Go to Post Most people who say "winning doesn't matter" have not won enough to have a balanced opinion on the issue. - T^2 [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.75 average. Display Modes
Unread 05-01-2014, 14:13
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Re: How do we launch this thing? 2014
What you want to accomplish with your launches will dictate how you launch.
Aerial shots:
-Lower angle (<45º line drive) high goal shots?
-Arching (~45º+) high goal shots?
-Over truss 45º shots?
-Over truss near vertical shots (robot keeps rolling and catches ball on other side of truss -no catch points; posession maintained)
-Over truss shots
Low to floor shots:
-Passing only?
-Low goal shots across floor?
-Robot-to-robot transfer/assist passing?
-Passing to human "shots"?
Handling all these well would require both a variable energy launcher and a variable angle launcher spanning nearly a 90º arch in the vertical plane.
A turret for targeting some amount to left-right might also be useful.
Our team is starting out building a surgical tubing powered ram launcher.
The ram will have an infinitely variable retraction tension cord winder with a trigger system that only accelerates the ram itself and the tension cord - no stored energy wasted on anything else - like a crossbow, but without the bow.
We are prototyping now to see how compact and short travel of a ram we can have while still shooting fast enough for consistent accuracy and adequate trajectory & travel.
We are not yet clear now many degrees the shooting angle of ram will need to be made adjustable. We also want to load balls as high up on the bot as possible, so shots cannot be easily blocked, and less energy needed to clear truss and hit the high goal.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
