Go to Post Just remember, FIRST isn't about the robot, just have fun, meet new people, and try to learn something new. Killing yourself with inhumane amounts of pressure just isn't fun for anyone. - Ian W. [more]
Unread 04-01-2014, 18:21
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
Re: Self pass over the truss
Originally Posted by Kevin Sevcik View Post
If you're holding a ball, it has the same velocity as your robot. Drive forward at a steady speed, shoot it straight up, and it'll land right back on your robot. Granted that's a different launching system than you'd need for Top Goal, but it's perfectly doable.
the ball is pretty large, the air drag would throw it off. in a perfect vacuum, yes, that would work, but not in the game
2015 MAR District Champions
Unread 04-01-2014, 20:22
Rypsnort's Avatar
Rypsnort Rypsnort is offline
AKA: Ian Rypkema
FRC #0706
Rypsnort will become famous soon enough
if you take the size of the robots into consideration you may not even have to move at all because the bot could be long enough to just sit under the truss.
Unread 04-01-2014, 22:06
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Then you compensate by throwing it forward slightly.
Unread 05-01-2014, 02:24
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
the ball is heavy enough and the flight duration short enough that Kevin's approximation is a valid one (as in less significant than other mechanical errors throwing and catching)
Unread 05-01-2014, 02:30
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Originally Posted by MasterEric View Post
What makes you say this?
The truss is only 1 foot wide, so if you stood almost below it and threw it in a shape like a steep parabola, you would only have to move a foot or two to catch it.
Well you'd probably have to move closer to 5. 2 feet for ball, 1 for truss, then another 2 for the ball as it falls on the other side.
