Go to Post Okay, okay, I'll bring your Krispy Kremes to the Championships ... I bought them right after the '03 Championships ... I'm sure they are still in the attic - Natchez [more]
Unread 05-01-2014, 00:40
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Re: pic: KitBot in SolidWorks Long and Wide Assemblies
Originally Posted by Coin3 View Post
Ah. Thanks for the explanation.
Something you could try is buying an external USB hard drive (ideally USB 3.0 if the computers support it), and installing Windows and Solidworks on that.
Unread 05-01-2014, 01:37
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Looks awesome! I am installing the newest version of Solidworks now, can't wait to check it out!
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 05-01-2014, 06:46
TJ_Watson's Avatar
TJ_Watson TJ_Watson is offline
RBE/ME undergrad
FRC #0190 (Gompei and the HERD)
TJ_Watson will become famous soon enough
I'm uploading all the files to 3D Content Central now, they should be up soon, including the STEP files!
Unread 05-01-2014, 07:23
jonboy jonboy is offline
Engineer/Mentor
FRC #0885 (The Green Team)
jonboy is an unknown quantity at this point
How can we find/search for the pertinent 2014FRC files on 3DCentral.com? Tags, contributor's name ...?
... jon
Unread 05-01-2014, 08:09
TJ_Watson's Avatar
RBE/ME undergrad
I'll be uploading them, so you can search for me or you can use the tag 2014kop.
Hope that helps, I'm trying to upload more files now, but I think I may have broke the 3DCC server... which is hilarious...
Unread 06-01-2014, 19:52
Anthony4004's Avatar
Anthony4004 Anthony4004 is offline
Anthony4004
FRC #4004 (MARS Rovers)
Anthony4004 is an unknown quantity at this point
I am new to Solidworks, and am not fully sure what to do to have the KoP be assebled together? I have downloaded the zip file from solidworks, but not fully sure what to do with all the CAD parts?
Unread 06-01-2014, 22:14
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
In SolidWorks there are three tops of documents:
Part - a single entity
Assembly - combination of parts. Parts are also called components.
Drawing - 2d representation of a part or assembly
You should see 3 folders Black, Green, and KitBot. Black and Green folders correspond to the kop parts lists. The KitBot folder contains three major assembly examples of many of the parts put together, AndyMarks KitBot in a long version and wide version and a control systems example assembly.
If you want to use the KitBot frame, I would take a look at the provided example. If you want to design your own frame from Andymark parts, go take a look at the robotics section www.solidworks.com/tutorials.
In the Andymark assemblies, half the frame is modeled and then a mirrored component of the other half is used to complete the assembly.
To create an assembly, click New, Assembly.
Click insert Component. Browse. Select a part or subassembly.
Click Ok. The first part is fixed to the Origin.
Insert a second part. This second part is free to translate and rotate.
Use mates to constrain geometry. For example a cylindrical face of an axle to a cylindrical face of a wheel would be a concentric mate.
I can help you through the learning curve and there are many talented people here that know SolidWorks. Just give us your questions. Marie
Unread 08-01-2014, 07:11
We updated the KOP last night at www.solidworks.com/FIRST.
Now included are STEP files of the KitBot Wide, KitBot Long and Control Board.
Also included in SolidWorks format, Ice Cube Cooler parts, Triangle parts and Ball.
At www.3DContentCentral.com, 100's of parts for FRC and FTC.
Thank you to all our SolidWorks users that have contributed models to www.3DContentCentral.com. Marie
