Go to Post I wouldn't want to force another me on everyone! - Andy Grady [more]
Unread 05-01-2014, 10:29
mitchklong mitchklong is offline
None #4859
mitchklong is an unknown quantity at this point
Is throwing worth it ?
Im trying to decide if adding a throw ability really buys that much.
Throwing can get you
Truss points (10)
Possibly catch points (10)
high goal points (9 more)
But throwing also:
causes the ball to bounce. That makes it more difficult to control than rolling.
risks ejecting the ball from the field.
can easily miss high goal and have to reshoot
relatively challenging technically
So..to throw or not to throw. That is my question.
Unread 05-01-2014, 10:34
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Re: Is throwing worth it ?
How about having a thrower that is also your shooter
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
Unread 05-01-2014, 10:36
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Throwing in a cycle can generate 20 points more than what just roll passes do just by the truss and catch bonuses. Add on the additional 9 from scoring high, and you have compelling enough reason for me. Also, a bouncing ball isn't really that hard to manage if you have some imagination. Get it to the wall or have a guide system to control it.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 05-01-2014, 11:21
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
I consider the truss pass (without catch) to be worth +20, since it comes with an assist (almost certainly). With the catch, it is worth 10 or 20 more than a normal assist.
Accurate throwing is going to be key for catching.
Unread 05-01-2014, 12:00
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
It all boils down to what the the level of impact is on increasing the cycle times when completing over truss shots & high goal scoring shots.
This then must be compared to the minimum cycle times that an efficient 31 point basic 3-assist with low goal score can give.
I can easily see the efficiently done 31 point cycles being completed almost twice as fast as an average 50 point cycle with both over truss done (no catch) and high goal scored.
Even assuming 100% success rate on over truss shooting, relinquishing ball possession with significant energy imparted to balls, and then perhaps having to contend with better positioned, more nimble than you defender blocking your effort to retrieve and reload the balls for the high goal shot seems like an especially risky time waster.
Then there is the issue of what percent of what goal shots can actually be successful on 1st try? Even at 90% accuracy this means you only gain ~8 points over the low goal (assuming 100% for them), and so in a five cycle match this would average out at only ~40 extra points, but if the the extra time investment needed, compared to low goal scoring, to reach that level of accuracy on the high goal, is only about 5 seconds per cycle, then the competition might nearly complete one more 31 point cycle and almost nullify the high goal scoring advantage.
So, if you seek to accomplish both the over truss shot and the high goal shot as your ideal strategy for each cycle, I conclude that that combination will ultimately prove more detrimental than advantageous for your final score.
This will be more the case with even an average amount of basic defense against you.
My advice would be to only attempt one or the other. and if high goal accuracy is good, that would be the one to do. The truss shot is just too big of a cycle time waster without having a consistent catch to add 10 more points and eliminate the ball chasing time waste. So, with the difficulty of executing the ball catch, the over truss shot seems like a bad idea.
Our team will only attempt high goal shots in both auto & tele of we can reach the 90+% accuracy level. We are also looking at how also to have an even more certain alternate option for low goal scoring, so we can go either way in matches where there is too much high goal shooting defense happening.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 05-01-2014, 12:24
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Truss points (10)
Might want to read the rules. High goal scores are clearly 10 points.
Base point values are as follows:
LOW GOAL 1
HIGH GOAL 10
CATCH 10
TRUSS 10
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 05-01-2014, 12:39
He said 9 more. The implication is that if you can get the low goals (and if you can't get those, you need a new robot, and quick!), throwing only nets an additional 9 on top of the 1 for the low goal that anybody can get.
In other words, the box-on-wheels can get assist and low-goal points. A throwing robot can add in the truss points, the high-goal points, and possibly the catch points, as well as picking up assists and low goals.
Unread 05-01-2014, 12:40
Racer26 Racer26 is offline
Yes... And scoring the BALL in the high goal instead of the low goal is a net gain of +9 points.
Unread 05-01-2014, 12:44
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The high goals are a lot more difficult to defend than the low goals. Low goals could be fairly locked down by two defense bots. So a high, defense, defense alliance could probably take down a low, low, low alliance.
Unread 05-01-2014, 12:45
DonRotolo's Avatar
Back to humble
FRC #0832
First, consider if the winners on Einstein in 4 months will be able to throw or not.
Second, realistically, consider whether your team can build a mechanism to do that or not.
Your answers determine the answer to the OP
Unread 05-01-2014, 14:08
redsox11 redsox11 is offline
FRC #0348
redsox11 is an unknown quantity at this point
Another thing to take into consideration is that scoring in the low goals isn't as simple as just pushing it in, there are 7 inches between the bottom of the low goal opening and the field.
Unread 05-01-2014, 14:20
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
But the ball has a 12 inch radius, so I imagine it wouldn't be that difficult to push in.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 05-01-2014, 14:24
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
We discussed this as a team and I believe came to the conclusion that even if we had a reliable shooter, we would only use it for autonomous and truss points, unless someone is blocking both of the low goals.
The only advantages:
Autonomous points
If a team can successfully block the low goals for an entire match and
nobody on your team has the capability to shoot high, it comes down to the
autonomous points.
The disadvantages:
Loss of control, time wasted trying to recover the ball
Missed shots, leading to ^^
Yet another system to be designed (although what else would we spend our
time on?)
Overall, we resolved to prototype a shooter/thrower, and if our prototypes were semi-successful, we would keep it as an option.
Unread 05-01-2014, 14:36
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
If you have the resources you should certainly attempt to throw.
If not, try being the best catcher you can be. Are you a lineman, a wide reciever, or the quarterback? That mostly depends on how youre built. And I mean that about the robot as much as I do the team.
I love the positional designs this game requires.
Unread 05-01-2014, 14:51
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
Something not explicitly stated in the rules, but I feel like it works against the spirit of the game (and expect a Q&A regarding it) is whether a robot can throw a ball over the Truss and catch it themselves.
Effectively kills a "Teamwork" element of this game, but if you get some space, I feel like it could be an easier 20pt bonus than trying to coordinate throwing and catching with 2 different robots.
If it ultimately IS legal, than throwing is definitely worth it. If not, unless you plan to shoot for 10's, I'd say NO.
