Go to Post I am definitely as much a student as any one of the kids on the team. - Hieb [more]
Unread 05-01-2014, 15:35
austin4169 austin4169 is offline
FRC #4169
austin4169 is an unknown quantity at this point
Why only one ball?
It seems like only one ball is in play during the teleop period, which really doesn't make any sense:
Although an ALLIANCE may start a MATCH with up to three (3) BALLS, the PEDESTAL will only be illuminated when the last BALL that started the MATCH is SCORED, effectively reducing the number of BALLS in play per ALLIANCE to one (1).
I would think more time would be spend with human players running around with balls outside the field than will be spent with the balls being controlled by the robots. Did I get something wrong? thoughts?
Unread 05-01-2014, 15:37
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: Why only one ball?
The field staff handles balls that are not in play. Human players other than the primary inbounder are there pretty much to save you from starting almost completely over if a ball goes way out of bounds for some reason.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 05-01-2014, 15:39
jgcoded jgcoded is offline
FRC #0945
jgcoded is an unknown quantity at this point
Technically, in the beginning, more than one of an alliance's balls can be in play at a time, but a new cycle won't begin until that last ball is scored. Once the last ball is scored, the light on the ball pedestal will light up.
Autonomous mode could hurt an alliance if their robot misses. It might just be better to roll into your zone and claim the 5 points, rather than go for a shot, unless you're 100% certain you won't miss.
Unread 05-01-2014, 16:50
FRC #4169
regardless of who handles it, I kinda feel like its gonna take a while for somebody to get the ball to get from past one end of the goal to the other end of the field. And thats gonna be annoying if your robots are just waiting for more balls.
Unread 05-01-2014, 16:59
alectronic alectronic is online now
no team (Volunteer)
alectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant future
while they are getting the one you scored, another has already been placed on the pedestal, so there is no delay. They put a new one on the pedestal as soon as the light goes off, so it is already there and good to go once the light comes on.
Unread 05-01-2014, 17:18
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
My though is that you haven't watched robots trying to manipulate large balls....it's hilarious to watch, and agonizing if you're on the team that's trying to do it. It's not as easy as you might think. I expect that if an alliance can get the ball from one end of the field to the other, using 3 robots, it will take roughly a minute to do so. If they have their acts together.
Unread 05-01-2014, 17:33
yash101 yash101 is offline
AKA: null
This game will be quite some challenge. I guess one possibility could be some hammer assembly meant to bounce the ball. When the ball is in the air, the robot can get under it. However, that still seems quite impractical!
Unread 05-01-2014, 19:42
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
You clearly haven't seen footage of 2008. There was a fairly large number of robots that could get those balls around the field multiple times a minute.
Unread 05-01-2014, 19:45
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
http://www.youtube.com/watch?v=NYNEAL_dK6I
Unread 05-01-2014, 19:53
GaryVoshol's Avatar
Cogito ergo arbitro
HP's better not run around outside the field, unless they want to rack up FOULS.
3.2.7.9 G39
During the MATCH, TEAMS must remain in contact with the area of the FIELD (ALLIANCE STATION or HUMAN
PLAYER AREA) in which they started the MATCH. Exceptions will be granted for inadvertent, momentary, and
inconsequential infractions and in cases concerning safety.
Violation: FOUL
(since 2004)
Unread 05-01-2014, 20:01
MrForbes's Avatar
AKA: Jim
I was there....the robot generally had to pass the ball to itself (over the overpass) once per lap.
It'd going to be hilarious....I described the game to my mom today, she could immediately imagine how much fun it will be to watch. I hope she can make it to the competition, to see her grandsons play
Unread 05-01-2014, 22:53
Alan2338's Avatar
Alan2338 Alan2338 is offline
Former Team Leader/Driver - Alumni
AKA: Alan Cabiness
FRC #2338 (Gear it Forward)
Alan2338 will become famous soon enough
Okay, so a few of us on 2338 think we are either missing something or we found something interesting.
First off, a few things.
Is there anything that explicitly states a ball is on the pedestal to begin the match? We haven't found any...
Next
3.1.2 MATCH LOGISTICS
Are there 3 or 4 balls total available to be put in the rotation of cycles?
Also
G5
For ROBOTS starting in their GOALIE ZONE the TEAM may decide if the BALL is: staged between the TRUSS and the ZONE LINE and not contacting an ALLIANCE partner, or removed from the FIELD for the MATCH.
With the definition of a match as the full 2:30, if it's removed from the FIELD for the MATCH, is that ball permanently out of the rotation of Red or Blue's Match balls?
G5
For ROBOTS starting in the white ZONE, the TEAM may preload one (1) of their ALLIANCE’s BALLS such that the BALL is touching their ROBOT.
Even more with the auto balls, do you have to take one if not in the goalie zone? And if you can choose to opt out, and leave it out of auto, is it out of the FIELD for the MATCH?
If we are correct about this whole limited number of balls in a rotation, and there is not a stockpile, do you lose out by choosing for a goalie or choosing for someone not to take a ball? If this is true, you could end up with only two balls. I am already worried about the speed of the field worker being a variable to worry about, but if you only end up with 2 balls, it becomes even worse.
2013 Wisconsin Regional Winners (111, 1732)-Midwest Regional Semifinalists, 2nd Seed Captain, (111, 1675), Gracious Professionalism
Galileo Division Quarterfinalists, 7th Seed Captain (2512, 1323)
2014 Crossroads -Quarterfinalist, 8th Seed Captain (4085, 2358)Midwest -Finalist, 2nd Seed Captain (1732, 3936)
2015 Wisconsin -Quarterfinalist, 2nd Seed Captain (2077, 167) Judge's Award Midwest-Finalist, 1st Seed Captain (1756, 171) Chairman's
Archimedes Division Winner, 1st Seed Alliance (1023, 3996, 1089) Einstein Semifinalists
DePaul Class of 2018 - Computer Science
Unread 06-01-2014, 00:37
no team (Volunteer)
They stated during kickoff that field crew would stage a new ball anytime the light was off, so that it would be available to the team when the light came on. (I'm not sure how else you would get the first ball into the CYCLE?)
I don't think there is a specific number. The idea is that whenever a ball is scored, another is available for play. That is what they imply in the Kickoff videos:
http://www.youtube.com/watch?v=ERuue...qTbhru_5#t=107
As with above, I think that is over-analysis. I don't think the crew will "only" have those 2 balls to use, it is just a queue from all the balls they have back-stocked so that one is always available.
For starting positions, please see G5.
If a ROBOT does not report to a MATCH, its ALLIANCE may decide if the BALL is: staged between the TRUSS and the ZONE LINE and not contacting an ALLIANCE partner, or removed from the FIELD for the MATCH.
You never have to take a ball. But any ball you take in auto must be put into a goal before you can score ANY points in teleop.
Unread 06-01-2014, 13:55
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Next
Also
You only "end up with" 1 ball no matter what. After you score your 3 or less autonomous balls, only 1 ball is placed onto the pedestal no matter what. That is what 3.1.2 means.
Does anyone else remember when TBA signatures actually worked?
Unread 06-01-2014, 14:26
Racer26 Racer26 is offline
Multiple times a minute, yes.
BUT
Even 2008 World Champion team 1114, with Simbot SS being arguably the most dominant robot in FRC since 71 in 2002, was only consistently doing 6-7 hurdles in a match.
I expect that a top team flying solo in 2014 will be able to achieve 6, maybe 7 1-assist cycles. Top alliances at championship will be lucky to push 5 3-assist cycles in a match.
