Go to Post What I would really love to see is having the teams try to solve a problem that is real scientists are trying to solve right now. Wouldn't it be cool if a team came up with a robot design that could solve one of the world's worst problems? Talk about FIRST publicity! - Beth Sweet [more]
Unread 05-01-2014, 15:01
Travis_Team2619 Travis_Team2619 is offline
FRC #2619
Travis_Team2619 is an unknown quantity at this point
Re: Team 2619 - Install Problems
My problem has been solved by my Lead Mentor's son has fixed it. I am grateful for you helping!
Travis
Unread 07-01-2014, 00:11
mega900997's Avatar
mega900997 mega900997 is offline
FRC #0263 (Sachem Aftershock)
mega900997 is on a distinguished road
If you don't mind me asking, how was he able to fix the toolbar not showing up? I'm currently having the same problem.
Suffield Shakedown Winners & Most Points Scored
South Florida Regional 6th Seed, #5 Alliance Captains, Regional Winners w/ 2383 & 386, Innovation in Control Award
NY Tech Valley Regional 5th Seed, QF, Excellence in Engineering Award
SBPLI Long Island Regional 4th Seed, Finalists
Hopper Division 14th Seed, QF
Unread 07-01-2014, 00:53
Fifthparallel Fifthparallel is offline
AKA: Sam Chen
FRC #1410
Fifthparallel is an unknown quantity at this point
The FIRST button in the toolbar ribbon appears after installing the WPILib 2014 C++ update (aka Workbench update) available from http://first.wpi.edu/FRC/c/update/Release/.
Make sure to:
1. Close WB before running the installer/update
2. Ensure the Wind River Registry is no longer running (check the available icons in the Windows system tray and ensure the Wind River Registry is set to appear.)
3. Then run the update.
sudo chmod u+x helloworld.sh
gotta start somewhere.
Unread 07-01-2014, 19:47
mega900997's Avatar
I have tried installing the workbench update after installing Windriver and making sure that the registry is not running and the FIRST toolbar is not appearing. I have all of the other files such as the WPILib files and the vision examples from this year but the FIRST Toolbar is not appearing.
Unread 08-01-2014, 00:28
FRC #2619
Travis
Okay, the problem that I was having was with the last updater (for Windriver) was with the update tool, when it was copying over the files, the text on screen was zipping by so fast that you couldn't even read it! So what had happened on my computer was that the System PATH variable was missing/messed up, so I will also show you here how to fix that problem (Windows 7 only).
1) Open the [Start] menu, right click on [Computer], and choose [Properties] (at the bottom of the drop down list)
2) Click on [Advanced system settings] on the left (if you are prompted to enter your administrative password, do so now)
3) Click on [Environment Variables...]
4) Scroll down under the section labeled "System variables" until you see [PATH] under the Variable heading.
5) If [PATH] is not there, you need to click on [New...]
1. Set the Variable Name as PATH, and set the Variable Value as the value shown at the bottom of this post.
6) If [PATH] is there, then you need to click on [PATH] and then [Edit...].
1. Add a semicolon [;] to the end of what you have in the Variable Value, and paste the value at the bottom of this post to the end of what you already have in the Variable value field.
7) Click Ok until you are back to the [System] screen, then press the X.
8) Run the Updater again (the last thing to do after the 1 or 2 discs). If the text doesn't zip by in 5 seconds, you are good. If it does, continue asking for help on ChiefDelphi.
Variable value is all of the following (until the return):
%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\Sy stem32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShel l\v1.0\;C:\Program Files\Java\jdk1.6.0_27\bin;C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\;C:\Program Files\IVI Foundation\VISA\Win64\Bin\;C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin;
[*NOTE* I found out how to do this from a previous team member who is now in college. I could maybe ask him for some more help, but it isn't guaranteed.]
