Go to Post I love FIRST... - jess523s [more]
Unread 05-01-2014, 01:10
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
"Dud" robots
The most concerning part of this game for me is the potential for one mistake to completely shut down a team. Say a robot during autonomous is loaded with its ball, but the autonomous malfunctions and the robot rams into the wall, loosening all the PWMs, and trapping the ball on board. This team would never have their cycles begin and be shut out of any points or even showing the scouts their abilities.
In previous years you would still be able to play with a robot down, but you are 100% sunk if the ball is trapped.
**edit - Sorry, this is only a suggestion ** There is a solution - if a robot is stuck with a ball inside, and that robot is E-stopped, then another ball is put into play.
2013 North Star Regional Industrial Design Award
2011-2013: FRC #3633 Catalyst
2014-20XX: FRC #3633 College Mentor
RPI Class of '17 / Materials Engineering
Unread 05-01-2014, 01:13
EricH EricH is online now
Re: "Dud" robots
Where is that in the rules?
Sorry, but I couldn't find it earlier when I was looking through and reading. Much as I'd love for that to be the case, I'm thinking right now that it's going to be a case of partner robots trying to free the ball from the robot. Like I said, I'd love for that to be the solution.
Unread 05-01-2014, 01:14
Registered ConfUser
AKA: Mark McGivern
Re: "Dud" robots
That was a suggestion.
Unread 05-01-2014, 01:21
Re: "Dud" robots
I figured--just the way it was phrased originally.
I'd be on-board with that solution--that is, if a ball is on the field but stuck on an inoperable* robot or other object, a manual override to the system would allow a replacement.
*For clarity's sake, I'll define "inoperable" as: Can neither eject the ball nor drive around due to failure of either mechanical systems or control systems, OR disabled by FMS or E-stop for any reason. In layman's terms, the ball is STUCK.
Unread 05-01-2014, 01:23
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
Re: "Dud" robots
Another concern is that with only one ball on the field and statistically a lot of teams who won't be fast enough to do successful passes with the faster caliber teams, I see a lot of teams not getting the chance to do anything more than defense.
Ex, a team that can score goals fast enough to win by themselves won't be willing to let a partner take all match just to do one cycle. In the past there were enough game elements for any team to take as long as they want with, with only one though....
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
julianpowell julianpowell is offline
FRC #2928 (Viking Robotics)
julianpowell will become famous soon enoughjulianpowell will become famous soon enough
Re: "Dud" robots
When you load a ball for autonomous you are taking a calculated risk. If you think it's likely that your autonomous will malfunction then you don't have to load a ball.
Unread 05-01-2014, 01:33
Racer26 Racer26 is offline
Re: "Dud" robots
THIS is a humongous part of why I'm not a fan of Aerial Assist on first analysis.
Seems to me the elite tier robots should easily be able to turn 150ish points on their own (20 pts [truss toss +high goal] x 6 cycles + 25 auto). Especially so if they have two defenders clearing the road for them on this wide open field. Total number of cycles is unlikely to change much with assisting, if anything going down slightly.
Adding one assist per cycle, brings the cycle points to 30. If doing so 4 times costs you 2 solo-cycle time periods (going from 6 cycles to 4 in a match), you have no net gain.
Unread 05-01-2014, 01:56
Anthony4004's Avatar
Anthony4004 Anthony4004 is offline
Anthony4004
FRC #4004 (MARS Rovers)
Anthony4004 is an unknown quantity at this point
Re: "Dud" robots
You do not have to load the ball into the robot, you can have it on the carpet touching.
Unread 05-01-2014, 02:22
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Re: "Dud" robots
The problem is not that your robot could malfunction and lose you the round. The problem is that you get put in the position where you have to tell your alliance partners that you think their robot's autonomous mode is worse than useless. That's a good way to make people resent you.
Unread 05-01-2014, 02:39
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Re: "Dud" robots
What if you put one robot playing defense on this single scorer, then pass with the other two? If you can't beat the single robot's score with that, then do you really deserve to win?
Does anyone else remember when TBA signatures actually worked?
Unread 05-01-2014, 02:45
Re: "Dud" robots
How will your one defensive robot do anything when the solo scorer has two defensive robots to clear the way?
Also, scoring with assists will be slower. If you can do 6 solo cycles, or 4 cycles with 1 assist, there is no difference in net score.
Unread 05-01-2014, 03:34
Damyen Damyen is offline
FRC #1574
Damyen is an unknown quantity at this point
Re: "Dud" robots
Can my robot pick that other ball and score it as well to earn more autonomous points?
Just a thought of a solution
Unread 05-01-2014, 04:35
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: "Dud" robots
Your alliance members have always been able to jeopardize your chance of winning by doing something negative for the team. This is nothing new.
Unread 05-01-2014, 07:51
magnets's Avatar
magnets magnets is offline
Re: "Dud" robots
In previous years, if my alliance partner wanted to stop me from scoring, I could still grab discs/basketballs/tubes and score them, or I could single balance, climb, or deploy a minibot. This year, if my partner gets stuck with the ball, I can no longer get points for the rest of the match. Think about if Einstein 2012 happened again, and a robot didn't work on the field. 0 points for that allinace . That's the first time they've made a game where your partners MUST continue working if they have a game piece.
I predict if there are field issues (let's face it, it's not unlikely), then teams will be really mad.
Unread 05-01-2014, 08:03
Yalib Yalib is offline
FRC #2630 (Thunderbolts)
Yalib is on a distinguished road
Re: "Dud" robots
What about a robot losing communication? just e-stop him immediately? because usually a robot who lost com will "come back to life" after a number of seconds..
Thunderbolts 2630, Emek Hefer, Israel
2013 Israeli Regional Winner & Quality Award, Dean's List Finalist
2013 DC Regional Semi-Finalist & Industrial Design Award
Ranked 5th in 2013 Galileo
