Go to Post We have about 16 pounds more to add, including the code- all that code can get heavy! - Dave Campbell [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 16-01-2003, 14:11
yangotang's Avatar
yangotang yangotang is offline
#0253 (MRT)
yangotang is on a distinguished road
Send a message via AIM to yangotang
edu bot helP???
I was playing with the EDU Bot today, and i couldn't get it working.
Can anyone give me a basic rundown of how i should start with the EDU bot?
Unread 16-01-2003, 14:56
Geoffrey4283 Geoffrey4283 is offline
Geoffrey4283 is an unknown quantity at this point
Righto
Start off by following basic instructions about hook up. To figure out where to put your Joysticks, refer to the Default Code Reference Guide for the Edu robots, I think there's one at innovationfirst.com
That will tell you which PWM's you want to use to control your motors, and which joystick port will correspond to them. Just make sure to have the switch on Tether when you're using the cable directly, and on program when you're using the built in radio.
Unread 16-01-2003, 21:24
yangotang's Avatar
#0253 (MRT)
yah i did that..
i think my robot's messed up, i got the whole team to look for stuff..
we're sending the EDU bot back, possibly
Unread 19-01-2003, 14:55
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
If you let us know more on what is wrong we might be able to help.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 30-01-2003, 22:04
utishpenguin's Avatar
utishpenguin utishpenguin is offline
penguin
AKA: atu
#0115 (Monta Vista Robotics Team)
Team Role: Communications
utishpenguin is an unknown quantity at this point
Send a message via ICQ to utishpenguin Send a message via AIM to utishpenguin Send a message via MSN to utishpenguin
Question hmm
isn't there a edurobtoics primer site....its a site that walks through the edurobtoics kit i think
MVRT PR
"When I die, I want to go peacefully, in my sleep, like my grandfather. Not screaming in terror, like his passengers."
-unknown
Unread 10-02-2003, 01:00
activemx's Avatar
activemx activemx is offline
A M X
AKA: Akshay Dodeja
activemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of light
Send a message via AIM to activemx Send a message via Yahoo to activemx
its kinda late to play around with the edu robot. Though visit the usfrist.org site for more info on the kit.
2005 - Present - FIRST Volunteer(Inspector, Ref, Judge)
2000-2004 MVRT 115
Unread 10-02-2003, 11:16
yangotang's Avatar
#0253 (MRT)
yeah. i solved the issue a long time ago. the problem was that the team number must be set as 0-1 or else the thing screws up, which was kinda wierd.
--yang
Unread 10-02-2003, 18:32
penguin
AKA: atu
--yang
s'all good... but the edu robtoics kit always keeps the electrical people busy in the beginning of the build
MVRT PR
-unknown
Unread 10-02-2003, 21:41
yangotang's Avatar
#0253 (MRT)
I actually found the EDUKit more burdensome than helpful.. it's just not enough like the real bot to make the thing work, plus it's hard to configure, in most cases, to the way how you want to prototype your robot to be.
(excuse me for run-ons)
Unread 11-02-2003, 15:07
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
I like it
I disagree about the EDU kit. I've seen a lot of people express negative opinions about it here, but I don't know how the kids would have finished without it. The real robot is not quite ready to roll yet, so they've spent the last four weeks developing and debugging their autonomous code with the mini-bot. All signs point to it scaling nicely to the real robot.
It was a major PITA to get it together, but mostly because of poor planning. I would much rather chase a 2 lb. robot around a 1/3 scale course than wrestle with a 100 lb. robot. I give it a B.
Unread 11-02-2003, 21:23
penguin
AKA: atu
Re: I like it
i agree..... but then the significance of the edu robotics kit descreases suring the build... i won't use it for protoyping tho
MVRT PR
-unknown
worst experience mike pawlak Chit-Chat 15 06-12-2004 07:04
Team 34 Bot Pics Ed Sparks Robot Showcase 0 25-03-2003 21:56
Team 1072 (Harker Robotics Team)'s bot: Tork AlbertW Robot Showcase 8 19-02-2003 13:19
what did people think of my teams bot this year (263) Rob Colatutto General Forum 8 22-05-2002 19:03
Team 524's bot Amadkow Robot Showcase 2 27-02-2002 20:36
