Go to Post Ah, this sounds like a sitcom whose pilot I should write and send to NBC - "Life With Lavery". There's a lot of eating, several practical jokes, and lots of bad hair. - Amanda Morrison [more]
Unread 04-01-2014, 22:09
Swampdog Swampdog is offline
FRC #3381
Swampdog has a spectacular aura aboutSwampdog has a spectacular aura aboutSwampdog has a spectacular aura about
what constitutes assist?
I have read the rule on possession. But what is herding? Or can you just bounce a ball off of your alliance member ?
Unread 04-01-2014, 22:27
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: what constitutes assist?
Read and reread the rules on ASSISTS. They don't strictly have anything to do with passing, ASSISTS only depend on which of your robots POSSESSES the ball in which particular ZONES. Herding counts as possessing. RobotA bouncing a ball off RobotB almost certainly doesn't count as RobotB POSSESSING the ball.
Unread 04-01-2014, 22:34
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
This is the best definition we have.
POSSESS: (for a ROBOT) to carry (move while supporting BALLS in or on the ROBOT), herd (repeated pushing or bumping), launch (impel BALLS to a desired location or direction), or trap (overt isolation or holding one or more BALLS against a FIELD element or ROBOT in an attempt to shield them) a BALL.
It seems to me that bouncing off would not be herding because it isn't 'repeated'. However, I think it may be considered launching, as long as your robot was positioned such that it would bounce it to a planned location.
I think this is worth a QA, but I bet the answer will be unhelpful.
Unread 04-01-2014, 22:39
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Launch still requires you to add force in that direction. A simple bounce is not enough.
You'll want to be sure that you are being obvious about your possession to the refs, so they can score it properly.
Unread 04-01-2014, 22:46
alextound alextound is offline
alextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these parts
You need to make 1 football move
Unread 04-01-2014, 23:19
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
The qualifying term "impel" implies that the robot taking possession would need to impart some force onto the ball, in a way beyond being just a stationary obstacle in the ball's path, and change its momentum, in order to qualify for an assist.
However, if a moving robot was heading toward intersecting with a rolling ball and then intentionally stopped itself right in the path of the ball so as to redirect the ball's momentum via only the ball's rebounding off the now stationary robot, I still think this could be considered an assist. Especially if that rebound improved the path of the ball for reaching the 3rd bot in the assist chain.
I seems to me the ability of judges to establish what in fact is a "desired location or path" might be a bit tricky to determine.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 04-01-2014, 23:23
Racer26 Racer26 is offline
Or you could just read the blue box immediately below that rule, which specifically calls out "deflecting" as NOT counting as POSSESSION (which makes sense, since I can deflect my opponents BALL without causing myself a PENALTY for POSSESSING their BALL).
Since deflection doesn't count as POSSESSION, bouncing a BALL off an ALLIANCE member does not count as them POSSESSING the BALL
Unread 04-01-2014, 23:27
1)Does an opponent hitting a ball delete all assists?
2) Does missing the final shot delete assists?
3) Does the ball staying lame for several seconds delete assists?
4) Does a deflection off wall/opponent/alliance (Accidentally) delete assists?
Unread 04-01-2014, 23:29
Alesha_webb's Avatar
Alesha_webb Alesha_webb is offline
FTC #5070 (N.U.T.S.)
Team Role: Team Spirit / Cheering
Alesha_webb is an unknown quantity at this point
It's just a unique pass that has not been seen. The way that they are going to score it is not going to depend on exactly who passes it where. Just in the unique pattern
~~Alesha
Unread 04-01-2014, 23:40
WeJohnFriedIt's Avatar
WeJohnFriedIt WeJohnFriedIt is offline
Team Captain, Driver
FRC #1466 (Webb Robotics)
WeJohnFriedIt will become famous soon enough
I don't anything nullifies the assists except for ejecting the ball from play through scoring or otherwise throwing it outside of the field.
John Fry
Team 1466, Webb Robotics
Unread 04-01-2014, 23:43
AKA: Sparks
That blue box is not in the definition of POSSES; just in the rule about not touching opponents balls. I (likely wrongly) saw that box as a special case for opponents balls.
And even so, its still going to be subjective what qualifies. "impels" is a tricky word. I don't think you'll really know until the coaches meeting.
Also, to the last guy; I don't think even ejection from the field nullifies it as passing to human players (outside the field!) is "part of the game"
Last edited by tStano : 04-01-2014 at 23:44. Reason: saw new comment to respond to as well
Unread 04-01-2014, 23:52
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
A cycle is defined as beginning when the ball leaves the pedestal and ending when the ball is scored in a goal. As far as I can tell there's no rule that says that anything resets your assists other than ending the cycle by scoring the ball.
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
Unread 05-01-2014, 00:29
dajacques's Avatar
dajacques dajacques is offline
FRC #0225
dajacques is an unknown quantity at this point
This indicates assist points are only scored as part of, and after, a goal score.
3.1.4 Scoring
Points are awarded once per CYCLE for BALLS SCORED by ROBOTS in the GOALS, BALLS SCORED by ROBOTS over the TRUSS,and for each ROBOT CATCH. Additional points are credited to an ALLIANCE upon each GOAL based on the number of ASSISTS earned by the ALLIANCE for that CYCLE.
Unread 05-01-2014, 00:37
Dr.Bot
Posts: n/a
IMHO - I think bouncing a ball off a stationary alliance member would NOT be an assist. Passing a ball to a moving alliance member who then redirects the ball by momentary contact would be an assist, even if the robot moved into position to deflect the ball and then stopped just before contact. The key is intent. A stationary robot or disabled robot can't 'assist.'
Unread 05-01-2014, 00:52
AKA: Dick Ledford
Moving to an intersecting location and then stopping in the path of a moving ball in such an orientation that the face of the robot causes the ball to rebound off it in a favorable direction seems like it should be considered an assist, especially if this cuts off a defender from redirecting the ball in a random direction.
Q&A should offer further clarification on this point, as it seems to be needed.
-Dick Ledford
