Go to Post Maybe you should whack it a few times with a hammer. That always seems to fix our robots. - Adam Y. [more]
Unread 04-01-2014, 21:50
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: KOP new connectors
You got them because 3M makes a huge range of really wonderful, easy to use, connectors for a wide range of tasks. They want to give them to you so that you will use them on servo and sensor lines, rather than using hobby level parts.
They want you to be so thrilled with their connectors that the next time you need a connector you Google "3M connector to ...." and find the perfect 3M connector. A connector that is in your new device that you are planning to sell millions of.
The really are nice, sturdy connectors that can be crimped on the wire with pliers. Perfect for your robot.
3M™ Link Connectors - industrial grade discrete wiring solution for servo motors, controllers, and sensors
from the first line of the Digikey link
Good luck!
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
