
right top and right bottom will be hot for last 5 seconds.
Unread 04-01-2014, 18:32
AKA: Jesse Gibson
Team Role: CAD
Yes, that appears to be correct. The question as to how scoring given your original scenario would go is still a little hazy. The definition of scored doesn't seem to help much but is copied below for convenience. The caveat about the ball passing completely through the opening makes me think that if the Hot goal changes just after the ball enters the goal (front edge sticking on or something) you would not get the bonus - I'm not sure if that is the intent of the rule so this could be a good question for the official Q&A.
A BALL is considered SCORED in an ALLIANCE’S GOAL if
a ROBOT causes one (1) of their ALLIANCE’S BALLS to cross completely through the opening(s) of one (1) of their ALLIANCE’S GOALS without intervening human contact,
the ALLIANCE ROBOT last in contact with the BALL was entirely between the TRUSS and their ALLIANCE’S HIGH GOALS, and
the BALL is not in contact with any ROBOT from that ALLIANCE.
2011 - Logomotion
Unread 04-01-2014, 22:58
puneeth.meruva puneeth.meruva is offline
MIT Class of 2019
AKA: Puneeth Meruva
FRC #1501 (Team T.H.R.U.S.T)
puneeth.meruva will become famous soon enoughpuneeth.meruva will become famous soon enough
Do Hot Goals only happen in Autonomous Mode?
Unread 04-01-2014, 23:00
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Yes, the HOT goal is only active in autonomous mode.
All GOALS scored during AUTO will earn a five (5)-point bonus. If the BALL is SCORED in a HOT GOAL, the ALLIANCE earns an additional five (5)-point bonus. Each pair of an ALLIANCE’S LOW and HIGH GOALS are sequentially HOT for five (5) seconds during AUTO; the first pair to be HOT is determined randomly by the FMS. The pairs are the same for each ALLIANCE, relative to their ROBOTS’ perspective. For details regarding HOT GOAL indication, please reference The ARENA Section 2.2.3: The GOALS.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 04-01-2014, 23:13
MIT Class of 2019
AKA: Puneeth Meruva
thank you!
