Go to Post it is not as hard as it looks, but thats prolly cause we havent tried to build it yet... - robolemur1236 [more]
Unread 12-18-2013, 10:13 PM
Kyle Chan's Avatar
Kyle Chan Kyle Chan is offline
FRC #0368 (Kika Mana)
Kyle Chan is an unknown quantity at this point
Passing Parameters with Command-Based Robot Structure
This year our team just switched over from LabVIEW to Windriver and we've decided to go with a Command-Based structure. After looking through various guides, we were able to get the Teleop part of the program going but the Autonomous portion is giving us problems. How do we pass through parameters to specify how far we want the robot to drive (for example)? If anyone could help us out with this, it would be greatly appreciated.
Unread 12-18-2013, 10:44 PM
Re: Passing Parameters with Command-Based Robot Structure
Where do you want to pass parameters from?
You can make command constructors that take parameters and use those. Have you see WPI's GearsBot videos? They lead you through a complete command based program (albeit in java). https://www.youtube.com/playlist?lis...F26A88C6D16C8F
Unread 12-19-2013, 02:12 AM
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Our autonomous code reads the desired motions from a text file and executes them. We make up our own command language each year, build a parser and call functions/methods to execute a series of motions or actions. That way we do not have to change the code for each match or before playoffs, we just FTP a new command file to the robot.
HTH
Unread 12-19-2013, 03:22 AM
Kyle Chan's Avatar
Thanks for the quick responses! We'll look into constructors and also reading commands in from a text file.
Unread 12-30-2013, 06:43 PM
Kyle Chan's Avatar
Update: We got the autonomous up and running. Had to use a "this" pointer and make it equal to a variable of with a different name from the parameter. In our code we used power, leftdistance, and rightdistance parameters/local variables. Format: "this->localvariable = parameter"
Unread 01-05-2014, 11:44 AM
AKA: Brad
#0190 ( Gompei and the Herd)
You can also choose which command, and therefore which autonomous program runs during autonomous using some radio buttons or combo box on the driver station.
http://wpilib.screenstepslive.com/s/...smartdashboard.
Hope this helps.
Brad
Brad Miller
Robotics Resource Center
