Go to Post If this was really about changing the culture, FIRST would be on Will.I.Am's website. - Meredith Novak [more]
Unread 05-01-2014, 13:05
Fatrick Fatrick is offline
FRC #0449
Fatrick is an unknown quantity at this point
Low Goal Defense
Is it valid to extend an appendage less than 20 inches into the low goal from the side, as a form of defense? There is a space from the side when the robot is in the goalie area, and an appendage could be extended into the low goal from this.
Unread 05-01-2014, 13:07
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: Low Goal Defense
An appendage that is less than 5 feet (60 in) from the ground is legal, as long as it stays within 20 in of the frame perimeter. As far as the legality of putting that appendage into the low goal, that's not specified, so that's a Q&A question. I wouldn't put it past FIRST to outlaw that.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 05-01-2014, 13:12
Happy Birthday! RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
There is a rule (forgot the number) disallowing actions by a robot that interrupt the flow of the game. So, covering all three open faces of the goal could only be done intermittently, like while the ball is arriving.
If your blocking device leaves too little room for the ball to enter goal, and it is maintained in that blocking position while a robot is trying to insert the ball into the goal, then you would likely get penalized.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 05-01-2014, 13:14
Zuelu562's Avatar
AKA: Jake Janssens
-Dick Ledford
Rule G25 ROBOTS on the same ALLIANCE may not blockade the FIELD in an attempt to stop the flow of the MATCH. This rule has no effect on individual ROBOT-ROBOT interaction.
This strategy is not a violation of the blockade rule. The blockade rule's key requirements are 1) multiple robots 2) attempting to interrupt game flow by preventing movement past the multiple robots.
Team Resume
Volunteer Resume:
Unread 05-01-2014, 13:20
cdicorpo's Avatar
cdicorpo cdicorpo is offline
AKA: Chris DiCorpo
FRC #2064 (The Panther Project)
cdicorpo is on a distinguished road
Thumbs up Re: Low Goal Defense
Blocking INSIDE the low goal is a pretty bold concept. Although it seems to comply with all the rules (20 inch extension rule, etc.) I see no mention of blocking the goal itself. In other words, it appears it is perfectly legal. It would be a good question for FIRST Q&A. Very bold idea. Good luck.
Unread 05-01-2014, 13:27
AKA: Dick Ledford
Placing your robot appendage(s) into (or over faces of) the cube of the low goal at a spot(s) intended to redirect the balls from entering the goal could also be considered possessing their ball, since you are obviously intending their direction to go away from the scoring direction.
-Dick Ledford
Unread 05-01-2014, 13:33
cdicorpo's Avatar
AKA: Chris DiCorpo
-Dick Ledford
Touché. I overlooked that rule. I take back what I said. It is most likely not legal. I would still ask FIRST though.
Unread 05-01-2014, 13:39
FRC #0449
Then wouldn't having any method of blocking the balls in the 6 inch cylinder also be "possesion"? What is the difference between that and the appendage to the low goal?
Unread 05-01-2014, 14:03
TVwazhere's Avatar
TVwazhere TVwazhere is offline
Unregistered User
AKA: TomTom
FRC #0020 (Rocketeers)
Team Role: CAD
TVwazhere can only hope to improve
If it is legal, they will most likely make an amendment to clarify that making it illegal, considering its not exactly in the spirit of FIRST :/
"Well there's your problem!" -Mythbusters
"It's Dope" -Will.I.Am, Jan 9th, 2011 FIRST Locomotion Kickoff
"Design Thrice, Measure Twice, Cut Once"- Tom Tom
"If your life was a Disney film, then this is the part of the movie where you would break out into song" - Tom Tom
Unread 05-01-2014, 14:09
Sean Hackett Sean Hackett is offline
FRC #2067
Sean Hackett will become famous soon enoughSean Hackett will become famous soon enough
-Dick Ledford
3.2.3.4 G12, the rule which disallows the "launching" of an opponent's ball, also defines "deflecting" as "being hit by a propelled BALL that bounces or rolls off of the ROBOT." Deflecting is legal with regard to contacting the opponents' ball. An arm extending into the low goal would be considered to deflect the ball, not launch it, for it is merely being hit by a ball projected by the opposition.
Unread 05-01-2014, 14:14
Just because something is not in the spirit of FIRST (whatever THAT means--trust me, everybody has a different take on that, including the GDC) does not mean that it is illegal, or that it will be made illegal in the future.
For example, in 2010, I'm sure a lot of people thought that catching a ball right off the return was "not in the spirit of FIRST", particularly when it was returned to pretty close to the goal. Never ruled illegal, though, and multiple robots did it.
I'm thinking that there won't be a change to say it's illegal, partly because there's that other low goal and it's very difficult to block them both.
Unread 05-01-2014, 14:23
AKA: Dick Ledford
Well then blockading the low goal with stationary robot body and any appendages protruding into the goal may be technically legal, but if the bot attempting to score merely presses the ball against your bot's appendage(s) or body, that would likely trigger the "possessing an opponent's ball" penalty, so it's too risky IMO.
I suspect a new rule will be added to make inserting appendages into an opponents low goal illegal.
-Dick Ledford
Unread 05-01-2014, 15:14
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
-Dick Ledford
In this case it would actually be the other alliance being penalized. You can't force another robot into taking a penalty.
Unread 06-01-2014, 02:12
AKA: Dick Ledford
The question would be who is forcing the result to happen. That could go either way. If your bot is defending mine, and I try to shoot past you, but ball sticks in your robot, are you saying you won't be penalized, because my bot forced the penalty on yours by merely shooting?
Unless my shot was not headed toward any valid target, that would be an unlikely ruling, and I suspect my bot pushing ball into low goal with your bot's appendage preventing scoring would also yield penalty to your bot.
I guess the critical factor is whether your bot remaining stationary during any contact with ball absolves your bot of receiving any penalty. If so, then it seems like a seriously good defensive strategy.
-Dick Ledford
Unread 06-01-2014, 11:20
-Dick Ledford
Possessing the other Alliance's ball is directly stated as a penalty (G12), so if the ball gets stuck in your robot, you will get a penalty. However, if the other alliance came and purposely put their ball on/in an opposing robot, they would most likely receive a technical foul under G16. Errant shots should not receive G16 penalties, though.
I don't think low goal defense will ever be a penalty, though. In the blue box for G12, deflection is explicitly stated as legal and not possession (“deflecting” - being hit by a propelled BALL that bounces or rolls off the ROBOT).
