Go to Post If this truly bothers you, you should do something CONSTRUCTIVE about it instead of whining about it - Jaine Perotti [more]
Unread 04-01-2014, 19:40
AhAhPatel's Avatar
AhAhPatel AhAhPatel is offline
FRC #1261 (The Peachtree Ridge Robolions)
AhAhPatel is an unknown quantity at this point
Chassis issue
Coming up with some dimensions after the kickoff today with our team we came to the realization that the ball could very well be larger than standard dimensions that we build our robot to, that being 23" x 32" or 34"x 22". does this mean that instead of seeing longer chassis that we will see more wide based ones to accommodate such a large game piece? If this is true, then i would be pressed to make a wider robot to be able to intake the ball, but then of course this means your width is shortened, so you have less room for your mechanisms to fold in to.
I guess what it comes down to is what are your ideas regarding chassis orientation and size?
Unread 04-01-2014, 19:44
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Re: Chassis issue
Since it's all based on perimeter rather than max x dimension and max y dimension like it was until 2013, you can get creative with it. A square of 28" on each side (while not creative) would be right at the max perimeter and would be able to fit a ball
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 04-01-2014, 20:01
AhAhPatel's Avatar
Re: Chassis issue
while that is enough to carry the ball, you only have 4 inches of space extra for any sort of mechanisms. i mean i guess you have the 60 inches vertically to extend into.
Unread 04-01-2014, 20:04
AKA: Jesse Gibson
Team Role: CAD
Re: Chassis issue
Plus you have the 20 inches outside of the frame to work with as well - you don't necessarily need to take the entire ball into your frame to be able to control it, you would be pretty good once you got past the diameter. Not saying that taking it completely into the frame isn't doable - it looks like Team Copioli is trying it ...
https://twitter.com/TeamCopioli/stat...946432/photo/1
2011 - Logomotion
Unread 04-01-2014, 20:18
AhAhPatel's Avatar
Re: Chassis issue
interesting. I think we also have to worry about some sort of recoil coming from any sort of shooting mechanism. obviously tipping would be bad lol
Unread 04-01-2014, 20:21
AKA: Jesse Gibson
Team Role: CAD
Re: Chassis issue
Yeah if you have a high CoG, depending on the launch angle, Newton's 3rd Law may get angry and decide that your robot would be much better off on it's back
EDIT - would also depend on the weight of the robot
2011 - Logomotion
Unread 04-01-2014, 20:23
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: Chassis issue
I've already personally conceded that we might go wide frame this year. Depending on how you pickup the ball, you may have to.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 04-01-2014, 21:34
katabolt's Avatar
katabolt katabolt is offline
Katabolt
AKA: Devon Johnson
FRC #3674 (4-H CloverBots)
katabolt is an unknown quantity at this point
Re: Chassis issue
I've similarly come to the conclusion that a wide frame will be optimal this year. However, as rule G24 shows, the dimensions of a robot can extend up to 20" beyond the perimeter, which is enough to create a mechanism that extends to grasp the ball (mostly) outside the robot frame.
Unread 05-01-2014, 07:32
Random42 Random42 is offline
FRC #4533
Random42 is an unknown quantity at this point
Re: Chassis issue
If you want to fit the ball inside the chassis then you have to go octagonal.
Unread 05-01-2014, 09:03
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Chassis issue
I think you may want to calculate this again.
Sorry, quick sketch of AM14U cut to 30" long to show ball can possibly fit within frame: http://www.chiefdelphi.com/media/photos/39270
112= 30" x 26"
Last edited by Dad1279 : 05-01-2014 at 11:51. Reason: My Bad, I'll learn to add.... ;)
Unread 05-01-2014, 09:37
AlecS AlecS is offline
FRC #1323 (Madtown Robotics)
AlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond repute
Re: Chassis issue
Originally Posted by Dad1279 View Post
30"x30"
That would put the robot perimeter at 120", rules limit this to 112"
Alec S.
Engineer - Sales Representative, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 05-01-2014, 12:58
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
Re: Chassis issue
The AM14U instructions show 32"x23", either long or wide.
Another possibility that's easy to make is square, 28" long by 27" wide. That gives a bit of room for mechanisms on the sides, but is still longish.
We have already built ours 32"x32", and will get it running for prototyping, then cut it to final size AFTER we design our robot!
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 05-01-2014, 16:57
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Chassis issue
Mondo good idea. Thanks!
