Go to Post Like fishing, some may get away as you are reeling them in, but never letting out enough line to get the big ones at the bottom is just disappointing. - Eric O [more]
Unread 05-01-2014, 05:37
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Catching without throwing
Since a catch is defined as when the ball is sent over the truss and then in possession by another alliance robot without the ball touching the ground or human player, can I simply place the ball on top of the truss, and the have my alliance partner pick it up off of the other side of the truss for a catch? The ball went over the truss without touching the ground or human player, so is this a possible strategy?
Unread 05-01-2014, 06:05
AWB's Avatar
AWB AWB is offline
AKA: Andy
FRC #0423 (Simple Machines)
AWB is an unknown quantity at this point
Re: Catching without throwing
From Rule R3:
the ROBOT height may not exceed 60 in., except as allowed by G23.
Rule G23:
If a ROBOT is in contact with carpet in its GOALIE ZONE...there is no height restriction
my point: no, you cannot extend upwards of 5' unless in the goalie zone.
good luck
Unread 05-01-2014, 11:22
bEdhEd's Avatar
Ah, OK I see. Thanks!
Unread 05-01-2014, 12:53
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
It might be possible with Coanda effect manipulation devices (like leaf blowers). You might want to Q&A that before you commit to the design though.
