Go to Post neato. - ebarker [more]
Unread 04-01-2014, 18:32
anthonygraff24 anthonygraff24 is offline
FRC #2872 (CyberCats)
anthonygraff24 is an unknown quantity at this point
Taking Over the coding load for my team this year, quick, simple question
Hi guys! So I've learned a good deal of how to do the coding for the robot and I'll figure out more as I go along, but I need to know what to do with my code when I'm finished with it. Like how do I upload it to the robot so when I use the driver station thing it will run. Any and all help would be greatly appreciated
Unread 04-01-2014, 19:43
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Re: Taking Over the coding load for my team this year, quick, simple question
http://wpilib.screenstepslive.com/s/3120/m/7885
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 04-01-2014, 22:04
shindigo shindigo is offline
AKA: Mike Parker
FRC #0102
shindigo is an unknown quantity at this point
Short answer is: when you run the program in netbeans it will download the executable to the crio, reboot the crio and start your program. Then use the driver station to set the game mode (Autonomous or teleop) then start the match. This will start you program running in the crio at either the start of teleop or Autonomous.
I highly recommend you learn how to attach the debugger as soon as possible because it will save you many hours that would otherwise be wasted watching the crio reboot
Unread 05-01-2014, 11:36
usacat6 usacat6 is offline
AKA: Will
FRC #2228 (Cougar Tech)
usacat6 is an unknown quantity at this point
Very good support information on the control system and programming procedures located at http://wpilib.screenstepslive.com/s/3120/m/7885
Good luck.
Unread 05-01-2014, 12:09
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
Originally Posted by usacat6 View Post
Good luck.
^this
you're in for a ride
2015 MAR District Champions
